Question about Sony VPL PX40 Multimedia Projector
HOW DO YOU PUT THE SYSTEM IN STAND BY - Sony VPL PX40 Multimedia Projector
  • 10,594 Answers
Turn Power Off by pressing power button on projector, it is now in standby.
If projector is plugged in but not in power On mode or not showing picture, it calls standby.
Posted on Aug 27, 2010
I have a 2006 honda shadow aero. engine dies when put in gear. kickstand switch measuers good at plug...clutch switch measures good...clutch disengages properly...what else can it be?
Hi, Dan the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
a. It prevents starting when the transmission is in gear and the side stand is up, but the clutch lever is not pulled.
b. It prevents starting when the transmission is in gear and the clutch lever is pulled, but the side stand is still down.
c. It cuts the running engine when the transmission is in gear and the side stand is moved down.
Periodically check the operation of the ignition circuit cut-off system according to the following tests.
With the engine turned off:
1. Move the side stand down.
2. Make sure that the engine stop switch is set to "RUN"
3. Turn the key to "ON".
4. Shift the transmission into the neutral position.
5. Push the start switch if the engine does not start the neutral switch may be faulty.
With the engine still running:
6. Move the side stand up.
7. Keep the clutch lever pulled.
8. Shift the transmission into gear.
9. Move the side stand down if the engine does not stall you may have a faulty side stand switch.
After the engine has stalled:
10. Move the side stand up.
11. Keep the clutch lever pulled.
12. Push the start switch if the engine does not start you may have a faulty clutch switch.
This check is most reliable if performed with a warmed-up engine.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Dies when put it in gear 2003 Honda Spirit VT 750
Bike only starts in neutral and Dies when put in gear
Honda VT750C2 Shadow Spirit Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT750C 2005 Shadow Aero Owner Manual
Apr 29, 2017 | 2006 Honda Shadow Aero
My honda valkyrie stalls when shifting from neutral to first gear wile still holding down the clutch
Hi, Anonymous the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1500 Dies putting it in gear GL1500 Information Questions goldwingdocs com
Honda GL1500 Service Manual
Honda 1997 GL1500C Valkirie Owner Manual
Apr 06, 2014 | Honda F6 C Valkyrie Motorcycles
Yamaha virago problems
Hi, Darrensemail the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
Periodically check the operation of the ignition circuit cut-off system according to the following.
https://www.viragohelp.com/virago-ignition-systems
ViragoTechForum com Yamaha XV250G Supplementary Service Manual
OEM parts for Yamaha
Yamaha XV250L Owner Manual
Mar 30, 2017 | 1993 Yamaha Xv 250 Virago S
Yamaha Radian stalling
Re dies when put in gear Road Star Forum Yamaha Road Star
Bike dies when put it in gear plz help
Yamaha YX600 Service Manual
http://www.badrad600.com/Radian%20Manuals%20-%20Complete%20-%20Printable/Radian%20Owner's%20Manual%20Clean%20Complete%20Final.pdf
Mar 25, 2012 | 1987 Yamaha YX 600 Radian
A STAND ALONE NO USB PORT WANT TO BURN IMAGE supported files
You have a stand alone duplicator ? It will copy whatever you put in it. It will not extract and burn the image correctly, just make a copy of the image.
You need a computer with SW to extract image content to a recordable DISC.
Mar 11, 2011 | Computers & Internet
2003 honda 750 ace, with the clutch lever pulled back when you put it in gear the engine dies.
Check you side stand safety switch. If it is unplugged, removed, or malfuntioning, the bike's system will think the side stand is down and kill the engine when the bike is put into gear.
Nov 13, 2010 | 2003 Honda VT 750 CD Shadow A.C.E. Deluxe
Got 2001 gsxr 600! bike starts in (N) but stalls out when put in gear?????
Check you side stand safety switch . Suzuki uses a system that kills the motor if you put it in gear with the side stand down or put the side stand down while it is in gear and it is running.
Oct 01, 2010 | 2001 Suzuki GSX-R 600
Fisher CA-885 Integrated Stereo Amplifier stuck in stand-by mode
Given the heat/cold cycles of the storage area along with humidity, I would first suspect poor solder connections. This is not unusual for units of this age. A general overhaul should restore this to operation. This should be a labor only repair unless the output STK is bad. These units are known for having poor connections at the voltage regulators which cause a DC voltage offset triggering the protection circuit. The overhaul should address this as well.
Keep us posted on your progress.
Dan
Jul 06, 2010 | Audio Players & Recorders
Sony VPL PX40 Multimedia Projector Logo
70 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
