Question about Lexmark JetPrinter Z25 InkJet Color Printer
Lex z25 not printing
Hi, I have a lex Z25 nota all in one. it ran out of ink and after installing new cartridges it goes thru the motions bit no ink is showing up on the pages
  • 2 more comments
  • pecandeb Jun 02, 2008
    how do you tell if you have ink in your cartridge
  • angel poo Jun 08, 2008
    I installed new cartridges and the printer goes through the motions, but no test appears. It seems the ink is not coming out and so does not appear on the page at all.
    Any solutions????
  • ghel0808 Jun 26, 2008
    we tried to install lexmark Z25 to HP desktop PC and we successfully did but the problem is that when we try to print a document it won't print at all, the paper came out blank although the cartridge is new.. any solution for this?
  • ellyjo May 26, 2009
    Although I installed 2 new Lexmark cartridges, the printer notes that the two cartridges are empty. When I click on the printer (Copy), the cartridges appear to be full.
    Still the printer is not working, it says there's no communication.
    Help! What to do?
Mine wasn't printing at all, but now its printing color. I still don't know why it won't print black, but what I did was go into the control panel, I clicked on printers and faxes found the Z25 and right clicked it. I then clicked on properties, I clicked on the advanced tab, went down to the bottom of that section and clicked printing defaults, that opened the window for the properties for the printer. Once there I clicked on options in the top right corner and clicked on Lexmark Z25-Z35 Solution Center. On the maintenance tab I clicked "Clean to fix horizontal streaks", it takes to you a pop-up that says "Clean and Test Nozzles" a page will start printing to show if you have broken lines or unbroken lines when you print, either way it should clear your nozzles enough for the ink to start coming out again. If you need to repeat it the "Clean and Test Nozzles" pop-up had a box that says "clean again. Once you are done with that you can close the pop-up. If that doesn't solve the problem there are other things to try on the maintenance page besides the "Clean to fix horizontal streaks". Hope it starts working for y'all too. I still have to figure out the black part.
Posted on Jul 16, 2008
I lost my lexmark z25 cd and i now have window 7 on my pc
The lexmark z25 printer does not require any drivers to run on windows 7, they are available automatically as part of the operating system.
All you need to do is plug it in and it will install the required software!
http://www.microsoft.com/windows/compatibility/Windows-7/en-us/Details.aspx?type=Hardware&p=Lexmark%20Z25%20Inkjet%20Printer&v=Lexmark&uid=15J0070&pf=3&pi=2&c=Printers%20%26%20Scanners&sc=Ink-Jet%20Printers&os=32-bit
Regards,
sjstore2
Dec 18, 2010 | Lexmark JetPrinter Z25 InkJet Color...
My Lexmark Z25 has been packed away for a few years. I have new cartridges but, the pages still print blank. It makes all the noises like it is printing but, nothing. Can't find original software for...
The blank pages is normally due to dried ink in the print head nozzles. Even by replacing the cartridges, the blockage remain.
You can clean the print head with some wet lint less (camera lens) paper soaked in iso-propyl alcohol.
If the blockage is wet, running a cleaning cycle a few times will normally remove the blockage after doing the above steps.
Feb 28, 2010 | Lexmark JetPrinter Z25 InkJet Color...
Hi. I've just updated my Lexmark driver for uor
If there are no error messages, it sounds like you have some clogged nozzles caused by the lower quality of ink in refilled or aftermarket cartridges. There cartridge inks may not be up to specification. This is especially true for the ultra fine printers.
To clear the problem you need to insert an OEM cartridge, run the deep nozzle cleaning utiliity at least twice followed by the alignment utility. This should clear up the problem. .
Let me know if this solves your problem otherwise we can explore other solutiions. For the record, which operating system are you using?
Please rate this solution. Thanks.
Oct 05, 2009 | Lexmark JetPrinter Z25 InkJet Color...
Lexmark z25 printer light keeps blinking, will not print
Have you used this printer before? Is it new? The flashing green light means that the ink cartridge needs to be replaced. Make sure you have the ink cartridge in correctly and seated down completely. Otherwise, it may be a defective ink cartridge.
Mar 29, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
Cant install my priner lexmark z25
I'm afraid you're out of luck. Your printer is so old that Lexmark didn't release a Vista driver for it.
Here is the driver page for the Z25. Notice in the OS selection box it stops with XP. So your only choice is to buy a new printer or go back to XP. The cheapest printer I could find on their site is the Z1300, which is only $29, less than the cost of one ink cartridge. There is a Vista driver available for it.
Aug 07, 2008 | Lexmark JetPrinter Z25 InkJet Color...
Lexmark z25
cheat settings see if u have print coler in black only in printer settings ok
Feb 03, 2008 | Lexmark JetPrinter Z25 InkJet Color...
Lexmark z25 drivers for windows vista
Unfortunately, the Z25 isn't supported by Vista.
Jan 11, 2008 | Lexmark JetPrinter Z25 InkJet Color...
Lex-Z25 Blank Pages
need to install my Lexmark Z25 to my laptop.recently upgraded to windows XP
Jan 05, 2008 | Lexmark JetPrinter Z25 InkJet Color...
hi!
i followed this one:
"I was only able to print by doing the following change on Control Panel.
1. Lexmark Z25 printer Properties
2. Ports tab
3. Select USB00x instead of LPT1"
and it worked!!! problem solved for lexmark z35. ü
Nov 21, 2007 | Lexmark JetPrinter Z25 InkJet Color...
Lexmark JetPrinter Z25 InkJet Color Printer Logo
139 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
