Question about Refrigerators
I need a Beater for a Model 162-12 Taylor soft Serve Machine. The Taylor part number is X24689. Thanks, Jeff
SOURCE: Taylor 770 soft serve
press reset button very hard (the red one)
Posted on Aug 05, 2008
  • 2976 Answers
SOURCE: vanilla ice cream tends to turn brown!
Tou probably have an area that wasn't properly cleaned. Everything is stainless so, it can't be rust. Check for missing seals at the ends of the dasher.
Posted on Jul 07, 2009
  • 3 Answers
SOURCE: Taylor Y754-27 Soft Serve Ice cream machine
gearbox is sealed, I've never replaced one.check belts could be too tight, does it scream when you start it. check bearing at end of barrel sharp edge means needs replacing. check temperature of product disspensed on loud side could be too cold. adjust on board or needs new probe, inexpensive but a ***** to install.
Posted on Jan 21, 2010
  • 1144 Answers
SOURCE: Beater stuck in Taylor Ice Cream Machine Model Number 168-27
these units are usually set up to have the beater rotate in a clockwise direction facing front. If they get stuck, it is usually due to excessive wear or the hexed end has been lubed and has created a suction seal in it's counter part. Try rotating the beater in a counter clockwise direction while holding the drive wheel pulley stationary. Be sure to unplug unit first. this has worked for me in the past but can be very difficult at times.
Posted on Feb 21, 2010
  • 1144 Answers
SOURCE: need to know how to clean the taylor soft serve
http://www.taylor-company.com/
go to this web site and just click on operators manuals. Then either enter your model number or you can use the drop down menu.
Posted on Aug 12, 2010
Beater overload on one side
turn the power off and hit the reset buttons about the size of a quarter hole on the back or front panels. turn back on and it should clear if not then you will need to have the beater motor or contactor replaced.
Oct 08, 2014 | Taylor 2008 C713-27 Soft Serve Ice Cream...
I have a Taylor 794 soft serve machine. The left side is too soft.
Viscosity adjustments should not have to be made frequently on these machines. If you change products a lot, such as flavors of yogurt, minor adjustments may be required. If your machine uses 3 phase electricity and it machine has been moved or any electrical work performed you may want to check the beater rotation, the beater should rotate clockwise inside the barrel viewing from the front, if you look at the gear box from the back, the pulley should be turning clockwise as well. Otherwise, there is a fine tuning potentiometer on the control, you must remove the front cover to see it. Clockwise is colder/thicker. I recommend small adjustments. It is best to read the amp draw on the motor to see what type of amps it is drawing. If your mix is soft and your motor is drawing 4 amps, you may have another type of problem such as a bad motor. The board and control can also fail giving these problems. There are many things to check in addition to these. Hope this will help you get started.
Apr 05, 2013 | Taylor Ice Cream Makers
I need pice from 339-27 ice cream mashin
Dear friend, Well if you are planning to buy an ice-cream machine.i can provide you a few links.
for 339-27 ice cream mashin 1)http://shop.ebay.com/sis.html?_nkw=TAYLOR+339+27+SOFT+SERVE+ICE+CREAM+MACHINE+AIR+COOLED
2)wvw.lucantoniblanz.tk/taylor-339-27-ice-cream-machine
3)http://www.fashioninpassion.com/index.php?jeans=simac+il+gelataio&pj=67167
Price:$2392.0 - Taylor Soft Serve Ice Cream Machine Model 339-27 for the 3rd website
the cost is ranging from $1,995.00 to $7,500.00 (cost on ebay.com)
the below link will guide you in a more better way.
http://shop.ebay.com/sis.html?_nkw=Taylor+754+33+Soft+Serve+Ice+Cream+Machine+Air+Cooled
Buy It Nowor Best Offer $7,500.00
Jul 31, 2011 | Taylor 632-27 Ice Cream Maker
Taylor soft serve ice cream machine model #y754-27
I have a gearbox,coupler,pulley etc. pulled off a y754-27
Jer 805-925-5556
Sep 30, 2008 | Taylor 632-33 Ice Cream Maker
754-27 Taylor soft serve machine Beater motor not running - compressor not engaging - Power to beater relay but not out of relay.
May 18, 2008 | Ice Cream Makers
Refrigerators Logo
79 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
