Question about Vintage Keeper chillR 900
Unit stopped operating. As on 3 prior occasions, I replaced the controller unit. This time, the unit operated briefly, then stopped, and I cannot get it started again. Have disconnected and reconnected controller several times with no result. Not a fuse problem. Not a power problem. The number 57 remains lighted on the controller, even after I set the temp to 60 (or any other number). Possible ancillary problem: lots of small black flecks from under the fan area, and also exhaust area. Any suggestions?
  • 1 more comment
  • bkochchico Aug 29, 2010
    OK, so I take the unit out of the wall and remove the cover so I can replace the sensor. I notice that in the containment (?) tray below the large black "tank" (the only word I know for this since I'm not knowlegeable about equipment of this type) there is a quantity of brown-colored, dry material...formerly some kind of liquid, it appears. Looks like it has been there for awhile. I don't see an obvious leak source, so I assume this is some sort of overflow, coolant maybe? At any rate, is this indicative of a bigger problem than just the controller/sensor issue previously discussed? The unit is almost 5 years old, if that makes any difference. And, the black flakes I mentioned in the first post...there is a quantity of those at the base of the back (inside) of the "radiator" or whatever it is called, that is in front of the fan that pushes the cold air into the wine room...looks like paint from the radiator, since there are areas between the radiator fins (?) which appear silver in color, while most of the radiator is black...So, am I out of coolant and that's why it won't work, or should I go ahead and replace the sensor and see if it works? Thanks.
  • bkochchico Sep 01, 2010
    I sent another comment directly to Silverdragon but don't see it posted here, so here is a summary: I pulled the unit out of the wall and removed the case to change out the sensor. When I opened the case, I discovered a large amount of dried brown and black material in the catch basin below the large tank in the unit. It flaked when scraped. Nothing damp in evidence and it looked like the material had been there awhile. Does this mean my tank is out of coolant or has experienced some other failure that has caused it to stop working. Also, the black flecks I referred to in my original post appear to be paint that has come from the radiators...does this mean anything regarding the units failure? Thanks for your advice.
  • bkochchico Sep 08, 2010
    Given the state of the bottom of the unit with all the dried, formerly liquid, material around, and rust and oxidation on other parts of the unit, this sounds like the best guess to find a solution. If this doesn't do it, a new unit will. Thanks!
  • 3,083 Answers
I'm not familiar with this syle of cooler, but I would suspect a relay or contactor ahead of the control board, and if the contacts on it are oxidized, the compressor won't start, or would start intermittently, at best. Look for that part, and try that first. If the compressor has a reset switch, check that, also. It's possible that the compressor is low and has triggered that switch by getting too hot.
Couldn't find any reports of this problem on the net, so can just take an uneducated guess.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 08, 2010
  • 12,061 Answers
This is a Sensor problem usually the thermostat or thermistor itself. Either that or some "Other" sensor is.has failed, and it is this, then, that stops the device from working.
Also I suggest you check you Power Supply. As if there is a fault here, nothing else can be alright.
Unfortunately you have NOT discovered the original fault, the same fault, is why three boards have faulted prior.
Check ALL Voltages. Check ALL Sensors.
Posted on Aug 28, 2010
Chamberlain whisper drive residential door opener model LW3500 stops after perhaps 2 seconds, lights flash and door will not open or close
Page 36 owners manual.
35
Operation
Diagnostic Chart
Your garage door opener is programmed with
self-diagnostic capabilities. The "Learn"
button/diagnostic LED will flash a number of times
then pause signifying it has found a potential issue.
Consult Diagnostic Chart below.
Installed
Safety Reversing
Sensor
"Learn"
Button
Safety Reversing
Sensor
Bell Wire
Diagnostics Located
on Motor Unit
LED or
Diagnostic
LED
1 Flash
Safetyreversing
sensorswire open
(broken or
disconnected).
OR
2 Flashes
Safetyreversing
sensorswire shorted
or black/white wire
reversed.
Symptom:
One orbothof the Indicatorlights onthe safety
reversingsensors donot glow steady.
l
Inspectsensor wiresfor a short(staple in wire),correctwiring
polarity(black/white wiresreversed),broken or disconnected
wires,replace/attach asneeded.
l
Disconnectall wiresfrombackofmotor unit.
l
Remove sensorsfrombracketsand shorten sensor wiresto
1-2 ft.(30-60 cm) frombackeach ofsensor.
l
Reattach sending eye to motor unitusing shortened wires.If
sending eye indicator lightglowssteadily,attach the receiving
eye.
l
Align sensors,ifthe indicator lightsglowreplace the wiresfor
the sensors.Ifthe sensor indicator lightsdo notlight,replace
the safetyreversing sensors.
3 Flashes
Door control or wire
shorted.
Symptom:
LEDis not lit ondoorcontrol.
l
Inspectdoor control/wiresfor a short(staple in wire),replace
asneeded.
l
Disconnectwiresatdoor control,touch wirestogether.If
motor unitactivates,replace door control.
l
Ifmotor unitdoesnotactivate,disconnectdoor control wires
frommotor unit.Momentarilyshortacrossred and white
terminalswith jumper wire.Ifmotor unitactivates,replace
door control wires.
4 Flashes
Safetyreversing
sensorsslightly
misaligned (dimor
flashing LED).
Symptom:
Sendingindicatorlight glows steadily,receiving
indicatorlight is dim orflashing.
l
Realign receiving eye sensor,clean lensand secure
brackets.
l
Verifydoor trackisfirmlysecured to wall and doesnotmove.
5 Flashes
Motor overheated or
possible RPMsensor
failure.Unplug to
reset.
