Question about Kenmore Elite 45986 Front Load Washer
HF error At the point of the rinse cycle my Kenmore HE3T beeps the H/F signal and will not continue until I hit pause once and restart the machine. There is no water inlet problem but apparently it thinks there is. I fear that one day it won't restart! Any suggestions? Thank-you.
  • 5,911 Answers
The "F/H" error code can be attributed to a number of things.
If NO water is in the washer:
- Check the inlet hoses for kinks or clogs.
- Check the water inlet valve for clogs and clean the inlet screens.
If there IS water in the washer:
- Verify the Drain Pump turns on.
- Verify the Pressure switch hose is in good condition and is connected properly from the tub to the switch. The hose is an air hose that is attached to the wash tub on the right-hand side (facing in from the front - with the lower panel removed) and runs to the pressure switch (located in the rear of the washer on the right-hand side - facing from the front, with the top panel removed). Make sure the hose is attached at both ends and has no leaks.
- Make sure you don't have a siphon problem. This occurs if you place the drain hose into the standpipe at the wall too far. If the drain hose sits in the standpipe in a manner where there is no air gap (i.e., drain hose sitting in the waste trap, or fits too tight at the top to allow air in the pipe) water will start to siphon out of the machine as it fills. This is a common problem.
- Check the flowmeter to see if it is operating properly. The flowmeter is white cylindrical device located near the inlet valve that senses water flow into the washer and tells the presssure switch to cut off. If the flowmeter fails, the pressure switch does not receive the correct input signal and the washer generates an error code.
In a nutshell, check the easy things, first. I would begin with making sure the inlet hoses are not clogged or kinked and the make sure the drain hose is not causing a siphon issue. Then follow the recommended steps mentioned above.
You can place the washer in diagnostics mode for troubleshooting by selecting DRAIN/SPIN, NO/SPIN and then press any button under OPTIONS 4 times (must be the same button). The washer display will change to "C00" and start a series of tests. For a complete list of error codes and diagnostics procedures, look inside the lower panel under the door. There should be a tech sheet somewhere inside the washer that explains all of this in detail.
If it's not a simple hose issue, I suspect you may have a flowmeter problem, or an air hose leaking to the pressure switch. These are the more common problems I have found associated with this error. I hope this helps you. Post back if you have any further questions.
Posted on May 07, 2008
  • apollo11land Sep 06, 2010
    I also have this same error code, and I found this post very helpful.
    Our washer displays this error intermittantly and if you pause it and restart it it keeps filling up with water. It seems like the water flow is fine but the sensor that determins there is sufficient water in the tub is not working. I am assuming that this is the presure switch mentioned in your response but I am having a tough time finding it on the sears site.
    http://www.searspartsdirect.com/partsdir...
Ge adora washing machine beeps when pushing start with door closed
Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal. Post any error codes.
Dec 07, 2012 | GE WSXH208A Front Load Washer
HF signal on a Sears Kenmore He3 washer
i think you need to see this diagram for the repair.
Jul 31, 2008 | Kenmore 44832 Front Load Washer
I have a Kenmore Elite He3. It won't complete any wash cycle without stopping and displaying HF. I can restart it but it continues restarts the wash cycle again. Therefore a Heavy Duty wash cycle of...
Hi
Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hoses as they might be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Aug 31, 2011 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite HE3T washing machine code F11
Kenmore Elite HE3T washing machine error code F28, what does this mean?
Jun 26, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite He3t front load washer - error code reads H & F
the F code is a puwer outige. This is how to fix
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
This is what an HF code is.
"FH" (Water Inlet Problem--no water or insufficient water
supply)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
Dec 15, 2008 | Kenmore Elite 45986 Front Load Washer
I get an F1 error code at the start of the wash & at rinse cycle.
Your Central Control Unit is most likely the problem. It is the main board in the machine behind the control panel and they have been failing a lot. This is a major problem with the Whirlpool Cabrio and the Kenmore Oasis machines. You will most likely need to call a service technician. People have also called whirlpool and complained and got them to pay for the part. I suggest you try battling with them. The part is faulty.
Nov 17, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Elite washing machine won't complete a full cycle
its a error code for not enough water fast enoght or no water. check fill bibs are on and screens inside fill valve are clean if ok . make sure you do not have steel branded flow retrickers fill hoses it if so replace hoses. washer has to get a amount of water fast or it will code out
Nov 11, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
HELP my clothes and sheets are being held hostage !!!!
first unplug the power cord and plug it back.
select drain/spin with no spin after the cycle completed the door will open.
Jul 29, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
368 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
