Question about Zanussi Dishwashers
The water is not going into my dishwasher when i turn on to wash
  • Zanussi Master
  • 43,501 Answers
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Aug 29, 2010
Why does my dishwasher make the noise, that water is going into it, and the cycle moves but no water going into it?
probably the main control board turning the discharge pump on while it is filling . call your repair man
Oct 29, 2015 | Dishwashers
Water will not come into tub to start washing dishes
Paul,If this dishwasher has just been installed or there has been some plumbing work done in the sink cabinet. Please check the shut off valve for the water going to the dishwasher. it is connected to the hot water pipe in side on the sink cabinet. if the shut off valve is already turned all the way to the right it is in the closed position. This would mean the water is off. turn the valve to the left to turn the water on.This is very common after new counter tops are installed.Please also check water line going to the dishwasher to be sure it is not pinched
Hope this helps
Nov 10, 2011 | Frigidaire Dishwashers
Maytag dishhwasher turns on but no water is going in to wash dishes and the heating element is on
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Jun 01, 2010 | Maytag MDB9600A Jetclean II Built-in...
Water not going into dishwasher. We turned off the water temporarily because we first had a leak. Fixed the leak and tried the dishwasher. It would not drain, the garbage disposer was clogged. We put in a...
Is the drain attached directly to the side of the disposal? If so, you didnt take the "knock out" out. Where the drain goes for the washing, there is a block in case the house does not have a washing machine. U need to knock this out with a screwdriver and whatever (plyers or hammer). Not tough to do. Good luck
Jul 09, 2009 | Hotpoint 24 in. HDA2000Z Built-in...
When we turn on the dishwasher it doesn't fill with water
Hi I am vortash it sounds like this is a water level switch ( vacum ) problem it is telling the machine there is water in and the machine carries on and doesn't open the flow valve to put the water in .. as it thinks it is full . or the controller is faulty and need s repalcing .. try replacing the level control first as this would be cheaper than the programer.. Regards Vortash
May 31, 2009 | Whirlpool 24 in. DU940QWD Built-in...
DIshwasher wont start, flashes pre-wash and was lights
1) Ensure the dishwasher is turned off. 2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher) 3) Pour powder indo the dishwasher 4) Turn the dishwasher controller to the top position (the 12 o?clock position) ? this is the eco-setting. 5) Press the on/power button on the dishwasher, so that it now turned on (a light will display) 6) Move the dishwasher controller to the ?R? position (it?s on the very left), and leave it there a second or two. 7) Move the dishwasher controller back to the eco-setting (the 12 o?clock position).
Apr 19, 2009 | Ariston Technologies L63SNA Stainless...
Frigidaire fdb1050rem2 dishwasher will not drain during was cycle
Checked water temperature at water heater. It was at 110 degrees. Turned water heater up to 125 degrees. Dishwasher works perfectly now.
Mar 30, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Hot water for dishwasher
Hi thanks for the question. before you start your dishwasher turn on the hot water tap at sinc let the water get hot . then start the dishwasher it will be hot enough for the rest of the cycle. thanks the appliance doc
Oct 06, 2008 | Dishwashers
Dishwasher
I have a kenmore dishwasher (about 10 year old) it won't turn on. It just buzzed when set to wash. What can I do?
May 15, 2008 | Dishwashers
Amana Dishwasher
sounds like something is jamming your wash inpeller start at the washer arm and go down till you get to the wash impeller and see whats sticking it like broken glass small peice of bone toothpick etc
Jan 19, 2008 | Dishwashers
Dishwashers Logo
65 people viewed this question
Top Zanussi Dishwashers Experts
paulcarew
Owen Barnes
Gerard Curran
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
