Question about Sanyo HT32744 32" TV
Blurry Picture Picture fine sometimes, maybe for a few months with no problem, then gets blurry RGB all run together. The set will work fine for a few days/hrs/min and then the problem starts again for a few months. Sometimes I'll cut it off and back on and its ok. Sanyo has offered some assistance, even though the warranty has expired, but have no way of getting this 150lb. set to the location. Purchased set from Wal-Mart about 3yrs ago, problem started about 1 1/2 yrs. after. Please help.
  • hkmp5ka3 May 15, 2008
    jjazzy, did sanyo tell you what may be the cause of the problem? I have the same tv and the same problem as you.
    Problem Solver:
  • 11 Answers
I too had the same problem where my HT30744 TV would lose its color or picture would get blurry. My mom's HT32744 would have the same problem too. They both are refurbished models bought at Value City Dept store. If I gave the cabinet a good hit it would mostly fix the color, but it could also make the picture go fuzzy too, a clear sign of just a loose connection somewhere.
So after my wife telling me she was sick of this almost 2 year problem and she was going to buy a new TV on the weekend, I figured I had nothing to lose. So I took the rear cabinet off, unseated the card mounted on the picture tube, applied a little dielectric grease on the connector on the card and reseated the card, removed, re-greased and reattached the card. I have had no problem with either my or mom's which I did the same to since! This is an easy fix that anyone can do. The hardest part is moving the TV and reassembling the rear cabinet. Do not pull the cabinet back out more than you have to, to ease the reassembly of it.
Posted on Mar 05, 2010
    Champion:
  • 252 Answers
Your problem is a CRT socket .it is a white plastic with 7 or 9 pins that attach to the picture tube,change that socket
Posted on Oct 16, 2008
Blurry picture if zoom is used ( no Sharp mage)
I'm out of practice because my camera suddenly stopped working 6 months ago, but I don't recall having a problem with blurry pictures when I used the zoom. Sometimes, it takes a few seconds for a pic to come into clear focus. I think the trick is to just keep working with it.
Jun 20, 2014 | Canon PowerShot SX100 IS Digital Camera
Lines and blurry screen
hi, sounds like u need some solder joints re-worked (probably quite a few for a set that old, but your right it`s a great set), price varies by region greatly, I`m in central florida we would charge 75 for service call & 95-125.00 for labor depending on how long it takes to do the solder rework, hope this answers your question, get it fixed it`s waaay better than the new hd (ha ha ha) sets, video-tek
Jun 02, 2009 | Hitachi Televison & Video
SONY rear projection TV KP61HS10 picture blurry, hazy
Issue is with main tuner since you have two of them. At least the tv is ok but that tuner is fubar.
Sep 07, 2017 | Sony KP-61HS10 61" Rear Projection...
Sony rear projestion TV has blurry picture.
sounds as if your convergence needs to be set. either through the menu on the tv or remote you need to get to the convergence set screen and you need to line up the crosshairs. this usually happens when the tv is moved or bumped.
Dec 31, 2008 | Televison & Video
Picture Quality
A blue tint would be the color balance in the white balance settings in the menu. Go set the white balance to "Auto" if he pictures are blurry, you could have dirty lens. Take a q tip and wipe it down without and solution to it. Otherwise you could have faced a possible impact damage. Was the camera dropped,bumped, or knocked around. This can be fixed. I recommend sending it to the camera doctor.
http://www.cameradr.com/
He can fix it faster and cheaper than the manufacture. Impact damage is not covered by warrantys.
Nate
Dec 17, 2008 | Nikon Coolpix S51c Digital Camera
Blurry image!
There is a ring around the lens that you have to physically turn to focus it.
Dec 06, 2008 | Microsoft LifeCam VX-3000 Web Camera
Blurry picture
1)Remove rear cover = clean RGB lens with soft cloth
2)Remove front speaker grill cover and access panel
Locate screen / focus block = adjust RGB focus controls
3)Last,if needed, unlock each focus lens cap = adjust then lock
................................................T.
Dec 01, 2007 | Sony KP-51HW40 51" Rear Projection...
My camera is blurry..and it takes blurry pictures..How can i fix this?
Gently clean the lens or get it cleaned at a camera store. I suspect fingerprints on the glass. If this isn't it, the camera's infrared sensor may be malfuntioning or dirty, or the lens assembly is not functioning properly (warranty).
Sep 13, 2007 | Samsung Digimax D53 Digital Camera
Blurry Screen
ok your problem is the RGB section maybe crack soldered at the RGB try to resoldered it! you seen that at the back of the picture tube they have small board attach at the neck... resoldred all small part, and transistor drivers!!!
Nov 13, 2006 | Jensen TS2750J TV
Sanyo HT32744 32" TV Logo
250 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
