Question about Akai LCT2715 27 in. LCD Television
When power is engaged only thing happens is a clicking noise and a flashing indicator source light
  • 2,318 Answers
The power supply has failed on your LCD due to defective capacitors leaking or bulging. There are 17 capacitors that should be replace to restore the power supply functionality.
I could also repair the power supply.
Let me know if you need further assistance.
See the picture below
Posted on Aug 27, 2010
Jazzy 600 powewr chair intermittion operation
The small click noise is the parking brake releasing to allow you to drive. the flashing is called a flash code that will give you an idea of what is wrong. count the amount of lights flashing this would indicate the problem. Post the amount of lights flashing and some could give you the meaning of the code.
Apr 28, 2016 | Pride Mobility Jazzy 600 Powered...
I have a 1998 explorer and the 4wheel drive will switch on like it should and the lights do not blink or anything but I can tell the rear end doea lock in low but never any power to front axle in any...
On these issue,there are few solved help links for troubleshooting the issue easily.-------
Click the link below:---
No 4x4 light on dash?
http://repairhelpcenter.blogspot.com/2011/12/no-4x4-light-on-dash.html
4X4 Truck makes roaring noise in the front end?
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
Car will not go into 4WD high or 4WD low?
http://schematicsdiagram.blogspot.com/2011/12/car-will-not-go-into-4wd-high-or-4wd.html
4 wheel drive system will not disengage?
http://technoanswers.blogspot.com/2012/01/4-wheel-drive-system-will-not-disengage.html
4WD light is flashing and beeping? NO 4WD high?
http://schematicsdiagram.blogspot.in/2012/02/4wd-light-is-flashing-and-beeping-no.html
2002 Jeep Wrangler: 4WD Idiot Light is ON?
http://technoanswers.blogspot.in/2012/06/2002-jeep-wrangler-4wd-idiot-light-is.html
Traction control switch will not engage on 4WD High or Low
http://whoisbyme.blogspot.com/2012/10/traction-control-switch-will-not-engage.html
4WD light flashing and 4WD will engage after few minutes
http://repairhelpcenter.blogspot.com/2012/10/4wd-light-flashing-and-4wd-will-engage.html
2008 Toyota Tundra: 4x4 Wheel Drive Light is Flashing?
http://technoanswers.blogspot.in/2012/05/2008-toyota-tundra-4x4-wheel-drive.html
4x4 front differential will not engage the axle on ford?
http://technoanswers.blogspot.in/2012/02/4x4-front-differential-will-not-engage.html
4x4 will not engage on Ford F150? http://technoanswers.blogspot.in/2012/02/4x4-will-not-engage-on-ford-f150.html
Dodge Ram 4x4 light keeps flashing 4X4 LOW LIGHT IS FLASHING ON DASH
http://technoanswers.blogspot.in/2012/09/dodge-ram-4x4-light-keeps-flashing.html
Ford 4x4 front wheels will not engage?
http://technoanswers.blogspot.in/2012/02/ford-4x4-front-wheels-will-not-engage.html
These details will help.
Thanks.
Nov 23, 2012 | Cars & Trucks
I am currently having the problem of not hearing the motor actuator on transfer case making any noise when i push in the 4x4 button on isuzu trooper 3.0.i am getting no 4 wheel drive and the light on dash...
On these issue,there are few solved help links for troubleshooting the issue easily.-------Click the link below:---No 4x4 light on dash? http://repairhelpcenter.blogspot.com/2011/12/no-4x4-light-on-dash.html
-----------4X4 Truck makes roaring noise in the front end?