Symptom:
Motorhas overheated; the motorunit does not
operate ortrolley is stuck onstopbolt =Motorunit hums briefly;
RPMSensor=Short travel6-8"(15-20 cm).
l
Unplug unitto reset.Tryto operate motor unit,check
diagnosticcode.
l
Ifitisstill flashing 5 timesand motor unitmoves6-8"(15-20
cm),replace RPMsensor.
l
Ifmotor unitdoesn'toperate,motor unitisoverheated.Wait
30 minutesand retry.Ifmotor unitstill will notoperate replace
logicboard.
6 Flashes
Motor CircuitFailure.
Replace Receiver
LogicBoard.
Symptom:
Motorunit doesn't operate.
l
Replace logicboard because motor rarelyfails. https://www.chamberlain.com/CatalogResourcesV3/en-us/shared/files/tucmanuals/114A4252.pdf
Jun 30, 2017 | Building Materials
My Gree hansol split air conditioner wall mounted model gwh18tc-d3dna1a says it has a "Error U5" what does this mean
U5 Malfunction of current detection for the complete unit. A/C status, During cooling and drying operation, the compressor will stop while indoor fan will operate; During heating operating the complete unit will stop operation. Possible Causes, Therese a circuit malfunction on the outdoor unit control board AP1, replace the outdoor unit control panel AP1.
Mar 06, 2015 | Heating & Cooling
Garage door opener won't work
Motor has overheated; the motor unit does not operate or trolleyis stuck on stop bolt = Motor unit hums briefly; RPM Sensor =Short travel 6-8" (15-20 cm).• Unplug unit to reset. Try to operate motor unit, check diagnostic code.• If it is still flashing 5 times and motor unit moves 6-8" (15-20 cm), replace RPMsensor.• If motor unit doesn't operate, motor unit is overheated. Wait 30 minutes andretry. If motor unit still will not operate replace logic board.
Aug 30, 2012 | Craftsman 3/4 Hp Garage Door Opener System...
It shuts off and blinks 11
AHX18MEV
4 - 12
[8] SELF-DIAGNOSIS FUNCTION
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
3. CHART
<INDOOR UNIT> ?:1-second ON / 1-second OFF
Problem
symptom
Outdoor
unit indication
(LED1)
Indoor unit Malfunction
No.
Content of diagnosis Check point Action
Lamp Main Sub Main Sub
Normal
condition
Normal
blinking
? ? ? ? ? Timer (Orange) 0 0 Normal
Operation (Red)
Super Jet (Green)
Indoor and
outdoor
units do not
operate.
1-time ? ? ? ? ? Timer (Orange) 1 0 Outdoor unit
thermistor
short-circuit
Heat exchanger
thermistor short
circuit error
(1) Measure the resistance
of the outdoor
unit
thermistors.
(1) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
Super Jet (Green)
? ? ? ? ? Timer (Orange) 1 Outdoor temperature
thermistor
short circuit error
(2) Check the lead wire
of the outdoor unit
thermistor for torn
sheath and shortcircuit.
(2) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 2 Suction thermistor
short circuit
error
(3) No abnormality
found in above
inspections (1) and
(2).
(3) Replace the outdoor
unit control
PWB assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 3 2-way valve
thermistor short
circuit error
? Operation (Red)
? ? Super Jet (Green)
LED1
AU-X24MV, AU-X24MEV
AU-X18MV, AU-X18MEV
LED1
May 27, 2012 | Sharp Heating & Cooling
We had an electrician install a Hunter ceiling fan in our daughter's bedroom along with a Hunter remote control. The light will randomly turn on in the middle of the night. It seems to occur only when...
Before I did anything else I would try changing the code on the problem fan. Change the dip switches in the fan and in the remote controller unit to a different code. It is not impossible that a neighbor has the same code in their unit or a device in the area is operating off the same code. Probably the cheapest thing to try next.
Sep 06, 2010 | Hunter Dryers
The unit begins and after a short time the unit stops.
it sound like the unit is very low on r134a refrigerant and in being so the compressor is overheating and the thermocouple sensor on the compressor body is shutting off power to compressor to keep it from burning up
Jan 17, 2010 | Frigidaire FDL25P1 Dehumidifier
Turntable turns intermittently so unit will not operate
The turntable fan and light all share the same feed, first check wiring for loose connections the problem though is most likely with the controller
Dec 28, 2009 | Viking DMOC205SS Microwave Oven
Random operation of Chamberlain HD900D garage door opener
As for all of us as Experts at Fixya. We would greatly appreciate if you would place your question in the right category so that an Expert with knowledge of this field can provide you with help. Sorry that I could not be of more assistants. I will inform other experts in this field of your issues so that they can redirect to help you. Thank you for using Fixya.
Dec 05, 2009 | Building Materials
Mitshubishi split muh-18nvand inside msh-18nv
-Start the unit.
-Press EMERGENCY OPERATION switch.3-minute time delay works.Test run operation operates for 30 minutes.
-Check voltage to terminal block of outdoor unit.Is there 12V DC between 2-1?
-If voltage is presenet check the wiring, compressor contactor outdoor fan motor and compressor.
-If no voltage check voltage to terminal block of indoor unit.Is there 12V DC between 2-1?
-If if voltage is present re-connect the continuity of indoor and outdoor unit connection.
-If no voltage replace the indoor electronic control P.C.
board.
-But also check the coil thermistor sensor and room air thermistor if this two is out of range it can cause the tripping of out door unit. It has the resistance of 8 to 10 k ohms at 25 deg c temp.
Jan 04, 2008 | Heating & Cooling
Vintage Keeper chillR 900 Logo
133 people viewed this question
Top Vintage Keeper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Vintage Keeper Refrigerator Expert? Answer questions, earn points and help others
