Question about GE DWSR463EGWW Electric Dryer
The dryer will run for 5 to 7 min then shut off come back in about 3 min it will run then the dryer will do it over and over again untill it will not trurn on
  • GE Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Posted on Aug 29, 2010
Ge adora dryer model dhdvh52ef0ww runs for about 5 minutes then cuts off
Inside the back and the bottom of your dryer are several ( From 2 to 6 ) "overheat thermostat switches".
One of these is doing it's job really well.
These are designed to prevent your dryer from overheating and catching fire.
I suspect one of them is failing, and needs replacement.
Someone handy with electrical testing tools and mechanic's tools need to take it apart and check these to find the "bad" one.
While they have it all apart, it should need a really good cleaning inside.
Be blessed.
Mar 22, 2013 | Dryers
Dryer runs for 10 mins and shuts off.
Your dryer motor has a thermal overload built in to it. If your symptom is shutting down allow to cool and it works again for a few minutes the shuts down again.
http://www.on-timeappliance.com/dryerrepair.html
Mar 28, 2012 | Frigidaire Dryers
Whirlpool ler7646EQI Dryer runs for 5-10 seconds
sounds like u have a bad overheat sensor on the back on the electric strip housing and on fan housing they are round they are very cheap just take them off and replace both of them and that should fix your problem
Feb 25, 2010 | Whirlpool LER4634J Electric Dryer
Maytag mdg6700aww gas dryer runs but heat kicks out after 5 min
You have bad coils on your main gas valve . They tend to short (open) after getting warm which cuts off the gas to the burner . After cooling , they will work again for another 5 min until shorting again . Replace the coils (2 in a kit ).
Jul 12, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer heat turns off after about 5 min- dyer will remain running but no heat
HI, After the heat shuts down, do you hear a click like it is trying to heat again but then get no flame. The most some problem is the coils on the gas valve go bad and will not reopen after they have heated up.
Remove the cap on the front lower left panel. After dryer has ran and heat shuts down, watch and se if the ignitor glows again (you will hear a click) and the ignitor shuts off before a flame. If this happens, change the coils on th gas valve.
Here is instruction: Normal 0 UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
Jun 01, 2009 | Dryers
Loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
Apr 10, 2009 | Kenmore 62602 Electric Dryer
Dryer shuts down within 5 mins of running
your vent is plugged up move dryer away from wall and allow room for vent
Mar 25, 2009 | Whirlpool Dryers
GE DWSR463EGWW Electric Dryer Logo
119 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
