Question about HP LaserJet 1020 Printer
I just refilled my toner, but problem is , it still doesn't want to print anything! It prints a weird "watermark" all along the left side of the page... and nothing else! HELP!
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
You have bud quility of toner in the cartridge
check here how to refill with no need of special tools
I just refilled my toner, - utube.png You-Tube video "iMiTopIVMxM" placeholder (do not delete) utube.png
Posted on Oct 29, 2010
Black dots are printing on the left hand side of the page when I print from my hp laserjet 1015. Any ideas how to fix this?
Run a "half test". Put paper in the manual feed tray. Print anything. Watch the paper, when it feeds about 1/2 way into the printer, open the cover. Pull out the toner and look down at the paper. If it has the dots, replace the toner. If it doesn't have dots, the fuser is probably bad.
Aug 31, 2011 | HP LaserJet 1018 Printer
Tip
Why i get black streaks on paper in laser printer prints?
there are some possibilities for this problem. i will explain it. 1) First of all check out if the toner is full ,half or near to empty. There is no exact procedure to check the powder left in the toner without opening the toner.but in one toner there comes about near to 1500 copies.if you have got about 1200 to 1300 copies.then its quite possible that the power left is near to empty so the streaks comes on the paper due to less powder left.many times in this case removing and shaking the toner then reinserting the toner again and checking the printout helps. 2) But if you are sure that toner is not empty then other possibility is.in the toner cartridge there is a aluminium drum.its easily seen in the cartridge.once you remove the cartridge. if that drum is got very much used then due to that drum the streaks appear.fox example.if the drum is new the print is very dark.if the drum gets old the print gets very light or with streaks or faded print. 3) Now if drum and toner powder both are proper and still the problem then its the fault in the printer.in your printer there is some toner powder got spilled out on the inner parts from where the printing paper passes.so when the paper passes from the part where the powder is fallen or got collected then the streaks comes.in this case the printer needs internal cleaning and servicing. 4) but in some cases it has been noticed that internal powder of the toner becomes moist and very hard to come out from the toner for printing.in this case either toner needs to be refilled or toner needs to be replaced.you can get the toner refilled from local cartridge refilling store or local stationery shops dealing in cartridge refillings.The cartridge refilling shops also have the same printer for checking the cartridge.so at the refilling shop it will be confirmed whether the fault is in cartridge or printer.
This will help. Thanks .
on Mar 18, 2010 | Office Equipment & Supplies
The printer doesn't print anything but there's no error indicator light appears
hi! first check the toner if it has carbon left. you have to refill it or to buy new toner cartridge marmeto12_3.jpg
Aug 22, 2011 | Kyocera FS-1030D Laser Printer
The printer cannot print i refill hp powder and my printer is fuji ducuprint 204
you are getting dirty print out or can't print at all? for Xerox 204 printer, each time you replaced a refill toner, you need to turn the level on the left side to down, you will need to unscrew 3 screws to do that.,
May 20, 2010 | Office Equipment & Supplies
Streaking on left side of page
This will help. Thanks please keep updated. please please do rate the solution positively .thank you for using fixya
Mar 18, 2010 | HP LaserJet 1200 Printer
Yellow light on Toner light on) Cannot print a thing
take out the toner.. at the left side of the toner, there is a level, unscrew the 3 screws and turn the level to the other side, this will reset your toner.
make sure the printer is on when you put back the toner.
Jan 18, 2010 | Xerox DocuPrint 203A Laser Printer
Refill Process of Samsung Toner
Dear sir,
  1. open your printer cartridge drum cleaning blade unite wast toner clean.
  2. open two side from your cartridge left side and right side
  3. open plastic cork
  4. filling toner
  5. assembling again
  6. start print
Aug 19, 2009 | Office Equipment & Supplies
Brother 2040 printing watermark
does the printer do it from beginning? or after cartridge change?
Apr 11, 2008 | Brother HL-2040 Laser Printer
Black Toner Problem
You just might have a faulty black toner cartridge think back did the problem arise when you installed the new black cartridge. Also is the toner a original if not change for a original.
Hope this Helps
Thanks J
Dec 31, 2007 | Samsung CLP 300 Laser Printer
HP Laserjet 1022
Have you refilled the toner cartridge or is it refill as when these toner cartridges are refilled they have a tendency to leak. I suggest to remove toner cartridge turn the machine off vacuum out the inside and replace the toner cartridge with a new original. Run 20-30 prints through to get rid of any other loose toner and then should be fine.
If printing doesn't improve then repeat process if still same problem suggest transfer roller to be changed.
Hope this helps
Thanks J
Nov 15, 2007 | HP LaserJet 1022n Printer
HP LaserJet 1020 Printer Logo
Seeker5211
Seeker5211
