Question about Brother Office Equipment & Supplies
We had a recent power outage for approximately 5 hours. When the power came back on, I started typing again on my BROTHER SX-4000 typewriter. What I was typing was not was being printed on the paper. I pressed the reset button, and began again. Still no luck! I turned the power off and unplugged the machine for about an hour. Plugged it back in and turned it back on. Still no luck! Hit the view button. What was being viewed was correct, but still no luck in printing the correct printing. Help!!??
  • Brother Master
  • 3,594 Answers
The P/W homing pawl is probably broken, you need a tech.
DickyO
Posted on Sep 01, 2010
I am having a problem with the sx-4000 typewriter. Every key that I hit on the typewriter is not typing correctly. What do I need to do to fix this?
Printwheel in wrong. release the printwheel, make sure the pin is aligned with the slot on the hub and snap it back in. The printwheel should spin, then home out to the left margin, then it should be ok. If not try it again.Check to make sure no pedals on the printwheel are bent.
Hopes this helps!
Mar 02, 2011 | Brother SX-4000 Typewriter
I have a brothers sx-4000 typewriter, i recently bought new ink ribbon. But for some reason my typewriter still does not print the letters at all. I know my typewriter is still good, I dont know why it...
There are two things that people mess up when changing printwheels and ribbons. Is that the ribbon is not in the guides properly. The other is that the latch the holds the type wheel is not locked in the forward position.
Nov 26, 2010 | Brother SX-4000 Typewriter
How can I change the margins? for Brother SX-4000
Move carrier with the backspace or the spacebar.
Press and HOLD [ALT] while pressing the [4/$] key.
The left margin is now set.
Press and HOLD [ALT] while pressing the [5/%] key.
The right margin is now set.
Hope it helps
Oct 06, 2009 | Brother SX-4000 Typewriter
SX 4000 Brother Electric Typewriter
With power off, remove the ribbon and look down inside the carriage assembly on the right hand side. Look close and you will see a white gear, you rotate that gear, either way about 1/2 a revolution. Power on and try typing, if it works you can put in the ribbon and go, if not, rotate the gear somr more.
Aug 27, 2009 | Brother SX-4000 Typewriter
The roller spins freely on my brother sx-4000 typewriter
Did you recently remove the daisy wheel cartridge? If you did... did you remember to slide the lever on the right hand side do the cartridge carrier back into its original position to lock the cassetted daisy wheel in place? Remember...make sure to press the lever firmly.
Close the top cover.
Press [CODE] + [RESET] at the same time to moe hte carrier to the previous position.
Apr 04, 2009 | Brother SX-4000 Typewriter
24 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
