Question about HP L1906 19" LCD Monitor
No power (led off) - HP L1906 19" LCD Monitor
  • 11,361 Answers
Check the main AC fuse, DC filter caps (more likely to be the problem).
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Aug 28, 2010
Can you tell if LED tv has bad LED strips before changing LED Board/Power Supply (as they're in one piece on a lot of TVs)?
This is not easy to diagnose, either use a meter on the power cable to the led or check the leds one at a time
Feb 24, 2016 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
Imac intel will not power on
Possible failed video card. 3rd LED indicates MLB and GPU are communicating: (CAUTION! There is high voltage from the powersupply so any attempt to open iMac other than removing glass panel to see the indicators...should be done by authorized ACMT)
  • LED 1 - Indicates that the trickle voltage from the power supply is detected by the main logic board. This LED will remain ON while the iMac is connected to the AC power. The LED will remain on even when the computer has been shut down or put to sleep. The LED will turn off only if the AC power is disconnected or the power supply is faulty.
  • LED 2 - Indicates that the main logic board has detected proper power from the power supply when the computer is turned on. This LED will be ON when the computer is turned on and the power supply is working correctly.
  • LED 3 - Indicates that the computer and the video card are communicating. This LED will be ON when the computer is communicating properly with the video card. If LEDs 1 and 2 are ON and you heard the startup sound, but LED 3 is OFF, then the video card might be installed incorrectly or need replacement.
  • LED 4 - Indicates that the computer and the LCD display panel are communicating. This LED will be ON when the computer is turned on and video signal is being generated. If the LED is ON and there is no image on the LCD display panel, the LCD display panel or inverter might be installed incorrectly or need replacement.
Aug 01, 2017 | Apple 24" iMac Desktop
I have a mackie 3208 (8bus series) thats leds wont work. I opened it up to clean it and for some reason 4/10 times when i turn it on the leds work, the rest of the time no led works (meter bridge,...
Howdy, As i informed you in our chat the most likely source of your problem is the supply of power to the led lights. Check the power supply lines and try to trace for any breakages in contact from the beginning to the end. For the power supply.
Usually there are only 2 possible problems to led lights and they are light burn out or power failure due to a breakage in the flow of power from the point of power supply to the led light. Considering that all the led lights cannot burn out at the same time the problem is from the supply of power to the led lights. Trace the power source for inconsistencies.
Hope this solution has been helpful?
Thank you for visiting Fixya.
Jul 19, 2011 | Computers & Internet
Lookig for a manual for an fic au13 motherboard
Front Panel Block Cable Connections
f_Panel
1 3 5 7 9
2 4 6 8
1] HDD-LED (+)
2] Dual Power-LED* (+)
3] HDD-LED (+)
4] Dual Power-LED* (-)
5] Reset Switch
6] Power Switch
7] Reset Switch
8] Power Switch
9] Dual Power-LED* (**)
* Single Color Power-LED 2 or 3 pins:
1 2 3
1]Power-LED (+)
2] GND
3] GND
** Dual Power-LED:
if useing dual power LED,
Green: pin2
Yellow: pin4
otherwise, Pin2 is positive (+) Pin4 is negative (-
For future Reference you can download your manual directly from the manufacturer's website HERE
Or directly from HERE
May 30, 2009 | FIC AU13 Chameleon Motherboard
I tried several different cards but no luck. Cards work ok on other computers.
5V Stand-By Indicator LED
The power supply will always supply a 5V standby voltage to your
motherboard so that it can power on via for example Wake On Lan
technology. This LED shows that your power supply is supplying
this standby voltage to your motherboard.n :D
You may need to replace your power supply, if the LED is flashing, it's not supplying the power the motherboard needs.
[JP-25]
1 2 3 4 5 6 7 8 9
10 11 12 13 14 15 16 17 18
1] Power Led (+)
2] --
3] Power Led (-)
4] --
5] --
6] Speaker (+)
7] --
8] --
9] Speaker (-)
10] Reset switch
11] Reset switch
12] N/A
13] Power Switch
14] Power Switch
15] ACPI Led (+)
16] ACPI Led (-)
17] HDD Led (+)
18] HDD Led (-)
For future reference you can download your motherboard manual here:
(PDF) Soyo K7VKP2
May 09, 2009 | Computers & Internet
NEED POWER SWITCH WIRING FOR A EMACHINE T-3095
check on the motherboard there should be a small prints on it near control panel.
Mar 05, 2009 | E-Machines eMachines T3830 PC Desktop
Canon ip4200 waste absorber is full
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button.
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button 4 times, the green (power) led should be lit to reset ink absorbers.
(Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
5)At the end of the service mode, press the Power button
Jan 10, 2009 | Office Equipment & Supplies
Internal led of ML350 server is glowing.......how do i resolve it?
Hi Franceso, plz specify
Is it powering ON ?
Which LED is glowing?
These leds are there on the front panel :
1 Power On/Standby button
2 System power LED
Green = Power on
Amber = System shut down, but power still applied
Off = No power
3 Internal health LED (Wave sign in BOX)
Green = Normal
Amber = System degraded. To identify the component in a degraded state, refer to system board LEDs.
Red = System critical. To identify the component in a critical state, refer to system board LEDs.
Off = Normal (when in standby mode)
4 External health LED (power supply)
Green = Normal
Amber = Power redundancy failure
Red = Critical power supply failure
5 NIC 1 activity LED Green = Network link
Flashing = Network link and activity
Off = No link to network.
6 UID LED Blue = Activated
Flashing = System remotely managed
Off = Deactivated
7 UID button
If it is Internal health led then any internal h/w issue is suspected.
If it is external health led then any power supply or power source related issue is suspected.
Also check the status of the server & its IML (Integrated Management Logs) in ilo (Integrated Lights Out ) if it is configured. (2nd RJ45 port in rear)
Also make sure the cabinet is properly closed.
Nov 18, 2008 | HP Compaq ProLiant ML350 G3 Server
The power led and reset led was both on
There is a line connection on power led that has a negative and positive maybe it inter change. Or there is an inter-change connection between your power led and reset led in *********** board.
Oct 18, 2008 | ASUS P5P800S Motherboard
HP L1906 19" LCD Monitor Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
