Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Hi, what kind of oil can i put in my ridind lawnmower craftsman?
  • 183 Answers
The domestic engines (Briggs, Tecumseh) take SAE 30 weight motor oil. The import engines (Honday, Kawasaki) usually take 10W30 motor oil. In either case, I recommend using a good quality name brand oil like Castrol, Pennzoil, etc. Most riding mower engine take about 48oz from a complete drain. If your engine has an external filter, it might require a few more ounces.
I hope this helps.
Posted on Aug 27, 2010
Craftsman 6hp.lawnmower oil pouring out of spark plug hole
Either someone put to much oil in it or a piston seal has failed. Try removing some of the oil and cleaning out the spark plug port and spark plug (maybe replace the spark plug with a new one. If it is a blown piston seal take it in for service.
May 05, 2015 | Cars & Trucks
I have a brand new craftsman 190cc lawnmower and the pull cord will not pull out
If it's new sometimes the manufacture puts a safety block to hold it from moving during transit. Check for this. See if the blade will turn and if not see if there is a seized area. Is the blade jammed against something.
Jun 30, 2014 | Craftsman Garden
My craftsman lawnmower is leaking oil.
Check the drain plug, maybe it loose
Jun 19, 2014 | Craftsman Garden
Help line for craftman lawnmower
Could you check the model number again and provide the Brand?
Jun 03, 2014 | Craftsman 20 Hp 42" Deck Lawn Tractor
What kind of gas to used on lawn mower 55 158 cc craftman
Ori Hi, most lawnmowers use regular unleaded petrol now. If you have somewhere that oil goes into your mower then it will be normal unleaded but if on the fuel cap it has an oil can picture you need to mix it with two stroke oil.
Sep 07, 2013 | Craftsman 55 Torque 158cc 22" Push Lawn...
Cant pull string on lawnmower
if motor is lock up pour oil in clinder and work the blade back and forth till it unlocks
Apr 28, 2013 | Craftsman Garden
Lawnmower looses power. Sounds like it is running on one cylinder. Have changed spark plugs, air filter, gas filter, drain gas, pulled fuel cylinoid from bottom of carbarator and drained. Replaced and...
Hi, first check the oil. If it smells like fuel, change the oil. Secondly if oil smells ok, check the valve clearances and adjust if incorrect. Let me know if the oil smells like fuel and I will help with a fix to stop it happening again. Regards Phil.
Aug 05, 2011 | Craftsman 26 Hp 54" Deck Yard Tractor
Lawnmower will not move in gear with motor running
Hi
Check to see if any oil leaks between rear wheels where the tractor was parked. Also make sure hydrostatic disengage lever, at rear of tractor by hitch, has to be pushed in.
Apr 05, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
127 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
