Question about Saeco Magic De Luxe Espresso Machine
Water leak I have the first edition of this machine and the water that is leaking that is suppose to be going to the tray is now leaking out of the side onto my counter
  • the3rick May 06, 2008
    it is the magic deluxe
  • Lodave06 Oct 30, 2008
    I have water leaking out to the right of my coffee machine (Vienna Digital Deluxe). I have the machine 4 years. I had the boiler replaced two years ago due to water leaking out. That only lasted 1 1/2 years. Now the water is leaking again, but it is not hot water, it is cold water, so I don't think it is the boiler.
Your machine needs repair. could be a leaky valve, clogged release chute, or a boiler gone bad.
90% of the time is a bad boiler.
Boiler work is going to cost ya on average 200 and up.
Posted on May 14, 2008
Water leak from Electrolux Kelvinator EPK09CRN2A portable air conditioner
You'll have to open it up and check for a displaced condensate collector. This may look like a funnel with a drain tube that is supposed to go to the tray
Nov 28, 2012 | Electrolux E23CS75SS Air Conditioner
Kenmore 54351 Dehumidifier is leaking -- water isn't going into the tray, but seems to be leaking out into the floor.
Mine is doing the same thing. The bucket is dry and the floor is flooded, so it is not an inability to condense, and it is not that the bucket has overflowed, and the bucket does not have a leak. It had been working great and then this suddenly started happening, it's as if the water is not flowing along the proper route and instead is gathering behind the bucket.
Nov 27, 2012 | Kenmore 54351 Dehumidifier
Our Saeco Magix Deluxe (old style) has developed a leak. It happens inside the machine, on the left, and is pretty severe, during coffee making. Sometimes there is just a little coffee ground in the...
When the machine is done brewing some water is relieved into the drip tray. This is the pressure relief. Some coffee residue is also taken into the drip tray. This is normal. As long as nothing is under the machine your OK.
Oct 23, 2010 | Saeco Magic De Luxe Espresso Machine
About once every 7-10 days, an excessive amount of water leaks from beneath our dryer, flooding our laundry room. Is there an area in the dryer that water from wet clothing is collecting before it leaks...
Their is a catch pan that has 2 float switches in it. One of them is supposed to pump the water into the water tray atop the machine.
The other is supposed to kill power if the pump motor fails. I would be willing to bet a hose came off the pump. When the tank gets full the water gets expelled to the floor. Here is a manual for condenser dryers:
Jul 03, 2010 | Dryers
Water leaks from the bottom of the odea go when brewing. We have soaked the brew group, tried to lube every spot we could think of, and still no luck. Machine is 1 and 1/2 years old. thanks.
If it's from the left side of the machine, probably the tap valve seals are leaking. If alot of water leak out without any coffee from the spout, then the hoses rupture or boiler leakage inside the machine.
Jun 18, 2010 | Saeco Odea Go
My Saeco Vienna Superautomatica leaks
Check the little chamber under the white plastic valve behind the brew unit, that might be blocked with coffee.
Apr 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
Water filter leaks replaced filter with bypass water leaks from drain holes underneath
In the very back of the unit, there is a black rubber drain hose that is supposed to drip into evaporator tray that is mounted on top of the evaporating tray. Check that hose is not plugged and that water is draining in tray.
Sep 15, 2009 | Refrigerators
Dehumidifier leaks
Either there is a hole/leak in the tray, or the drain line is clogged. You are giong to have to access the tray to determine this: standing water is plugged line and no water is busted pan. This will determine your avenue of approach.....
Aug 31, 2009 | Ebac Neptune Dehumidifier
Water leaks from softner dispenser
I had same thing with MtgNeptune frnt loader. Manual sed may be a kink in the front drain hose, caused by sudden burst in water pressure. Not in my case. A service call and $90 laterwasn't fixed. I pulled the soap tray and found rinse water wasn't going down the well as fast as it was filling, causing water to spill down front, and around the door. I turned down the water pressure 2 days ago and 9 loads later- no problem! It may take a few minutes longer to fill, but far less work than mopping after each load or hitting 'pause' and 'start' while waiting for the the water level to go down. We're on a well and ocassionally have change in water pressure. I don't know if this was the problem, but it was definately my solution! I turned the intake vavles at the wall to 1/2 pressure. Floor is staying dry and the drain tray beneath is also dry ($12.00 Menards). I hope this helps.
Jan 12, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Moffat fridge leaks, every couple days water on floor at front of fridgee
The reason why it leaks is because the pipe that discards the water underneath the refrigerator is clogged and must be cleaned. The water normally drains through this pipe into the bottom tray of the refrigerator where this water deposit is supposed to evaporate during normal conditions. When the pipe is clogged then the water does not fall into this tray. Therefore, turn off the refrigerator (power off/ previous taking-out of all food of course!) than go behind the fridge and locate this pipe (plastic hose / if you have difficulty locate at least the tray on the bottom and than locate this pipe / to locate it you can see the little hole on the back bottom of the freezer this is where the water is supposed to get out. Put water into the hole and you can see where it falls). Clean the pipe and the problem should be solved.
Jul 09, 2008 | Refrigerators
Saeco Magic De Luxe Espresso Machine Logo
165 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
