Question about Edimax 4 Port Wireless AP Broadband Router (br-6104wb)
How do i fix bad firewall on router - Edimax 4 Port Wireless AP Broadband Router (br-6104wb)
    President:
  • 2,571 Answers
What do you mean by bad firewall??
Is it not working?
Is it blocking everything??
Some more information please
Posted on Aug 27, 2010
My internet connection became slower after i got xfinity internet and belking router.Can a cause of the problem be a conflict between belkins firewall and Mccafee firewall that i have for a long time.If it...
It could be a conflict.. but the main thing is there really is no reason to have a 3rd party firewall installed on windows, it has it's own firewall, then you have the firewall built in to the router, all mcafee's firewall is doing for you is taking up resources and potentially causing conflicts.
I would remove that firewall and see if that helps, if not, reset the router to factory defaults (there should be a reset button on the router) and configure it again, possible that it was not set up correctly or got corrupted somehow.
With the introduction of Windows 98 SE Service Pack 2, there is no reason to have another firewall installed.
Hope this helps
May 20, 2011 | Belkin (F5D5231-4) Router
When playin xbox and laptop is connected to internet i have problems connecting to lobbies and lag really bad when i do connect to them... how can i fix this... it says my nat setting is strict... before...
Open the router interface (192.168.2.1), by connecting a computer hard-wired to your router and ensure modem is also connected.
On the far left side, Click on Firewall and disable it.
Click on DMZ under firewall and assign an IP: 192.168.2.25 after enabling DMZ.
Assign the IP settings manually on your X-Box too.
IP: 192.168.2.25
Subnet mask: 255.255.255.0
Gateway/Router: 192.168.2.1
Assign DNS settings manually on your X-Box: Primary: 4.2.2.2; Secondary: 4.2.2.1
Click on Wi-Fi Protected Setup, disable this feature.
Click on Security under WIRELESS, change it to 64-bit WEP and enter tour phone no. as wireless key under key1.
Check if the firmware version on the router is: 1.00.17, else upgrade it.
Save the router settings.
Restore the router to factory defaults
Restore the saved settings on the router now.
Unplug the power from modem, router and X-Box.
Connect power to modem 1st, router 2nd and finally X-Box and now check.
For further clarifications, please revert!
Thanks for asking.
Regards,
Arvind S Iyer
Oct 05, 2010 | Belkin Wireless Surf Router (F7D2301)
How to fix my 2wire modem if it says it has a firewall problem
1. What OS ( operating system) you are using.
2. Have you check if the settings are on " automatic DHCP and do you have the router
3.Check the firewall settings. This will cause disconnection if not on the "access list" in the "firewall" settings.
4. Make sure you have the most current firmware updates on the router.
5. See if you can "ping" the wireless router. If you can't check configuration.
6. check the " up grade history" page.
Apr 19, 2010 | 2wire (2701HG-B) Wireless Router
Magic Jack Phone System...
I haven't had any problems with my MJ, but that, I think, is because I port forwarded MJ. That's what seems to be your problem. You need to port forward your MJ into your firewall/router. If you don't think you have a firewall and/or router, your a noob. All pc have a firewall, at least. Windows has a firewall. If you get your internet connection is from broadband then you most likely have a router with a firewall. Some routers are buit into the broadband modem. Figure out what kind/name your firewall, router, modem is, and go to www.portforward.com. Click on the routers model number, then click on MagicJack. If you just have a firewall, and no router, they have a page just for firewalls. If your not sure what you have then click the "Start Here" link on their first page.
Feb 22, 2009 | Lands Phones
What im i doing wrong
Limited or No Connectivity Error Message
If you are still experiencing this error message even you may be experiencing one of several problems shown below:
1) Your Network or DSL router may have bad or missing information. Powercycle your router and/or rebuild the configuration in your router.
2) Double-check your cabling to the computer. Make sure you have the correct type of cabling, straight-through CAT 5 or possibly a crossover cable and try another cable or test the cable to make sure its working properly.
3) Check your network card to make sure its configured correctly and working properly. Many times setting the network card to 10Mbps/Full Duplex will solve this issue. To do this, open Control Panel, System, Device Manager. Go to the properties of the Network card, click on the Advanced tab and find the Link Speed and Duplex section. Change it from Auto Detect to 10Mbps/Full Duplex.
4) Check and test your firewall. Your firewall, especially if its a software firewall like ZoneAlarm, Black Ice, Norton Firewall or something else could be blocking the connection. Disable your firewall and test the connection. You may have to resolve the problem by even uninstalling and reinstalling the firewall.
5) Check your IP address assignments and workgroup settings in the computer for accuracy. Statically assign IPs to the computers in your network.
6) Reset your TCP/IP stack by downloading and running WinsockXPFix.exe a Visual Basic program designed to fix corrupted TCP/IP issues, host file problems and a variety of other connectivity issues.
Feb 01, 2009 | NetGear WGR614 Wireless Router
Laptop can't connect to internet
Nov 19, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
Need network key, wireless is not working it logs me off all the
7) Also this issue is relate to SP2 update (in that case you should run the Microsoft patch (KB884020) for it.)
Nov 18, 2008 | D-Link AirPlus DI-524 Wireless Router
No internet connection through routers (broadband AND wireless)
Try to disable any firewalls on your computer. If you already have internet details showing, there's something blocking your connection which is possibly a firewall. Turn off the Windows firewall as well as Norton, Mcafe, Zone Alarm and the like if you have one.
Nov 01, 2008 | D-Link AirPlus DI-524 Wireless Router
The device appears on the desktop but has a cross through it
Does mean that is not connected.
Double click on the icon, select your network and click connect.
If you were been connected before, you have some problem connectivity.
you can fin some help here:
Oct 28, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Edimax 4 Port Wireless AP Broadband Router (br-6104wb) Logo
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Rommel Balcita
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
