Philips model 37Pf9631D. Power LED blinks 6 times & won't turn on
  • 70 Answers
Hello, that pretty much means that your power supply board went bad.
Posted on Aug 27, 2010
Philips 37pfl5332d won't turn on. A blue light comes on and then turns red and blinks 6 times. Can I fix the tv or is it time to buy a new one?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Blinks counts to Philips Brand TVs are not direct' like other brand TVs. The details about how to count the fault blinks to Philips TV models are given in detail.
Mar 30, 2014 | Philips 37PFL5332D 37 in. LCD Television
Philips 50pfp5332d/37 won't power on...led light blinks 4 slow, 6 fast...i can not find error code 46 anywhere
Error 46
Description Pacific 3
Detected by VIPER
Device T6TF4HFG
Error/ Prot E
These info are for qualified service technicians.
Sep 09, 2012 | Philips 50PFP5332D 50 in. Plasma...
Screen wont come on, LED blinks once then 4 times whats this error code and where do I begin?
hiya
the power board has failed are you happy with opening the back of the tv? if so then look at the board for any capacitors that have domed and unsolder them and replace
this is a known issue which phillips know about and refuse to address from what i can gather they hope that customer get fed up with complaining
hope this helps
John
Oct 26, 2011 | Philips 37PF9631D 37 in. LCD HDTV
I have a Philips 37PF9631D/37 which has 6 times blinking red light syndrome. After opening up it appears there are two 250V 820 uF capacitors that may be faulty. Are these safe to...
Look for bad capacitors on power supply board they will be vented or swollen on top.
1000uf 16v 3300uf 10v 330uf 10v. Look for boards on shopjimmy.com
Also check the fuse on the inverter board it maybe bad.
Oct 15, 2011 | Philips 37PF9631D 37 in. LCD HDTV
Philips 37PF9631D 37 red light blinks 6 times
Code 6 is a I had a similar problem with my 42 in Philips LCD HDTV. Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired ofcourse) and found four bulged capacitors on the PSB. Many major electronics companiesPhilips/Magnavox, Sony, Panasonic, and others were sold capacitors that failedin 2-5 years instead of 10-20. Thecapacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in allsorts of devices and cause a wide range of failure problems. Here are some options for you. 1. Have it fixed by a professional $$$$$$$??????? (Is itunder warranty?) Remember, TVs CONTAINHIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk. 2. Open your TV and find PSB. (The board that the power cordplugs into) Check for faulty caps. If you find some (bulged or leaking) bad capsreplace the entire board. The entireboard costs around $250 right now because they are in high demand right now.They can be found online. I would definitely shop around though. 3. Remove and then replace individual faulty caps. This takes some soldering skill. Caps are inexpensive and if you can take care of it yourselfit will save you hundreds. This may be your problem. If you determine that it might be. I have a Tip/How TO tutorialon this site that may also help. Itgives step by step instructions for replacing caps on PSB #715t2432-2. If this isyour board you are in luck. Here is theLink: Fixingthe Philips Turns/shuts off on its own problem. I'm working on uploading pictures to helpguide people though the process as well. Let me know if I can do anything to help. Hope this helps and if it does please rate itaccordingly. Good luck.Kaufman605
Dec 16, 2010 | Philips 37PF9631D 37 in. LCD HDTV
Philips Cineos flat screen TV vith Ambilight 37PF9631D/10, went in standby and blinking red power led diode once-two times in cicles.
Sounds like an issue with the power supply board. We will have to go component by component and you will need to knowledge of using a multimeter. If you are skilled enough to do this then let me know and I will help you troubleshoot it.
Mar 19, 2010 | Philips 37PF9631D 37 in. LCD HDTV
My Phillips Flat TV (Plasma) Model 50PF9431D/37 is Blinking an error code of 6 long and 3 short red blinks I am assuming it is an error 63. I have to unplug the cord and plug it back in up to 6 times...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting the number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Sep 02, 2017 | Philips Televison & Video
Ptv915 won t turn on; led blinks 3 times, then continues blinking 2 times over & over. Tv shut off with ''snap''.
HI, your power supply circuit board is damaged and, you will need to replace this damaged component asap if possible. this will restore your units operational value.
Jun 05, 2009 | Philips Televison & Video
Red blinking light
The red light blibking 6 times indicates that the power supply board has a defective or damaged area. I know this because i had the same problem...bought a damaged tv for parts and replaced the power supply board as the tv would not turn on...wokrs like a charm now.
Jul 24, 2008 | Philips 37PF9631D 37 in. LCD HDTV
Televison & Video Logo
116 people viewed this question
Top Televison & Video Experts
