Question about Canon PowerShot SD1000 Digital Camera
My canon powershot sd1000 camera is showing a black screen
  • Canon Master
  • 4,738 Answers
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Posted on Oct 29, 2010
SOURCE: card locked
Have you tried looking at the memory card? Sometimes there is a switch on the card itself that slides up and down to lock, or unlock the card for usage. Hope this helps! (It should be white, and a semi-translucent plastic.)
Posted on Oct 01, 2008
kenshin99
  • 89 Answers
SOURCE: I have a Canon powershot
Hi!
It's possible that you may have accidentally pressed the DISP button to disable the LCD. Please try to press the DISP button after you switch on the camera. If the display does not show up on the first press, try pressing the button twice or until the LCD turns on.
Please let me know if it fixed the problem , or not so that we can try other options.
Good luck and have a nice day!
Posted on Oct 03, 2008
SOURCE: Canon SD1000, screen blacked out and takes black pictures
try taking the batteries and memory card out let it set and put everything back in it ang cut it on
Posted on Jun 18, 2009
SOURCE: Canon Powershot SD1000: LCD screen display
Hopefully you resolved this already. If not, push the "DISP." button left of the MENU button. Pushing it gives you three options: black (for discreet shooting so your LCD doesn't give garner dirty looks from fellow concert goers), liveview, and liveview with info overlayed (shooting mode, ISO, etc.). Good luck!
Posted on Aug 18, 2009
t00nz
  • 4738 Answers
SOURCE: canon powershot sd1000 startup screen black no
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Also note that if you read the "reader's comments" section of the link, you may notice that Fix #5a seems to work best for the SD1000. Just be careful doing that particular fix.
Posted on Apr 13, 2010
Testimonial: "thanks for the quick response. "
My Canon powershot SD1000 screen isn't working. Iv'e charged the battery but when I turn the camera on, the screent is black. It won't take any pictures
It's very likely the CCD sensor that needs to be replaced. If you need to have it serviced, this place is excellent for the Powershots and not much at all if you need to have one fixed: www.camerasandparts.com
Before having it fixed, press the DISP button first and make sure you just didn't turn the display off. If you end up needing service for the Canon, that place above is really great for these cameras.
Apr 15, 2012 | Canon PowerShot SD1000 Digital Camera
My camera will no longer show the image on the screen when I am taking a picture with my Canon PowerShot SD1000 digital camera. Can this be fixed or is it time for a new camera?
most likely you have turned the dispaly off. find the display key and turn the screen back on.
another option is to go into the menu, then go to display and set it there.
Jul 18, 2010 | Canon PowerShot SD1000 Digital Camera
Flash Does not work. canon sd1000
This happened to my SD1000 and I followed the step by step instructions shown here:
http://www.ifixit.com/Guide/Replacing+Canon+PowerShot+SD1000+Broken+Flash+Unit/7778/1
and when I got to step 15, I found that the small plug that connects the flash to the camera body had been disconnected when the camera had been dropped. I simply pressed the connection back in tight and reassembled the camera - and it works. Maybe this happened to yours too??
Dec 10, 2009 | Canon PowerShot SD1000 Digital Camera
My Canon PowerShot SD1000 won't focus. Most
Sounds like you may not be in "Auto" mode. Press the "Func/Set" button, then press Right or Left to select the "Auto" mode.
Nov 01, 2009 | Canon Powershot A1000IS 10MP Digital...
Screen goes black and purple when I turn it on. If I try taking a picture it just shows black and purple
This is classic symptoms of CCD failure. This is very unusual to occur for a SD1000, but it is quite common for specific older Canon models as defective Sony CCD's were installed in many models over a span of three years.
Are you certain that your camera is an SD1000, and that you didn't have a typo and really mean SD100? The SD100 is one of the model cameras have the defective CCD. If your camera is indeed an SD100, Canon will repair this problem for free, with free shipping too. This is regardless of warranty status.
Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Sep 22, 2009 | Canon PowerShot SD1000 Digital Camera
Jun 18, 2009 | Canon PowerShot SD1000 Digital Camera
May 05, 2009 | Canon PowerShot SD1000 Digital Camera
Black screen, not capturing photos
have the same problem...
it happened about a month ago and i pressed the display button and it worked, but now that doesn't work either!
Jul 22, 2008 | Canon PowerShot SD1000 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
223 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
