Question about Refrigerators
Water accumilating at bottom of freezer compartment.
  • Refrigerators Master
  • 43,501 Answers
Here is a tip that I wrote about how to fix your freezer so that the drain hole does not keep freezing up.
Water Running in Refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
Water on floor - french door refrigerator with freezer below
Yes the bottom compartment does have a drain opening but to see it you will need to remove the rear panel covering the evaporator inside the back wall of the freezer compartment. See item location number 11 on page 3 of the parts list. That will need to be removed so you can reach the drain inside the freezer compartment. The fresh food section also has a drain. Here is a=> AFF2534FEB4 Parts List and AFF2534FEB4 User Manual I am here to answer any questions you may have, Thanks Sea Breeze
Leaking Refrigerators
Jul 23, 2013 | Whirlpool Amana Refrigerator Water Filter...
Howling noise in HSS25GFP
I can only tell you of my experience when my freezer/Refrigerator made those similar sounds. I pulled it out from the wall and saw some dust accumilation so I took the bottom access panel off to the fan and compressor compartment. It had a lot of lint like dust accumilation so I cleaned it. I actually took my air compressor and blew it out.Made a little mess but nothing vacuum cleaner couldn't handle. Anyway it helped a heap. It's like any refrigerant device. The filter needs cleaning. Not sure it will help with your problem but it did mine.
Dec 21, 2011 | Hotpoint HSS25GFP Side by Side...
Water accumilates in the bottom of the freezer in the morning there is a thin sheet of ice on the bottom of the freezer
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 20, 2010 | Maytag MFI2266AES Stainless Steel Bottom...
Ice accumilation at bottom of upright freezer
i could be wrong, but, look along the bottom of the door to see if the seal is tight to the frame......if there is an air gap it is causing the floor to freeze the cold air....
Jun 04, 2010 | Woods Upright Freezer MU07W
Formation of ice in freezer compartment
heatman101
Sep 05, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Water accumilates in bottom well than leaks out onto floor???
if this is a side by side your defrost drain is froze shut thaw it out with hot water and make sure when you poor water down it runs to the pan underneath the fridge and adjust the freezer temp to 4 degrees above 0
Aug 09, 2009 | Refrigerators
Water weeping out vents in lower back of freezer compartment
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
heatman101
Jun 29, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice accumilation next to fan in freezer compartment
u have a defrost problem need to replace heater and tstat
Mar 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
14 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
