2009 Toshiba 55 inch lcd t.v. turns off by itself after 1 hour and 50 minutes I have to wait a minute or two before it will alow me to turn it back on. then it consistantly repeats this cycle over again. In addition, randomly but often it will turn off after only 20 minutes, If it is during this 20 minute cycle then it turn itself back on aoutomaticly! I have had the service guy out several times he has replaced the Main PCB, Inverter and Power PCB still not fixed! Then he took the t.v.back to his shop. and said he had no problems. He thinks it has to be something in my house interfearing... How would I even test for this is there any companies that do this? I have unpluged my Cablebox DVR and the proble still existed. I have run a movie through the Bluray player and the problem still exists....I do have a Onkio home theater that I got at the same time I got the t.v. it has always been hooked up to run t.v. Please help!! Thanks you!
  • lil_bit42 Aug 28, 2010
    2009 Toshiba REGZA 55ZV650U
  • 10,594 Answers
Let me know model number written on rear of tv, this will enable me to check its schematics if I have it.
Thanks.
Posted on Aug 27, 2010
  • Shahid Electronics
    Shahid Electronics Aug 28, 2010
    It sounds firmware problem and only Toshiba service center can update it.
Toshiba television won't turn on after power flicker
Free Fix For Toshiba 50" TV That Will Not Turn On. - YouTube
? 2:20
https://www.youtube.com/watch?v=8-0nQ57Bvow
Mar 21, 2012 - Uploaded by rstarre ten g
My flat screen tv cuts off and on while the power but is on what should i try before i buy a new one .... I have a ...
Toshiba TV power outage - AllExperts
en.allexperts.com > ... > TV/VCR/Stereo Troubleshooting
Feb 3, 2011 - TV/VCR/Stereo Troubleshooting/Toshiba TV power outage - no power... we had a power outage (they're calling rolling blackouts due to power grid ... but I admit I'm now afraid to turn it off for fear it won't come back on again.
Toshiba 32c120u LCD TV won't turn on - Tom's Guide
www.tomsguide.com/answers/id.../toshiba-32c120u-lcd-turn.html
May 27, 2015 - My toshiba tv is flashing but won't turn on with remote or power botton on tv itself ... dang this worked for me but after a minute it stoped working.
Dec 28, 2015 | Toshiba 58L7350U 58" 3D 1080p LED-LCD TV -...
Smart T.V Sumsung Got Stuck
It sounds that your TVs' timer function is set to 'ON' for 15 minutes time. Check it, and make it 'Off'. Refer its user manual for details.
Jul 21, 2013 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
Have a 55 inch samsung lcd tv and it keeps turning off, if i wait 20 minutes it will come back on but only for a few minutes, help !
samsung plasma just started doing the same thing, but turns itself on & off only seconds apart, so I can't even get a picture. Another site gave this advice.
Press D.menu
select SETUP icon
select SYSTEM
select SOFTWARE UPGRADE
select STANDBY MODE UPGRADE
select OFF
Nov 13, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
Sony wega 55 inch tv turns on fine but after one minute tv shuts itself off and comes back on 40 seconds later by itself and this cycle continues - none of the error code lights blink
This kind of problem occurs when lamp becomes weak that means near to end of working life hours but still not dead nor broken.
Replacement of lamp in tv will solve your problem, lamp replacement procedure is easy and would be written in user manual.
Thanks.
Oct 30, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
55 inch toshiba led tv audio sometimes gets garbled. must turn set off and on to correct
I have a Samsung 55 inch plasma that has experienced intermitent garbled audio, sometimes very frequent (a couple of minutes between episodes) and long in duration (several minutes). Switching to another channel and back would correct the audio.
I ran the auto program channel function a couple of times and it eliminated the gabled audio problem, except for infrequent (once every hour or two) and very short (a second or two in duration) episodes of gabled audio.
I found a thread on a CNET forum on this subject and it seems that the garbled audio problem affects a number of Samsung flat panel models.
Jan 16, 2010 | Televison & Video
Plasma TV turns off by itself-won't sty on for
when i turn my 32 inch VIVIO plasma tv on it turns pff by itself. i want to know why this is happening
Dec 07, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Turning off by itself
This TV probably needs the convergence amp IC's replaced. When they go bad the TV will not turn on.Call a good TV Tech and tell him you want the IC's upgraded to STK 392-150 instead of the original STK 392-120 and check all resistors in the circuit for proper value. They could be burned or open.
Jul 30, 2009 | Philips Magnavox 55P9271 55" Rear...
Strausbourg Manor Wall Clock chime adjustment
It is normal for the average wall clock. Of course, this can be adjusted, but without watch/clockmaking knowledge it is impossible, because first you need to find out which part of the movement is causing early chiming - and there are plenty of them.
Super fine adjustment can be found only in top of the range clocks. Hundreds of hours of craftsmenship are spent to adjust and fine tune them. That's why they cost a fortune.
If you can not live with that early chiming, you have to bring your clock down to the watch/clock repair shop and ask for help. Be ready to pay quite a money, as this job takes the skill and a lot of time.
Rate me, please.
Jul 29, 2009 | Seiko Mantel Clock
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
