Question about Maytag Atlantis MDG8400AW Gas Dryer
The dryer starts, it fires. But after like 30 to 60 sec. burner shuts off. All filters and exhaust are checked.
  • Maytag Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Posted on Aug 29, 2010
Why does dryer start run a little beep 3 times cut off
Really you need to provide your model number. but that said... the number one cause of a dryer shutting down after a short warm-up is a blocked exhaust outlet. Dryers have a sensor that checks the exhaust temperature... if its not moving the hot air out side than it over heats and trips the sensor which will shut off the dryer for safety (no fires please!!). So check your exhaust outlet outside for lint blockage... check your exhaust hose/pipe for kinks where lint can build up and of course always check the lint screen for blockage.
Aug 05, 2014 | Kenmore Dryers
When you first start up dryer everything is good. After burner shuts down just glow plug comes on but burner will not fire up.
Check for proper air flow. Pull exhaust hose from the back of the machine, turn on, form an opinion about air flow.....hook back up, turn unit on, go outside and see if the air volume is the same....Suspect air flow restriction, which will trip thermal sensors (rather than catch fire)...
Jul 05, 2011 | GE Dryers
Seems to work but doesnt dry
check the entire exhaust vent wok
a moister sensor detects any built up of lint and shuts the burner off to prevent fires starting
Jun 09, 2010 | LG DLG5932W Gas Dryer
I have a Westinghouse DG400JXW1 gas dryer. The burner ignites on initial start. After approx. 60 sec. it shuts off. 60 sec. later the igniter comes on but the burner does not ignite. This repeats itself...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 25, 2010 | Dryers
It taking too long to dry. I checked for blockage in the exhaust and lint and everything was ok.
Pop open the peep hole at the front bottom and watch the igniter glow until it ignites the gas. Are the burner flames a strong blue flame? Watch it for a little while. Does it stay lit for a few secs and shut down and then try to cycle back on? By the way, how old is this dryer?
May 20, 2010 | Fisher and Paykel DGGX2 Dryer
Isn't heating up. takes forever to dry,
Disconnect the complete exhaust vent tubing and clean it out thorourghly. Then it will dry. There is a moister sensor in your dryer and when the lint builds up inside the vent tubing the sensor shuts off the burner to prevent fires from starting
Apr 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer starts for 30 sec.+thenshuts off with
sounds like the blower is not cooling the heater coil fast enough this will cause it to shut down to prevent fire
Jun 06, 2009 | Dryers
Gas......starts to heat then quits minutes later.
Problem is your gas solenoid coils. When they get worn they will open til they get out then shut. They will need to be replaced.
Part number 279834 replaces for most models.
May 15, 2009 | Kenmore 62602 Electric Dryer
Dlg 5932w
My suggestion would be to make sure that the lint-filter and the exhaust flex hose are removed and cleaned. If you have the plastic type flex-hose, be aware that these can heat up and catch fire. Be sure to also check the exhaust port coming out of the dryer (that the flex hose attaches to); make sure that there is nothing obstructing the air flow, if there is, then clear & clean and try to restart. If not, I would call a service company...
Jan 12, 2009 | LG DLG5932W Gas Dryer
Gas dryer fires up once and that's it
suspect coils on burner once burner fires and heats up area coil may fail on next firing 2 coils are present.. whirpool sends both in kit
Apr 26, 2008 | Whirlpool GGX9868J Gas Dryer
Maytag Atlantis MDG8400AW Gas Dryer Logo
76 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
