Question about Saniflo 013/003/005 Sanibest Toilet with Grinder Series Pump in White Round
My Saniflo toilet has just started to pump/grind every half an hour of its own accord, I have had to switch it off as I am worried it will cause more damage.
  • 37 Answers
Sounds like the backflo preventer is bad letting water back down from system the backflo is the fitting is in the elbow fitting on top get a bucket when you loosen connection water from pipe will flow out then take elbow out of tank the backflow is the valve in bottom of the elbow it has a twist lock take out and clean if its cracked or any reason will not stay closed replace it
Posted on Nov 28, 2010
Low water level in saniflo toilet
Is it always low? Could be a partial blockage in the out flow pipe, causing the pump to stay on, or a sticking/dirty pump switch.
Apr 19, 2012 | Saniflo & Saniplus& Macerator Pump
We have a saniflo. We were out, and our babysitter (who isn't familiar with saniflos) was in the bathroom and suddenly she said water was flooding out of the toilet - she said she had heard a loud noise...
If the apple core was right at the pump intake at the time the pump kicked on it very well may have been the problem. The pumps in those units are not the strongest in the world anyway. They are not made to grind up anything that has any bulk to it.
So the answer to the question in my opinion is yes. But you well want to keep a close eye on it for a while.
Mar 11, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
The saniflo keeps cutting in even when not flushed
Water pressure makes the unit kick on and off. It will turn on by itself if water is somehow draining back into the pump. It could be water leaking from the toilet tank into the bowl and from the bowl to the pump or the flapper on the check valve inside the discharge elbow may be stuck open or could be defective and allowing waste water to drain back into the pump, once it builds up enough water pressure inside the pump, the unit will kick on and off by itself.
Jul 14, 2010 | Saniflo & Saniplus& Macerator Pump
Saniflo Saniplus won't stop pumping
is it pumping against gravity? if so there is a non-return flap in the outlet spigot could be stuck or worn.
Apr 10, 2010 | Saniflo & Saniplus& Macerator Pump
I have a turbofush P macerator and the pump no longer switches off automatically after grinding and flushing has occurred
turboflush uses a pcb mounted pressure sensor to switch the unit on/off. there is a small tube that connects to this unit. make sure that is ok and connected. otherwise its a new pcb i'm afraid. look online more info from saniflo-pumpshop.co.uk
Mar 17, 2010 | Saniflo & Saniplus& Macerator Pump
What is the best product/chemical to keep Saniflow free of calcium build up ?
I would suggest not using standard drain cleaner as it could cause damage to the seals inside the unit. Saniflo suggest the following
http://www.sanifloproducts.co.uk/products/Saniflo-Products-Saniflo-Descaler.html
Hope this helps
Jan 21, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
My saniflo keeps coming on about every hour on its own and we cannot stop it making an awful noise
Suspect that you may have a leak at the flapper of the toilet bleeding water into the holding tank causing the pump to run unnecessarily.
Replace the flapper and clean the mating surface.
Jan 11, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
How to install toilet macerator?
on your out put pipe make sure you put as few turns and bends in it as you can, this will help the pump out when it's grinding and pushing it up. also you will want to use schedule 80 pvc pipe if you can get it and make sure you prime and glue every fitting well because you do not want that to leak when it's started up. it's always good to put a check valve on it as well some where close to where it enters the tank and a shut off valve, the glued pvc valves are handy because you dont have to worry about them leaking
Jul 26, 2009 | Saniflo 002/005/007 Saniplus Toilet with...
Saniflo 013/003/005 Sanibest Toilet with Grinder Series Pump in White Round Logo
233 people viewed this question
Top Saniflo Home Experts
paulcarew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
