Question about Roadstar CD-308MP/FM CD Player
I m using roadstar cd-943dvd (car dvd player) now its display going dim and every time i start my car and on the player it needs to configuer each time
2000. Why doesn't it play a CD and indicates ER6?
Did you try to clean the lens of your optical reader? A typical product is selle dy Amazon and most retail stores
Memorex CD and DVD Lens Cleaning Kit
Tutorial to use a cleaner is shown in youtube
How to Clean CD DVD Laser Lens in Computer
How to clean DVD or CD player or recorder lens Sony RCD W500C
how to clean car audio player
and much more, just do a google search for
Youtube Clean Car DVD Lens
Jul 25, 2015 | Subaru Outback Cars & Trucks
Onboard LCD display
did you try to insert a different cd? see the settings like OSD button on the remote control or display to view the tracks.
CHARCOIS
Sep 13, 2008 | Toshiba SD-4900 DVD Player
LG RH2T80 DVD/Recorder front display very dim.
Very clever and an easy way to fix a problem, bravo!
Feb 06, 2012 | Televison & Video
DVD display says "Wrong disc" no matter which disc
Leave dvd player on for a lengthy time to dry up condensation, may take a few weeks?
Dec 01, 2010 | Norcent Technologies DP313 DVD Player
Dim display on Cambridge Soundworks 88CD
I can't find a manual for this but my guess would be there is a setting for the Display to dim it at all times unless you touch a control.
Feb 26, 2010 | Cambridge Soundworks 88CD CD Player
How do you dim the display light for night time driving on a Phase Linear SD 1411 ,It's like driving with a spot light in the car
You must use the illumination wire to have it correspond to the brightness of your dash lights.
Not all units have this function.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 28, 2009 | Jensen VM9510 Car DVD Player
Jvc dvd XV-N322S REGION CODE-2 is showing 'NO FILE'
It's a software problem pls upgrade ur dvd player.ur problem will be solved
May 11, 2009 | JVC XV-N322 DVD Player
Need Remote Codes
The manual on Page 10 says that with these modes (DVD,CD,MD,CDR,HDD) on the Remote you can control an Onkyo DVD player and CD/MD/CDR/HDD player/recorder.
For DVD, on page 12, it says to just push the DVD button (top right) and the following buttons will functions as stated.
ON/STANDBY button
This button sets the DVD player to On or Standby.
Number buttons
These buttons are used to enter title, chapter, and
track numbers and to enter times for locating specific
points in time.
DISC +/– button
This button selects discs on a DVD changer.
TOP MENU button
This button is used to select a DVD’s top menu.
Arrow [UP]/[DOWN]/[LEFT]/[RIGHT] & ENTER buttons
These buttons are used to navigate DVD menus and
the DVD player’s onscreen setup menus.
RETURN button
This button is used to exit the DVD player’s
onscreen setup menu and to restart menu playback.
Playback buttons
From left to right: Pause, Play, Stop, Fast Reverse,
Fast Forward, Previous, and Next.
SUBTITLE button
This button is used to select subtitles.
AUDIO button
This button selects foreign language soundtracks
and audio formats (e.g., Dolby Digital or DTS).
DISPLAY button
This button is used to display information about the
current disc, title, chapter, or track on the DVD
player’s display, including the elapsed time, remaining
time, total time, and so on.
CLR button
This button is used to cancel functions and to clear
entered numbers.
MENU button
This button is used to display a DVD’s menu.
SETUP button
This button is used to access the DVD player’s
RANDOM button
This button is used with the random playback function.
REPEAT button
This button is used to set the repeat playback functions.
PLAY MODE button
This button is used to select play modes on a component
with selectable play modes.
Feb 05, 2009 | Onkyo TX-SR304 Receiver
Radio stations
The +12V_Memory (pin 4 on A connector) must be connected to a permanent (not shutoff by ignition key) +12V.
HTH
Jan 22, 2008 | Roadstar CD-258US/512 CD Player
No DISC message displayed
Clean the lens by soft cloth by hand maually, lens cleaning will solve the problem
Aug 29, 2006 | Panasonic DVD-RV45 DVD Player
Roadstar CD-308MP/FM CD Player Logo
109 people viewed this question
Top Roadstar Car Audio & Video Experts
xxxxxx xxx
Are you a Roadstar Car Audio and Video Expert? Answer questions, earn points and help others
