Question about Acer Computers & Internet
Remove my keyboard acer aspire one - Acer Computers & Internet
  • 244 Answers
SOURCE: acer aspire 5610 keyboard replacement
1. you need to remove the power cover (if you see the power button, that what i mean).
2. after you remove that cover, you will see 2 screw that hold the keyboard. Remove both screws.
3. Remove keyboard and replace it with new keyboard.
Posted on May 08, 2008
  • 244 Answers
SOURCE: Acer Aspire 1640z keyboard removal
I don't have the diagram but i can give you direction.
1. remove the power cover first (where power button is), it might have 3 screw that hold, if there is 3 screw on the power cover, remove it first.
2. after your removed the power cover, you can see the screw that hold keyboard. remove that screw and you can remove the keyboard.
Posted on Aug 04, 2008
EmotionLess
  • 52 Answers
SOURCE: Keyboard removal Acer aspire 8920g
To take the keys off, gently pull up on the top side of the keys until they snap off. Just push them down again and they'll snap back on.
Posted on Mar 21, 2009
SOURCE: Keyboard broken on my Acer Aspire 5520
For the Acer Aspire 5520 I'm working on, (Acer Aspire 5520-5156, mode nol: ICW50)
Remove the three black screws under the battery, not the silver screws.
VERY carefuly pry off the power button cover. It will make 'snapping' sounds and if you where gentle nothing will be broken.
The keyboard has no screws holding it and can be slid toward the screen and very gently pryed out, taking care not to tear the ribbon cable, as mentioned before.
When the keyboard is out the cable can be released by gently pulling the cable lock on the header toward the cable, the thin (black in this case, it's usualy a different color than the white connector) plastic part of the connector I just use my fingernails, one index finger on each end slowly pulling till it releases.
Pull the cable out using the pull tab. You can just pull the flat cable out with the pull tab without releasing the calbe lock but you stil need to release the cable lock to properly put in the new cable, then push the cable lock back tight to the connector.
Posted on Aug 14, 2009
lock123
  • 6831 Answers
SOURCE: how do I remove the keyboard on acer aspire netbook
Hello
I found this Video where you get exact instructions on how to remove the keyboard. Just click on the link and you will be directed to the video link. Hope this can help you.
http://www.youtube.com/watch?v=FoTwln2SyQ4
Kind regards
Andrea
Posted on Nov 17, 2009
Testimonial: "Thanks! That is exactly what I needed !"
How do I remove acer aspire 9810 keyboard,I have removed the base cover and screen assembly but I cant fugure out how to remove the keyboard Thanks in advance Peter
to remove the keyboard, remove the screws at the back of your laptop. Then remove the Hard drive, then remove the Optical drive then remove the video card, and then power supply. Then remove the fan from the motherboard and you may remove the screws on top of the keyboard. Finally you may replace the keyboard.
Jul 15, 2010 | Acer Aspire 9810 Notebook
How do I replace Acer Aspire 5610z laptop keyboard-instructions
Below is an illustrated guide to the service manual and disassembly of the laptop. Illustrations start on page 57, browse through the pages and you will see the illustrated guide to removal of the keyboard.
http://tim.id.au/laptops/acer/aspire%205610%20travelmate%204200.pdf
Jan 10, 2010 | Acer 91.63X07.001 Keyboard
How do I remove the keyboard on acer aspire netbook
Hello
Kind regards
Andrea
Nov 17, 2009 | Acer Aspire One Netbook 8.9" Notebook
I need to replace the keyboard on an Acer Aspire 3680 series laptop
Hi there.
Remove the laptop battery and the AC power supply, open the lid as far back as you can take it.
Get a small flat headed screwdriver, now, you have to take off the keyboard bezel, this is the strip of plastic above the keyboard with the power button on it, the best way to remove it is to start by the on/off button by gently prying the bezel up from the lid hinge, once you have one side out gently pull it up using your fingers, it will unclip and lift away.
Next you have to remove 2 screws from the top of the keyboard, these should be visible to you, once the screws are out carefully lift the keyboard up, you will see a ribbon cable that is connected to the motherboard, gently pull the tab up on the connector that the ribbon cable sits in and it should release it and you can now remove the keyboard and replace it.
To re-assemble just follow my direction in reverse.
Please post back with the results and for any additional advice if needed.
Good luck and thanks for using FixYa!!
May 22, 2009 | Acer Computers & Internet
''NEED TO REMOVE THE KEYBOARD ON A ACER ASPIRE 3680 2233''
Remove the screws on the both hinge,be carefull when you revove the keyboard backwards, its all plastic and verry verry easy to breake.
Nic
Mar 12, 2009 | Acer Aspire 3680 Laptop
Acer aspire 3000
HERE is a link to the repair guide for the Acer Aspire 9410. With this, you should be able to find the correct method or removing the original keyboard and replacing it. If you have a replacement from Acer, you should have been given instructions on how to replace it manually.
Dec 20, 2008 | Acer Aspire 9410 Notebook
Instructions for acer aspire keyboard replacement
first of all, remove the power connector and the battery before u do anything on that laptop.
remove the 3 screws in the middle cover. remove that middlecover by putting a screwdriver in one of those holes which are covering the displaybrackets. pull it up slowly. same thing goes for the opposite side.
there you go smile.gif remove the 2 screws which are holding the keyboard and the cable to the mainboard.
Dec 15, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Jul 30, 2008 | Acer Aspire 1640Z Notebook
Computers & Internet Logo
217 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