------------2008 Toyota Tundra: 4x4 Wheel Drive Light is Flashing? http://technoanswers.blogspot.in/2012/05/2008-toyota-tundra-4x4-wheel-drive.html
----------4x4 front differential will not engage the axle on ford? http://technoanswers.blogspot.in/2012/02/4x4-front-differential-will-not-engage.html
-------4x4 will not engage on Ford F150? http://technoanswers.blogspot.in/2012/02/4x4-will-not-engage-on-ford-f150.html
------------- Dodge Ram 4x4 light keeps flashing 4X4 LOW LIGHT IS FLASHING ON DASH http://technoanswers.blogspot.in/2012/09/dodge-ram-4x4-light-keeps-flashing.html
----------Ford 4x4 front wheels will not engage? http://technoanswers.blogspot.in/2012/02/ford-4x4-front-wheels-will-not-engage.html
-------------These details will help.Thanks.
Nov 22, 2012 | Cars & Trucks
We heard a "pop" noise
The pop noise could be a capacitor poping its top up.This is a common problem to most TV sets today. Usually located at the power supply board.Once this parts give up it usually shorts the circuit and blows a fuse.Replacements of these parts mentioned will often remedy the problem.Flashing power indicators indicate a problem.If you have the chance of counting how many the blinks are I could have told you the problems code are and the source of the problem.
Dec 05, 2010 | Akai PT46DL10 46" HDTV-Ready Television
When i plug in my tv it has a sound then it stops, the on light just blinks and it dose not stop
Is the blinking light the power indicator or the lamp indicator? Is it sending a diagnostic code such as five flashes and a pause, repeated? If the lamp indicator is flashing, the bulb is burned out.
If the sound does not come from the speakers, and is not a soft click from a relay (electromagnet-operated switch), but is a crackle, thump or squeal, then you have either a high-voltage breakdown or a shorted component in the power supply.
Other possible noise sources are the lamp cooling fan or color wheel (spinning disk).
Whatever is going on, the set has detected a fault and is turning itself off to protect other components. The noise could be normal startup sounds that you don't notice in normal operation because they aren't masked by audio from the program material, or it could be a cutout relay in the protection system.
Oct 23, 2010 | Philips 60PL9200D Projection Televisions
My dell home computer is making a clicking noise and will not start
would help if you can get indicators from the system like the color of the light on its power button and if it is blinking, the system may also have 4 small lights in its front or back panel which will also give indicators of the system. Things you can try to do to start isolating the fault is to remove the power cables and the data cables from all your drivers (hard disk, dvd/cd), and remove and reconnect the front I/O panel where the power button is located, remove and reconnect the power connections to the motherboard, remove and reconnect only a 1 working memory module, then try to turn it on again. Try to determine if any indicators change and try to pinpoint the source of the noise. it is possible that this can be from the hard drive, the power suppy or the fans on the system board. if it is from the fans or the power supply, those are the components to replace. if the noise stopped, try to reconnect the hard drive first and test it, then proceed with the CD/DVD drive. If you've isolated the fault, you can then proceed to get the needed replacement.
Sep 06, 2010 | Computers & Internet
My palm doesn't seem to be charging at all. The
The clicking noise usually indicates a hard drive problem. There are replacements available. You can get a replacement hard drive or a flash card drive. Of the two the flash drive is by far the better choice.
Nov 06, 2009 | Palm LifeDrive Mobile Manager Handheld
2002 Ford Taurus has no power. No head lights no dome light no horn blah blah. Ok first of all my cars alarm kept going off by itself off and on for 2 weeks. I come out to start the car and it goes click...
One possibility is that the battery terminals are either corroded or not tight to the battery posts. Second, the battery itself may have seen its days. Try another battery of simply replace it. If the problem still exists, the have a mechanic inspect the main wiring from the battery to fuse block. Your alarm device may have its own battery source. The tick tick are the cars systems relays trying to engage, but there is not enough power for them to engage.
Aug 18, 2009 | 2002 Ford Taurus
TV and Vedio-Projection televisions
what i would do is crack into the tv and watch the individual parts being careful not to unplug anything while you take the back panel off.....turn it on and see what happens. let me know what happens
Sep 30, 2008 | Televison & Video
Akai LCT2715 27 in. LCD Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
