Question about Nelson Sprinkler: Traveling Tractor
I have a Nelson traveling tractor and the shutoff button housing is cracked and sprays water out. Do I have to replace the whole box or can I replace just the bottom part that has the water shut off button?
  • 43,501 Answers
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
Posted on May 19, 2011
Brand new nelson tractor sprinkler runs for about 20 minutes and then stops. water pressure is fine
Too heavy a hose can cause this (after 20 minutes, there's just too much hose behind the sprinkler to drag any further).
If the unit shuts off entirely, the sprinkler could be hitting the top of the hose (wheels digging into soft soil) and tripping the auto shutoff under the unit. (Mine does this every once in a while).
Apr 11, 2012 | Nelson Sprinkler: Traveling Tractor
Our Nelson tractor sprinkler is going backwards! How do we correct this?
You need to aim the rotary arms in the opposite direction. If the spray pattern is spinning clockwise, then you need to make it spin counter-clockwise or vice-versa. You do this by adjusting each of the 2 arms 180 degrees so that the jet stream spurts right instead of left (or left instead of right). Remember, the spray arms are connected to a gear box, and the gear box turns the wheels. Your wheels are moving in the wrong direction because the gears are moving in the wrong direction because the spray arms are spinning in the wrong direction because they are aimed in the wrong direction.
Jul 20, 2011 | Nelson Sprinkler: Traveling Tractor
My 9 year old Nelson raintrain leaks (gushes) water out of transmission housing (at about a rate of 50%) Sprinkler will still operate but at a considerably reduced rate.
not knowing that model,, look for a gasket that can be replaced, if not, the case itself has probably cracked, a local welding shop may be able to repair the crack.
Jul 10, 2011 | Nelson Sprinkler: Traveling Tractor
Our raintrain has worked for years....but now it is leaking out of the bottom causing it to get stuck often......please help us!!!!
I think your valve is shot. There is a button underneath that is pushed up by the ramp. It then closes the valve. The valve is leaking and lowering your water pressure causing your sprinkler to get stuck.
You could replace the valve but that requires disassembly of the gear box. The gears inside may be worn too so, I am suggesting that you just replace the gear box. Replacing the gear box will give you all new moving (and sealing) parts. This web site has a box for about 1/2 to 1/4 the price of a new sprinkler.
http://www.sprinklersupplies4less.com/traveling-sprinklers-nelson-1865-replacement-parts-c-384_627.html
Jul 08, 2011 | Nelson Sprinkler: Traveling Tractor
I have a Nelson traveling tractor for at least 12 years, now. No problem until this week. While traveling tractor was watering yard it turned over in some softer sand - which it has done previously - and...
I think that you need a new gear box. Your unit is 12 years old and the valve inside (the box) probably became separated from the "button" you pull down. Getting a new valve would solve your problem but, it would have to be installed inside the gear box. Since the gears may be worn (after 12 years) - I recommend a new gear box. This would solve your problem and prevent future "worn out" problems. This also saves you assembly of small parts.
Jun 23, 2011 | Nelson Sprinkler: Traveling Tractor
My rain train will not spin and travel consistantly. Water will come out of the spouts, but it will often just sit there and spray water in the same place - not spinning or traveling. I have lubricated...
You will need to boost your water pressure... it needs 40-60 PSI to work correctly...
heatman101
Mar 23, 2011 | Nelson LR Rain Train Traveling Sprinkler...
Need a new water shutoff defice
heatman101
Aug 27, 2010 | Nelson Sprinkler: Traveling Tractor
Housing crack
Go to auto parts store and get some JB Weld epoxy. Read directions...mix some up...it will fix your crack.
Aug 17, 2010 | Nelson Sprinkler: Traveling Tractor
I have a couple of Nelson tractors. Is water supposed to come out of the little holes on the bottom of the gear housing?
heatman101
Aug 12, 2010 | Nelson Sprinkler: Traveling Tractor
Nelson Sprinkler:  Traveling Tractor Logo
142 people viewed this question
Top Nelson Garden Experts
Dennis
Mike Squire
Phil Walker
Phil Walker
Are you a Nelson Garden Expert? Answer questions, earn points and help others
