Question about The Learning Company Compton's Interactive Bible (CIB3844AE) for PC
I want to install compton's interactive bible and into windows 7
    Brigadier General:
  • 3,513 Answers
This is not compatible with Windows 7 yet. The latest version is compatible with windows vista only.
http://support.selectsoft.com/products/C/LLCOMZOBIJ.htm
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Posted on Aug 27, 2010
3 Suggested Answers
  • 2841 Answers
SOURCE: I have upgraded to Vista and can't install
It is not compatible with Windows Vista. Go to the manufactures web site or call them and see if they have any advice.
Posted on Oct 07, 2009
  • 1082 Answers
SOURCE: New computer with 64-bit...can't install
Install it in compatibility mode as an administrator.
1. Right click on the program's shortcut, .exe file, or installation program.
2. Click on Properties.
3. Click on the Compatibility tab.
4. To Run a Program in Compatibility Mode -
NOTE: Runs the program using settings from a previous version of Windows. Try this setting if you know the program is designed for (or worked in) a specific previous version of Windows.A) Check the Run this program in compatibility mode for box. (see screenshot below)
B) Click on the drop down menu arrow and select which version of Windows the program was made for. (see screenshot below)
NOTE: Always pick the latest Windows version the program was written for to have a better chance of it running properly in Windows 7.Check run as administrator.
Posted on Aug 31, 2010
I have an older version of Compton's "Real Science" . Is it possible to install this on my new computer running windows 7
Not exactly. If you have windows 7 professional, or ultimate, you can try installing windows XP mode. Go to microsoft's website for it. you will then be able to install the program under the new virtual XP installation, and it will then be available for use under XP mode programs list. it will run in an XP style window. It's pretty neat. Otherwise, it's quite difficult to make 16 bit programs to work on a 64 bit operating system. there are ways, but it takes a great deal of computer know how, and how to work with some fiddilly software.
Oct 17, 2013 | The Learning Company Compton's Interactive...
Trying to install Bible Navigator, using windows 7 and it won't load corrrectly. Is it compatible with Windows 7?
have you tried to install it thru the add & remove program in the control panel?
if you have & it didn't work -- try this---
go to my computer
go to the drive it's in
right click on the drive
click on explore
look for a setup or install icon & click on it & see if it will install that way
I had to install windows7 upgrade this way on my laptop
good luck
Sep 11, 2011 | Csdc Bible Navigator - Lifeway Christian...
Can I copy the disc to a pen drive and run from the pen drive which is more convenient than running from the CD?
Yes you can do that. you copy files to your cd to your pen drive and then run the applications .exe file.
But there are some instances that you cannot copy a file from cd to pen drive or even to computer.
This instances is caused by CD that is copyright protected. it means that the files of the CD is not allowed by the Producers to be copied. Also, if your CD is bootable, when you transfer the files to a pen drive, your files will not be bootable anymore.
Hope my solution helped. Thanks for using fixya!
Jul 15, 2011 | The Learning Company Compton's Interactive...
I am running Vista. I have loaded an older version of Comptons Interactive Bible. It loaded, installed just fine,. I cannot view the videos. I get a view error. Can this be fixed?
First, make sure the software lists your OS (Operating System) as compatable. If Vista is not listed it may not ever work correctly or you may need to download a "patch" or driver to make the software function as designed. Next, you should contact the software manufacturer directly and see if they have a fix or patch for you specific problem. And lastly, it may be a problem with the software or drivers on your machine. Can you play other video software that is similar in nature? What is the year of release on the Comtons software?
Apr 07, 2011 | The Learning Company Comptons Interactive...
Recently purchased a new computer with windows 7 and the version I have says it won't install. Is there a new version that is compatible with windows 7 available?
What version of Windows 7 are you running? You may have to run in XP compatible mode. You can do this by right clicking the installer/application and going to properties. Then go to the compatibility tab. In here you can select different options, I would suggest checking the "Run this program in compatibility mode for: " option and then selecting the operating system the program was built for. I have heard that others were able to run this version on windows 7 using this technique. Hope this helps!
Feb 23, 2011 | The Learning Company Compton's Interactive...
I am trying to install The bible library 3.1 version on Windows 7 is that possible
I am told by the authors that 3.1 is not compatible with Windows 7. They suggest the most recent version.
Hope that's helpful.
Jan 11, 2011 | ValuSoft The Bible Library Deluxe Special...
New computer with 64-bit...can't install my current version of Compton's Interactive Bible. Is there a fix available
Aug 31, 2010 | The Learning Company Compton's Interactive...
I have upgraded to Vista and can't install Compton's Interactive Bible NIV
Look at the very bottom. It should say BYC8K54. If it dosent say that, its not compatable with Windows Vista.
Oct 06, 2009 | The Learning Company Compton's Interactive...
The Learning Company Compton's Interactive Bible (CIB3844AE) for PC Logo
168 people viewed this question
Top The Learning Company Computers & Internet Experts
k24674
Bapco
Are you a The Learning Company Computer and Internet Expert? Answer questions, earn points and help others
