Question about Braun 360° Complete Electric Shaver
I replaced the cleaning liqud cartridge but it shows the red light indicating it is empty.
  • 577 Answers
here is the solution..follow the steps please..
Thanks in advance for rating me..Regards
  • Replace the cartridge in the base station and close it.
  • The indicator light should cycle then change to green. If it doesn't then unplug the base station, wait a few seconds, then plug it back in.
  • Press the lock button to clean the shaver. If everything went well it should start cleaning like normal.
    Posted on Oct 23, 2010
    MY EPSOM CX 5500 WILL NOT PRINT. i HAVE A RED LIGHT PERM ON BY THE INK ICON. i HAVE TAKEN OUT THE CARTRIDGES SEVERAL TIMES AND RESTARTED BUT NOTHING HAPPENS. tHE CARTRIDGES HAVE INK AS FAR AS i...
    Hello, This happens with epson as it has a chip on the cartridge, which sometimes shows the cartridge empty even if there is some ink left on it. You can try this steps:- 1. With the printer turned on press the ink replace button, which will bring the print head to ink replacement position, pull out the cartridges one by one and cover the tip of the cartridge with some tape and shake the cartridges and reinsert it on the printer and press the ink replacement button once again, the printer will check the inks cartridges, if the inks is empty it will show the red light again, pressing the button once will bring the printer to ink replacement position with the cartridge to be replaced on the replacement position. you can also check on the printer software on the pc that which ink cartridge is emptied.
    Hope this helps.
    May 14, 2011 | Epson CX4400/CX5600
    I have cleaned the print heads, replaced cartridges and still can't get text to print. Any idea?
    If you have a a solid red light showing you will not get any printing done. On the epson printer which red light is showing? Is it the one for the black or the color? Was that cartridge replaced by you? I have actually seen one cartridge's red light glowing and so replace the cartridge. Then the printer goes through a charging sequence and to my surprise another red light is showing, but this time it's the other cartridge, because the printer was already low on that color and the charging cycle emptied that cartridge enough to trigger the light to start blinking on and off. Now suppose it's the same light that is still on even after you replaced the cartridge. Do this: hold the paper in feed button for about 3 seconds. The printhead will move to the left. Lift up the clamp of the cartridge that
    has the red light glowing and bring it down somewhat definitively again to lock the cartridge down. There is a microswitch that is reset when this is done that tells the printer it has a new cartridge installed. Sometimes when a cartridge is replaced the switch is not reset if the clamping process is not definitive enough, or it simply needs to be done again. When you've done this push the paper infeed button again to move the head back to park postition.
    Good luck,
    Jan 05, 2011 | Epson CX4200 All-In-One PSC Printer
    I've lost my manual. Does the red light that
    The red light that looks like an empty cylinder on the Sharp AL 1631 Grayscale Copier panel is the "drum replacement required" indicator. The "cartridge replacement" indicator is represented by 6 dots forming a triangular shape.
    The drum replacement indicator lights up when there are about 1000 copies left until its end of life. It is only when the indicator starts blinking that the drum really needs replacement.
    The part number for the drum is AL-100DR.
    I hope this helps.
    Nov 19, 2009 | Sharp AL 1631 Copier
    Ink light of my tx101 keeps blinking
    Hello, Amit.
    From FixYa, give this a try:
    Lift up the scanner bed (top part) of the printer to expose the cartridges.
    Push the red triangle button once. Wait for the cartridge carrier to move to the middle. On the housing of the printer (the non-moving part), there is an arrow that will point to the empty cartridge.
    Push the red triangle button again to see if the next cartridge is empty. Repeat this step, noting which cartridges are empty, until the cartridge carrier moves to the right. Now you can replace each cartridge that is empty.
    After replacing the empty cartridges, push the red triangle button again, and the carrier will begin moving back and forth (cleaning itself). Once it stops, it should be positioned on the far right side.
    Lower the scanner bed to "close" the printer. The ink light should go off and you should be able to print.
    Hope this helps.
    Oct 04, 2009 | Epson Stylus Multifunction Inkjet Printer/...
    Cyan Cartridge not working
    Show empty or not recognized (cross sign)? Check connector at chip and at head carriage. Do replacement procedure form status monitor (how to..). Do replacement ink tank one by one with cyan ink first.
    Jul 25, 2009 | Epson Stylus RX425 Multifunction...
    Overiding Empty Cartridge error for Dell A10 962
    maybe it have the ink level chip which can be resetted by removing the cartridge and oning and offing the printer for 5 times within 10 minutes coz it saves data of a cartridge upto 5 use before only.. and 6th time insert it.
    Nov 15, 2008 | Dell 962 Photo All-In-One InkJet Printer
    Doesn't recognise new cartridge
    did you clean and re calibrate those print heads?
    Mar 10, 2008 | HP Inkjet 1200dn Printer
    Red flashing light on '8BK' small black cartridge on left hand side.
    If this indicates 'low ink' then it is not alerting me on the monitor. I think this is something different because my printing has been interrupted. Aileen
    Dec 13, 2007 | Office Equipment & Supplies
    Braun 360° Complete Electric Shaver Logo
    583 people viewed this question
    Top Braun Health & Beauty Experts
    shaveroutlet.com
    shaveroutlet.com
    Gary
    Gary
    Kazim ERGUNEY
    Kazim ERGUNEY
    Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
