Question about Honeywell Dryers
I purchased a Honeywell HT-380BP Turbo fan disassembled and in a box at a thrift store. Is there anything by way of a circuit diagram I can reference to put it back together? There's a motor with seven wires/leads, a capacitor, the circuit board, and the power cable. I just can't seem to figure out where this capacitor goes..
I Guess nobody has the Answer....
Red= high
Yellow= med
Brown= low
White=com
Gray= neautral
Black 2X= live? ACL on the board.
the cap is connected to white & gray.... I want to bypass the electronic board w/ a manual 3speed switch cause I think the motor is still good!!
nobody has the answer?
I purchased a Honeywell HT-380BP Turbo fan - 3a1b5d56-5fb5-4fb9-a9b6-77c7ed684e9c.jpg
Posted on Sep 14, 2014
  • 14 Answers
SOURCE: where does while lead from ceiling connect? capacitor has five leads, 2 gry, 1rd, 1 grn 1br, (grn gry br to switch) switch has black lead to ceiling lead.
White is the common, or neutral. There should be a white wire to connect it to.
Posted on May 24, 2009
SOURCE: WIRING OF 3-WAY SPEED SWITCH FOR HAMPTON FAN
1 - Red/Pink
2 - Purple
3 - Yellow
L - Black
Posted on Jun 20, 2009
  • 334 Answers
SOURCE: wattage for the honeywell ht-800 fan
Can you see an amp draw rating on the fan motor itself?
SOURCE: Ceiling fan capacitor hook up problem. I have a 3
The reverse switch on my Hampton Bay ceiling fan didn't work. I cut the 6 wires; 1 white, 1 gray, 2 pink, 2 yellow. Here's what I did. Removed reverse switch. Had 6 wires white, gray, 2 yellow, 2 pink. Connected gray to yellow, connected white to pink and fan runs fine. Is this OK? I do not need to reverse fan. It's been running for 1 hour now with no problems. Don S.
Posted on Jun 11, 2010
mcdevito75
  • 1970 Answers
SOURCE: GE Box Fan Motor ? No Capacitor?
mcdevito75 here, It could be bad brushes in the motor also, or a bad bearing or bearing cap in 1 of the motor ends.
Posted on Jul 27, 2010
Singer 9420 bobbin case diagram
Could you check to see if that is the correct model number? I cannot find anything on a Singer 9420.
Dec 22, 2013 | Singer Sewing Machines
How do I clean fan blades?? No manual in box. model # HT8800BP
unpug the unit first and then open the front cover.
Aug 02, 2011 | Honeywell HT-800 Table Fan
How many watt it have?
    Features and Benefits:
  • Powerful 3 speed turbo fan for fast focused cooling power or enhanced air circulation
  • High performance blades rotate for maximum air velocity through the wind tunnel turbo grill
  • Pivoting head can be adjusted in a 90 degree arc for varied air distribution
  • Versatile design makes this fan great for use on desk and table tops
  • Wall mounts with separate purchase of hardware
  • Equipped with a carrying handle for transport
  • Dimensions and Weight:
  • Size: 6.33" x 11.375" x 11.125"
  • Weight: 3.5 lbs.
    Power 50W @ 110V
    Power 60W @ 220V
Feb 14, 2011 | Honeywell HT-800 Table Fan
How to open fan to clean blades honeywell model
first remove the two screws on the back top of fan... then remove little cover on third screw which is located on the bottom of the outer casing.. i used a fork to poke the hole for leverage then pull it out... take out the three screws on the bottom (that hold the stand part of the fan).. now you can start removing the casing.. start to pull apart.. carefully... once you have opened one part you can use a flathead or a butter knife to pry open where there are clips on the sides.. the final clip is under the handle poke that one and your fan should be opened....
Apr 15, 2010 | Honeywell Dryers
I am being told that I need to replace my furnace circuit board (Honeywell ST9120C 4016). I just replaced it 2 yrs. ago. Any ideas? If it needs to be replaced, where can I purchase it?
is it working properly if so then the ancer is no if yes remove it and take it to local apliance store and have them test it thay may have a used one cheep !!!!
Feb 10, 2010 | Honeywell Fan Timer Board St9120c 2010
My honeywell air purifier is emmiting an awful
Mine quit too... The led screen went blank so I changed the battery. Now it does nothing. I totally disassembled it as the fan was turning stiffly.(should spin very easilly) The grease in the end bearing was stiff. I washed the gummy grease off the shaft and reoiled with synthetic oil. Your smell is probably motor windings overheating. I disassembled the electronic control and was disgusted to see that there is a glass fuse soldered to the circuit board. I believe the only reason for this fuse is to cause us consumers to needlessly replace otherwise good equipment. (It cost more to pay a repairman to replace the hidden fuse than to purchase a new unit)The fuse is not blown. At least this fuse actually looks lide a fuse unlife the stealth fuses most electronics have hidden in them. I can not obtain a wireing diagram on my 17005 unit but it has a black box inside behind the control panel. It looks like a small start capacitor, but it has a temp rating on it of 70*C. I suspicion it is a single use over heat safety which triggered when my motor got hot due to stiff bearings. I refuse to play their game and purchase a new air cleaner. I love this one... So, if I can not determine what that little black box is, I am going to bypass all the crappy electronics and just drill a hole on top by the handle and install a hi/lo/off manual switch directly to the motors wire hasness. This machine will never give me problems ever again, and if I oil the motor every couple of years with synthetic (Ander oil) this unit WILL last me for the rest of my life...
Oct 26, 2009 | Honeywell 17000 Air Purifier
Wattage for the honeywell ht-800 fan
Jun 20, 2009 | Honeywell HT8002 Table Fan
Ceiling fan wobbles How do i balance it ??
you go to the hardware store and buy a ceiling fan balancing kit
Jun 18, 2009 | Honeywell HT-800 Table Fan
Cleaning Honeywell table fan
By the way please check my video on YouTube for your answer. Watch, Subcribe, Share, and Comment!
Thank you
" How to Open a Honeywell Fan to Clean" on YouTube
Jun 14, 2009 | Honeywell HT-800 Table Fan
Dryers Logo
300 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
Tom Chichester
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
