Question about Kenwood KR-V5580
I have Kenwood KR-V7060 receiver and unable to program my ATLAS OCAP 5 remote to accept codes for it. Really only need volume to work with the remote will be ok with me at a minimum. I have tried all the codes I can find online for Kenwood but none of them work.
  • 319 Answers
SOURCE: problem with playing my Kenwood KR-X1000
Unit apparently has problems. Check/replace batteries in remocom
Posted on Aug 14, 2008
MNfisherman
  • 11896 Answers
SOURCE: need a code for universal cox cable remote to turn on and off Kenwood KR-V-8040 Receiver
[PDF] Cox Manual File Format: PDF/Adobe Acrobat - View as HTML
not respond to the Cox Universal Remote Control after trying all of the codes listed for your brand,or if your brand is not listed at all,try searching for ...
www.cox.com/support/digitalcable/hdtv/pdf/Universal_Remote.pdf - Similar pages
  1. More results from www.cox.com »
  2. Universal Remote Control Codes Apr 17, 2009 ... More Cox Remotes, Includes Cox Digital Interactive, Universal DVR, Navigator, Millennium and Model ER1 PDF manuals. Cox Universal Remote ...
    www.xdiv.com/remotes/ - 73k - Cached - Similar pages
  3. How to Program a Cox Universal Remote for Your TV | eHow.com How to Program a Cox Universal Remote for Your TV. Have you ever dreaded programming your universal cable remote for your TV? Many people put off this very ...
    www.ehow.com/how_2153479_program-cox-universal-remote-tv.html - 52k - Cached - Similar pages
Posted on Jun 01, 2009
  • 4 Answers
SOURCE: My Kenwood KR-V5570 receiver powers
i had exact problem.
the bare wire speaker cables that connect via a clip connecor in back of the receiver are pushed too far in. something inside is shorting out with the speaker cables. solve this issue by either tightly twistng or soldering the wire ends ( then clip the ends about 1/4 inch long). watch out for the same issue of electrical shorts at the speaker end of the cables.
Posted on Sep 05, 2009
smarthome2
  • 1114 Answers
SOURCE: kenwood kr v 6080 keeps shutting off when you turn
Receiver say's "Protect" or turns on then off posted on Dec 13, 2009
MessageRate.ThreadID = 3632423; MessageRate.ProductID = 0; c81ea4d.jpg smarthome2
Rank: Guru
Rating: 88%, 432 votes
The most common problem found on FixYa for Audio Video2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire2_bing.gif. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers2_bing.gif one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers2_bing.gif) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Feb 28, 2010
SOURCE: Kenwood kr-v6030 master volume wont go down
To zyclon3, I've got a KR-V6030 that the volume knob some how got broke and had to take the receiver apart and get the knob out and play with it with the remote untill I got control. but I have to becareful cause it will go full blast if I'm not carefull going down in volume have to be especialy carefull since theres no stop.
Posted on Jan 08, 2011
Remote code for kenwood receiver kr-v86r
If your Bose remote really is universal, you should be able to search for a code that will enable some functions of your Kenwood receiver. The Bose remote may not have a suitable code in its library.
Sep 29, 2014 | Audio Players & Recorders
Can Atlas Ocap 5 control Sansui TV/DVD combo? If yes, what code does it need?
You have this backwards. The Atlas Ocap 5, if programmable, contains a library of codes, one or more of which can control your Sansui. There may be a search feature you can use to find what works.
May 13, 2014 | Sansui Televison & Video
No power
One has to open her up and check for aged or swollen caps on the
power supply.
Sep 08, 2012 | Kenwood Audio Players & Recorders
I have an Atlas Ocap remote, need a control code for a Dynex Blu ray player
Hello
Blu-Ray payers cannot be operated by universal remote controls.
Mar 17, 2012 | Televison & Video
We have lost the remote control for this tv llg 172wt. can i program another remote?
Hi
LG TV can be synchronised with Vizio universal remote control. Code is:
0056
Setup codes for LG TV with "Atlas Metrocast OCAP-5 device Universal remote control are:
1265, 0178, 0442, 0700, 0829,
0856, 1178, 1325, 1423, 1758,
1993
OK.
Jul 26, 2011 | LG L172WT 17 in. HD-Ready LCD Television
Where on the Kenwood KR-V5580 do I connect a sub woofer
Wherever the unidentified subwoofer's manual recommends. As there are no volume-controlled pre-amp outputs it would have to be a model that accepts full-range speaker level input if you want to control its volume locally.
Jul 02, 2011 | Kenwood KR-V5580
The list button doesn't work and I am unable to
turn off your cable box
turn off the dvr
disconnect cable box from wall outlet
disconnect dvr from wall outlet
unplug e-sata cable from dvr
replug e-sata cable back in to dvr
plug dvr into wall outlet
turn on dvr
plug in cable box to wall outlet
turn on cable box
wait for cable box to go completely thru startup procedure
...then try your list button again.
Mar 01, 2010 | Televison & Video
Time warner remote not working on a RCA model L32HD31 R TV
trying to get code for time warner remote for my rca 32" hd tv
Jan 20, 2010 | Televison & Video
Need a code for universal cox cable remote to turn on and off Kenwood KR-V-8040 Receiver
Jun 01, 2009 | Kenwood Audio Players & Recorders
Kenwood KR-V5580 Logo
169 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
