Tosumi stb01 My freeview receiver has suddenly stopped producing any volume - I can listen through my 'loop' system - so there is some volume there somewhere, I can also hear thro my tv receiver - can you help please? Wendy Barker wendybarker1@talktalk.net
    Problem Solver:
  • 35 Answers
Is this like your unit? Don't you have the vbi teletext support on your freeview receiver?
Check here:
http://www.247electrical.co.uk/epages/twentyfourseven.storefront/48286d43011507e2273f0a020f020539/Search/Run
Posted on May 12, 2008
Suddenly yesterday this equipment stopped producing any sound. Not even on the TUNER option. Usually it receives sound from a satellite receiver also. Now it is mute. It is connected to a pair of JBL H-F...
Hi,sorry for my dumb question...is your receiver 's "MUTE" switch is ON or OFF ? because your description relates directly to this feature..if it is on make sure you switch it OFF but before doing this pls make the volume minumum..
if problem continues pls let me know for further help..
Hope this helps!..if more help requires pls let me know.
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 18, 2011 | Audio Players & Recorders
Volume not function.
You need to be a bit clearer on the exact nature of the issue.
Please include if the unit was working and suddenly stopped producing sound (ie - speaker output fuse blew) or if you relocated the unit, and after hooking it back up, you aren't getting any sound (ie - not hooked up right) or if the volume knob isn't changing the readout for the volume level (logic or knob broken) - and also include the make and model of WHAT the volume knob is attached to (ie - Yamaha receiver model X)
Feb 22, 2011 | JVC Audio Players & Recorders
My home theater speakers make a constant hum whenever my receiver is on. The loudness of the hum changes with the volume control, and goes away entirely when the system is muted. All components are plugged...
jd40,
Sounds like a grounding issue. The first two places to look into is the powered subwoofer and antenna. During your last test, did you leave the FM antenna and subwoofer connected? Many times the hum is directly related to the antenna and/or the subwoofer and to how they are grounded; creating a ground loop through the receivers ground on the outlet. If the antenna is grounded to the dwellings wiring, hum is inevitable and sometime you can get a ground loop hum from how or how & where the subwoofer is grounded. Try taking them completely out of the loop.
Also try taking it further back to the basics, start with the receiver plugged into a known good grounded outlet with no surge or line conditioner in the loop and nothing connected to the receiver, nothing. Use one speaker and different wire to test each speaker output while in tuner and any other mode but phono. With no signal, you will either get nothing (no hum or static) or just static in the tuner mode. No hum is a good sign. Some systems will mute the speakers if no signal is connected to eliminate the static from being produced through the speakers but a ground loop hum will most likely still be produced even in mute. If you get a hum when nothing is connected to the receiver, try looking into getting a better grounded outlet, even maybe to a different dwelling.
-Chris
Jan 30, 2010 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Suddenly, amplifier stopped giving out sound. Controls and display seem to work fine. If it is blown fuse, where is it & how can i replace it?
Does it stop on both channels? It sounds to me like the safety circuit is activating. This usually happens when either the volume is too high, or the speaker load is too great (i.e. usually loads less than 4 ohms will do this) or, the amplifier has an internal short causing the amplifier's output stage to become un-balanced. Does the sound come out nice and clearly through both channels? How long does the receiver play before the sound stops? How loud are you playing the music when it stops like this? If the sound is reasonably clear through both channels at regular volume, then there is probably nothing at all wrong with the receiver's output circuits. If the amplifier is being played at regular volume or even lower volume for quite a while and then quits, perhaps the receiver is getting too hot and it's thermal sensors are activating the protection circuit. Make sure that when you operate the receiver, that there aren't things laying on top of it blocking the unit from venting and cooling properly. Make sure it has plenty of breathing room - amplifiers (most of them anyway) are inherently subject to producing heat. If the amplifier only quits when played at high volume, well then that's probably the problem - it's probably not meant to deliver such power that you're asking it to - especially if you're driving a heavy load such as 4 ohms or less. If you're running several speakers on this unit, try scaling back to just two speakers for now, and make sure these are 8 ohm speakers. Play the unit for a while and see how it does.
Oct 24, 2009 | Aiwa AV-DV95 Receiver
My speakers wont work suddenly unless I am using my headphones
Make sure in the volume mixer that it is using the right sound device. You most likely have it set to the wrong device output. When you plugged in the headphones in kinda automatically switches, but to use the speakers again you have to do it manually. Just hook up a cheap av receiver to your computer and use this headphone input instead. a 100$ 5.1 av receiver beats any pc speaker system.
Aug 01, 2009 | Toshiba (4CH-VOUT) Sound Card
"protect" display when volume is high and volume cuts in and out.
you should have it repaired.the audio circuit is malfunctioning because of the sudden burst/surge of current.
May 15, 2009 | Onkyo TX-SR502 Receiver
Kenwood VR-209 turns off after 20 minutes
Overheating is likely your root cause. Move the unit to make sure it is getting enough air around it and remove anything that you have sitting on top of it ESPECIALLY any device that produces heat of it's own such as your CD player. If that does not solve the problem, listen at a lower volume and/or defeat any equalization or bass enhancement circuitry.
May 09, 2009 | Kenwood VR-209 Receiver
Freeview receiver
This aeems to be a dud device return to seller or Philips
Jan 16, 2008 | Televison & Video
106 people viewed this question
 Grubhead
Grubhead
