Question about Electronics - Others
My Faroudja DVP 2200 isn't working. It won’t turn on anymore. I removed the cover and checked the fuse – and it was fine. I am not sure is there is another fuse. I had some previous issues where it wouldn’t turn off when I pressed the power button, but it would turn off if I unplugged it; it would power on normally. Any ideas? Faroudja got acquired so getting tech support has been difficult.
    Problem Solver:
  • 10 Answers
I would check ac plug change it if you could it probably had a short and maynot be visible also some fuses made be hidden on underside of board so check good you could overlook it easy
Posted on Aug 27, 2010
I have a electric roper dryer. Will not turn on. Worked fine this morning. Changed loads now won't turn on at all
Remove the back dust cover and check the blower fuse. (skinny white one screw 2 wires) If it is open remove and clean the filter housing, Clean the vent. My home video shows all the components and how to check.
Jun 28, 2013 | Dryers
Why isn't my Logitech Z-5300 speaker system no longer turning on at all?
I have a suggestion that you can try. If the unit is no longer turning on and you're sure the electrical outlet is good (by plugging in another device) and the hand-held control panel is on, as well as the switch at the base of the subwoofer, then try replacing the fuse. The subwoofer on this model has a fuse near where the power cord enters the subwoofer. There is a slotted screwdriver slot on the fuse cover. Using a flat-head screwdriver (or your thumbnail), turn the cover about a 1/4 to a 1/2 a turn and the fuse should pop out. Keep the cover. Replace the fuse with a 4 amp, 125V (or higher) fuse that is a slow-blow fuse. There are fast blow (or fast acting) and slow blow (or slow acting) fuses. You can't replace one for the other. You should be able to find a fuse at Radio Shack. If a new fuse doesn't get your system working again, then something else is broken. Good luck.
Sep 25, 2012 | Logitech Z-5300 Computer Speakers
My Sony dvp NS710H isn't playing most standard, well conditioned DVDs.
Hello
Just clean its laser pickup lens, by inserting a lens cleaning disc in to, and play it at least two times. If it doesn't help you, the laser pickup unit should be replaced. The lens cleaning disc can be bought from most of the electronic sparepart selling shops at your town, and won't cost more.
Feb 27, 2012 | Sony DVP-NS710H/B DVD Player
Why is my frigidaire washer not spinning?
  1. Stopped Mid-cycle
    • If your Frigidaire washing machine started spinning, but then stopped, verify that the power cord is still connected to the outlet. See if the outlet blew by plugging in a different appliance into the outlet. See if you blew a fuse. A blown fuse usually is either black or has broken wires. Replace the fuse. If you have a circuit breaker instead of a fuse box, reset the circuit breaker if it's been tripped. Check the lid switch, which is located inside the main housing of the washing machine, near the door frame. If the switch is burned out, order a new part from a Frigidaire parts dealer.
    Pump
    • The pump's sole responsibility is to remove water during the spin cycle. If the pump isn't working properly, see if it's clogged with debris or clothing. Use needle-nose pliers to remove these items. Check the pump pulley, which is connected to the pump. This component must move freely for the pump to work. If it won't turn, purchase a new pump pulley since you can't usually fix this component.
    Lid
    • Check the door latch assembly if the door isn't closing correctly. If any of these components are broken, order a new part from a Frigidaire parts dealer. If you do not, the washer won't start spinning since it believes the door isn't closed. Your Frigidaire washing machine won't start the spin cycle until the lid or door is closed. Always close the lid, and remove any items preventing the lid from fully closing. Always close the dispenser drawer.
    Additional Concerns
    • Never over- or under-load your washing machine. Your Frigidaire washer may not enter the spin cycle if the load is too large, since this can damage the washing machine. Remove a few pieces of clothing. If the load is too small, add a few similar items to the washing machine. Check the internal belt, drive motor and motor coupling. If any of these components are broken or very worn, they may not work properly, preventing the washer from entering the spin cycle. Order replacement parts from a parts dealer. Check the tub and basket bearings, and get new ones if the current ones have broken components or are defective.
Sep 27, 2011 | Washing Machines
My S5211 is 5 months old and was running perfectly. Last weekend I took it out to vacuum house but it would not start. I checked the fuse in the plug but it was fine. I replaced the dustbag but still it...
if you put everything back in place properly it should be working,check dust bag properly seated, and cover reseated, still not working do as planed, take it backto the shop, hope this helps
Sep 01, 2011 | Miele S5211 Deep Black Vacuum Cleaner...
Need to purchase a lamp for a Faroudja DLPHD20
I use www.avprojectorlamps.com
They seem to be the most competitive and next day delivery. I have just looked on theyre site and they don't seem to have anything for Faroudja. I am sure they could source one for you. I usually ring him with my order, he sorts it and has them to me the next day, here is his details: -
Sean O'Neill - 0800 043 3322
Aug 02, 2011 | Faroudja FDP-DLPHD20 Multimedia Projector
My 1999 masda 626 won't start. it turns over but acts like it isn't getting any fuel.
check relays/fuses first then the pump if you know how to test it
the pump is easy to test locate any fuel line unplug it tell a friend to make a quick one key turn if squirts fuel then pump is fine
but check the pump relay first to make sure and to begin with simplest
it seems you can tell it is the pump but you don`t know where to start
Jun 07, 2011 | 1999 Mazda 626
So after getting my car back for the garage my subwoofer isn't working I checked to make sure all of the connections are correct and the settings are there why won't it work
Check to see if your amp is on. You may have blown a fuse somewhere maybe on your amp. Check for proper voltages and make sure the sub isn't blown by pushing on it. If you feel unequal resistance, you probably blew it. Also check the ohms on the woofer.
Jun 06, 2011 | Car Audio & Video
Kawasaki vn1500 2nd gear jumping out
Hi, make sure your lever is adjusted to your foot. You can turn the linkage arm adjuster up or down to get a better throw on the lever. If you don't wear boots when riding, this is always a problem on a Kawasaki due to the positive neutral finder. The fist question you get when you call the Kawasaki Hotline is if the rider wears boots or not.
If adjusting the lever doesn't help the problem is internal. Under the gear change cover the items to check would be the pawl that rotates the drum and the detent arm and spring. If the edge of the pawl is worn, it won't move the drum far enough. If the detent arm or spring isn't working, it will want to drop into a false neutral. I've had very good luck by removing all of the parts and polishing them, removing any burrs and replacing the springs. If the problem isn't found under the cover in the gear change area then the only other solution is to pull the motor apart and inspect the tranny itself.
May 15, 2011 | kawasaki Vulcan 1500 Classic Motorcycles
Power will not turn on - plug is fine
Check the outlet first to make sure there is power. If the outlet is OK then unplug the DVD, flip it over and undo the screws holding the top on, then flip it back over, lift the back of the cover and slide off the lid. Follow the power cord to the transformer, and look for a small glass fuse. Pull out the fuse and make sure it isn't burned out. If it is burned, pick up a replacement at Radio Shack. If it isn't burned out, start looking for a repair shop, although considering how cheap they are these days, you may be better off just buying new. Don't poke around because you could get a nasty shock or do other damage to the delicate components.
Mar 16, 2009 | Sony DVP-NS575P DVD Player
Electronics - Others Logo
62 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
