Question about Fisher and Paykel 24 in. DD-602 Built-in Dishwasher
I am having trouble taking out the bottom pan to clean the filter. Please let me know how to remove the bottom pan. Thanks
  • Fisher and P... Master
  • 3,247 Answers
I am not sure what you mean by the bottom pan. Are you trying to clean inside the drawer or the inside of the outer housing?
If you want to remove the filter plate at the base of the drawer then refer to page 21 of the user manual. (DD602 is similar to DD603).
Posted on Sep 12, 2010
How to put in a tranny filter on a 91 gmc 4x4 4.3l blazer
You remove the transmission pan and then remove the old filter. Make sure you remove the old seal out of the valve body and install new filter with new seal and re-install pan. Fill with fluid and you are done.
Nov 15, 2014 | Cars & Trucks
I froze shrimp in ziplock bags and it leaked in the back of the refrigerator and in the pan and smells really bad. How can I clean it. I don't know how to get the pan out and my hand is small but I...
Hello, To clean the bottom of the refrigerator just remove the two bottom vegetable draws. Refrigerators inside don't have external drain (why, it would the number one place for contamination from mold). The only pan that could be there is the refrigerant coil condensation catch pan. You'll to remove the kick panel on the front below the doors or door. It just snaps in, Once you get the front panel off, clean up the front there will lent, leaves, maybe one of kids sock, everything collect this space. You can probably see the aluminum pan, also there might be a front tab to take the pan out. Sent me message back and I'll tell how to clean the back of the frig. Madam, you did give the make of your refrigerator. GB...stewbsion
Aug 25, 2011 | Frigidaire Refrigerators
Where to find the auto transmission fluid drain plug on a 1997 ford escort?
Hi, there is no drain plug. You must remove the pan to drain the fluid unless you want to sure a pump through the dipstick pipe. You should probably take the pan off anyway to check for metal shavings and to replace the filter. The filter usually comes with a new pan gasket. Please let me know if you have more questions, and thanks for using FixYa.
Feb 12, 2011 | 1997 Ford Escort
My washer is 7 years old. During a wash cycle, it overfilled so much that the door opened and flooded the laundry room. After turning it off, the machine continued to fill. My guess is that there is a fill...
Hi, just read about your problem. Need to have you go to the bottom of front of washer. It may be visible or you may have to take kickplate off. Position pan underneath filter. Slowly turn counterclockwise and water will start to come out. When pan is partially full, empty. Repeat until no more water comes out. Unscrew and remove filter and clean. Reinstall. Other possibility is a bad pressure switch? Hope this helps.
Jan 19, 2011 | Washing Machines
Water keeps overflowing, dont know how to clean the filter or where it is .
hi, read about your problem. The filter is located at the bottom of the front of washer. If its not visible, remove the bottom kick panel. Three screws at bottom. Take a shallow pan and place under filter. Slowly turn counterclockwise and water will slowly start to come out. When pan is partially full, empty. Be sure to close filter before doing this. Keep up with this procedure until no more water comes out, then unscrew filter and remove and clean. Reinstall and put kickplate back on. Hope this helps.
Jan 19, 2011 | Hotpoint Aquarius WD640 Front Load...
I need to change the transmission fluid, but I don't know how... I'm frustrated plz help...
simple task!!! jack up the car. get a pan BIGGER than the tranny pan itself. put pan below.while your doing this you might as well change the filter also!!!!!! start unbolting the pan, but leave a bolt at all 4 corners.once you have all but the 4, break them loose, but dont take them out.take two bolts out and let it drop down to get most of the tranny fluid out. once most of its out, take the other two bolts out and bam! there you go. if you have a new filter, it just pops out, make sure you take out the old seal.
Dec 06, 2010 | 2002 Lincoln LS
How do i change the manual transmission fluid in 1996 honda prelude
You remove the drain plug from the transmission pan. The oil pan is at the front of the vehicle bottom of engine. The transmission pan is more in the middle of the vehicle. The plug will either be on the bottom of the pan or on the side. For a quick change you drain and refill, but you usually want to change the transmission filter which is inside the pan. To do that you drain and remove the pan, take of the old pan seal and clean the area it was at on the pan. Remove the filter and replace, then put the new gasket on the pan and install the pan and fill
Jul 23, 2010 | 1996 Honda Prelude
How do you service automatic transmission? change trans. fluid?
remove the transmission oil pan bolts,leave one corner tight untill your ready to lower pan and drain fluid into oil catcher pan,then remove remaining bolts and drop pan,
remove the transmission filter, install new filter,clean inside pan and dry,install new gasket on pan,reinstall pan,put at least 5 quarts in before you start car and shift through gears,return to park,and bring oil to full mark.
Jan 01, 2010 | 2005 Ford Mustang
Where is the transmission in line filter located for a 92 saab
I assume you have an automatic transmision (the manual is basically "fill and forget unless it leaks" as it wasn't designed with a drain point, but check the level periodically, anyway) Like pretty much all auto trans, the filter is located inside the bottom pan, and for Saab is a metal encased rectangular unit, with rounded end. It is cleanable and re-used. Drain the pan; clean the pan exterior and drop it; remove filter mounting bolts and filter and clean with suitable solvent or clean ATF; clean pan and magnet in pan and reinstall magnet in the SAME position; re-install filter with NEW O ring; dry pan and re-install with NEW gasket (no sealant); install drain plug; re-install cross members/support plates what have you torques: pan mounting bolts 71-106 in-lb drain plug 44-71 in-lb REFILL the transmission, and with handbrake on and engine running, shift through all gears. Then re-check fluid levels and check for leaks. If this helps you, please give a "thumbs up" thanks Saabreur
May 27, 2009 | 1991 Saab 900
Drain pan under ge sideby side fridge
pull the front bottom grill off then pull the pan out to you to drain or cleas.
Dec 16, 2008 | GE GSS25JF Side by Side Refrigerator
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Logo
99 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
