Question about Whirlpool MT9160XE Microwave Oven
I push start & the microwave doesn't do anything.
  • ncfosc19 Aug 27, 2010
    The keyboard seems to work. The clock works and can be reset. When you put in for it to cook for 30 seconds and push start the time clicks off
  • 2,382 Answers
You have a failed membrane keypad.
On this model, the keypad is not available as a separate part, so you would need to order a new control panel frame assembly, which comes with a new keypad already mounted on it.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
Posted on Aug 27, 2010
  • Tunde Autos
    Tunde Autos Aug 27, 2010
    Then if the keyboard works, what is the problem? Please explain....
It shut off as soon I push start on my new wave oven
Have you tried in in a different outlet??? Maybe too many things on the same breaker and it tripped??? Most microaves will draw about 12-13 amps, so depending on what size breaker you have it on you may not be able to have anything else on the same circuit.
Sep 28, 2017 | Microwave Ovens
Sharp r-509fw Keypad problem?
You need to replace the control panel, the panel is all one piece buttons and all.
Jun 10, 2017 | Sharp R-520KS Microwave Oven
Bosch combination oven/microwave HMG 8220GB start button doesn't work
This is a door switch problem, one of the door switches has malfunctioned preventing the microwave oven from running.
May 14, 2012 | Bosch Microwave Ovens
Electrical short /pop sound & now it doesn't heat. Everything else works. Any idea what went out.
The signs are not always evident, but from the description the magnetron has failed.
Apr 13, 2012 | Sharp R-1491 Microwave Oven
Microwave lights up doesn't turn on
The part of the oven called the "magnetron" (this part is what creates/generates the microwave energy that heats the food or liquid) is burned out, the cost to repair is more this part is more than the cost to replace with the cost of Microwaves so depressed by the stagnant economy.
Jan 31, 2012 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
Galanz Microwave Model WP1000AL30 doesn't go on when the item buttons are pushed?
Does microvave button makes sound and when you start push button does the turn table moves.If yes for sound ,and no for turn table then you might have door switch which is either doesent latching or might broke.
open oven (be sure to discharge capacitors).
check its closing properly(the switch)
and use DMM to check resistance that it doesn't show OL
thanks
please rate my work
Sep 20, 2011 | Microwave Ovens
Frigidaire FM156DSB 950w #7G63610032 light and timer works but microwave will not come on. When you push start it just clicks and does nothing. You can push up on the door from the bottom and microwave...
I have the same problem with ours! The light will come like it should but the microwave will not start until we hit the upper part of the door handle. Any advice?
Jan 21, 2011 | Microwave Ovens
After push START bottom,fuse has over current & fuse damaged
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
May 25, 2010 | DeLonghi MW 535 Microwave Oven
Whirlpool MT9160XE Microwave Oven Logo
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
