My heat and AC fan wont come on and all the fuses are fine
What I would do is pull the fan blower motor speed switch, plug the wires back into it while you're holding it in your hand, run the car, and check with a multitester and see if you are getting voltage at the switch. Should be something like:
High=12-14 volts
MHi=8-10 volts
MLo=4-6 volts
Low=2-4 volts
OFF=no voltage
If you get voltage but the fan still doesn't work, then it's either a bad ground, or the motor is bad. If you can access the blower motor wire connections(sometimes its easier to try this with it removed from the vehicle), then you could try jumping the blower motor at the wiring connection with a known good 12 volt source, and if you STILL can't get the motor to spin then it's seized up or it's just a bad motor. If you have the motor removed, try spinning the squirrel cage by hand. Is it stiff? Seized? Probably need a new one if it doesn't spin freely by hand.
Hope this helps!
