Question about Soyo DYLT032D 32 in. LCD Television
We have sound but no picture at all... work the night before, next morning, nothing.
  • Soyo Master
  • 17,130 Answers
Check the Pico fuses fromthe power supply to the main board, the convergence board. trace using the power output from the power supply. if you notice any suspected components visibly showing out a fault like a capacitor or a burnt resistor, check it out and replace.
Check for possible dry solder joints or failure of the IC.
Remove plug off while checking and test by tapping board for any loose connection.
Posted on Aug 27, 2010
  • Bud Martin
    Bud Martin Aug 27, 2010
    First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
    if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.
    If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
    Please see my basic troubleshooting guide here: http://www.fixya.com/support/r5093881-lc...
    http://s807.photobucket.com/home/budm/al...
    http://en.wikipedia.org/wiki/Capacitor_p...
    Parts: www.shopjimmy.com
    Capacitors kit: http://lcdalternatives.auctivacommerce.c... he can make you a set of caps.
Tv wont turn on
Check all the connection sockets on the main power supply board for any loose fitting. Re-seat them all, and check. Contact any service technician. Gopakumar Gopalan Google
Feb 16, 2014 | Polaroid Televison & Video
No signal and sometimes picture freezes
sometimes you can have weaker signal, and pictures freeze...
it can be caused by bad weather, by thunderstorms, heavy rain....
you can't do anything about it, just get stronger antena....it can improve your gain from signal, but never for 100%
Jan 13, 2014 | Polaroid Televison & Video
My philips 32pf 5531d/10 has no picture by sound?
Check for the Ac power cord, the fuses and the power supply Module.
Nov 04, 2012 | Televison & Video
Black screen with sound
My 47" LCD Smart T.V. was working fine last night. I got up this morning and I have sound but no picture. The VIZIO icon lights up as usual but I get no picture, only sound. From the time I turned it on, nothing appeared on the screen. I have already tried unplugging it for a while and still nothing.
Oct 24, 2012 | Vizio VO47L 47 in. LCD TV
Power
  • Sorry but it can't be fixed without knowing how a tv works on the inside. The problem is on the inside possibly in the horizontal section and should be taken to a repair shop
Dec 31, 2007 | JVC AV-32730 TV
Crashing sound on Protron 32 TV
no sound, everything was working fine the night before. woke up the next morning, and turned the tv on, and there was no sound at all. nothing from the TV, DVD, and nothing from the Computer. Please help. curtisw_1999@yahoo.com.
Dec 26, 2007 | Protron PLTV-32 Television
No power to the television
Dont know if this will help, try leaving it unplugged over night, thaught I saw that solution in a blog somewhere a while ago.
Dec 23, 2007 | Akai PT5598HD 55" Rear Projection...
Power
if the tv set have no sound no picture, they call it dead set your tv need a repairman technician to trace your tv what was part was damage. but if your tv has standby mode mybe you entered the timer code.
Aug 20, 2007 | JVC AV-32D305 32" TV
Soyo DYLT032D 32 in. LCD Television Logo
26 people viewed this question
Top Soyo Televison & Video Experts
ted dux
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
