My speakers are plugged in, the error messae sounds are coming through the speakers but the sounds and audio devices say there is nothing plugged in and any media players say the same. I can't find any drivers to downloads for it and don't know what else to try. I've plugged it in all the different ports and nothing else happens. Help please!
    Sergeant:
  • 223 Answers
Look in the control panel for sounds and audio devices, if the error sounds are coming through, then the speakers are working, leave them plugged into that port, check your speaker configuration setting try setting it to stereo speakers. It also sounds like you may have it set to 5.1 and are only hearing the rear audio channel. problem being your two speakers connected to a 5 - 6 speaker configuration. Again, solved by setting the speaker configuration to 2 speakers (stereo) . Let me know the outcome. Thanks
Posted on Aug 27, 2010
  • Trevor Groves
    Trevor Groves Aug 28, 2010
    Did you get those speakers working , do you need further clarification or help? Please use the solution rating if your problem has been solved, make a note if your still having trouble.
    Thanks! Gurvy
I just bought a pair of "istar" USB speakers which came with no instructions. I have put the usb into a port at the back of the computer and plugged the little green (sorry not real tech savvy...
Hello.
You can go to the control panel and then double click the sounds and audio device. On the audio, under default device select the newly installed device audio or what ever indicated in the selection.
like this picture below
If not seen the newly installed device you install the driver of you hardware. may this help.
Mar 26, 2008 | Computers & Internet
I have checked and rechecked the setup and I am getting no sound. I have sound signals from my soundcard but no sound coming from my speakers. They are on. The power cord is plugged into a fonctionnal...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
hope this helps you
Sep 19, 2011 | Logitech Z-2300 Computer Speakers
HI I HAVE IBM FRU NUMBER 25P2726 SPEAKERS THAT HAVE NO SOUND COMING OUT OF THEM THEY WERE WORKING BUT WE HAD A PROBLEM WITH OUR SYS. AND NOW I HAVE NOTHING
if you are having problems with your sound
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Mar 31, 2011 | IBM 25P4726 Computer Speakers
We brought some Sony SRS-D21 speakers for our pc yesterday but there is no sound coming through them when plugged into the rear jacks on the pc. We have test sound when plugged into the headphones jack at...
control panel sounds and audio,volume you can adjust the volume or
advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 05, 2010 | Sony SRS-D21 Computer Speakers
XP laptop no longer recognizes any USB speakers, and internal speakers dont work. USB speakers do not appear in the audio controls. the only 'device' listed under Sound Playback is SoundMax Digital Audio,...
Nothing wrong with your USB ports. MagicJack has changed your audio and driver settings so it can use the sound system for phone calls. The changes exist whether the Jack device in plugged in or not.
You can confirm the problem by uninstalling MagicJack and reinstalling your sound drivers. Should fix the problem.
You'll probably need to contact the maker of the MagicJack device for a workaround. Might be something specific to your laptop/operating system.
Nov 13, 2009 | Toshiba Satellite M45-S2653 Notebook
No sound from external speakers with toshiba dynadock
if using XP, go to start control panel , sound and audio devices.Under the audio tab make sure the C Media CM106 sound device is selected under sound playback. Then under the volume tab set the volume somewhere in the middle or at the top if you don;t have active speakers . Then Under Speaker settings advanced, make sure the speaker setup is set to Laptop Stereo speakers. Also make sure the speaker volumes are up on the speaker volume button. click ok. If no result check that the cm106 sound decvice was cemented in as I saw it dissaper when I thought i had slected it. I think the key thing here is the device and the laptop speakers setting.
Aug 26, 2009 | Toshiba Dynadock Port Replicator, Docking...
My pair comuter speakers work, and there pluged in right, but don't pay anything out of them.
I assume you have told Windows about you new speakers ???
(Start, Settings, Control Panel, Sounds and Audio Devices = Volume tab, Speaker Settings box, Advanced button ...)
Oct 30, 2008 | Dell A215 Computer Speakers
Computers & Internet Logo
David Payne
David Payne
