Question about Dishwashers
When the dishwasher stopped there was about 2 inches of water left in the machine. Trying to start it again is met with an A-3 fault message...this does not appear in the manuals trouble shooting section!
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Aug 29, 2010
LG dishwasher error code after 2 minutes
fault with the programe as it has stoped in mid cycle
Aug 01, 2012 | Whirlpool Dishwashers
In my dishwasher Whirpool ADP 8967 after the washing cycle start the drying cycle when start it I got the error F7 and the machine stop the cycle. Can some one help me?
Hi simone_b_630,
F7 is known as a fill fault.
1) Remove the filters and the mesh filter, clean out the black grid in the bowl carefully. Don't burst the membrane inside it.
2) Try the machine again after resetting it. (Reset it by holding the start button for 8 - 10 seconds)
3) If the fault persists, take off the left hand panel and unplug the flow-meter, located bottom front of the large plastic water matrix.
4) Plug it back on, reset the machine and try it again.
Also make sure the fill hose isn't kinked and that water is actually entering the machine.
* If you found this solution helpful, please rate 4 thumbs up and leave a small testimonial. :-)
Apr 19, 2011 | Dishwashers
KENMORE DISHWASHER CLEAN LIGHT BLINKS SEVEN TIMES M#665.17029403
The thermistor beneath the accumulator inside the sump detects the water temperature as it begins the first 8 minutes of the main wash cycle. During this time, the controller expects the thermistor to detect the 2-4 degrees rise in the water temperature when the first 8 minutes is completed. If the expected temperature rise is not met, the controller will not be satisfied. It will shut the dishwasher down and blink the clean light 7 times. Press the heated dry then normal wash buttons in the same sequence two times. The unit will enter diagnostics mode, but can be stopped by pressing the cancel button. It will clear the fault and makes the dishwasher run normal but the fault will appear again if you have problem in either of the following:
  1. Heater and its circuitry
  2. Water filling
  3. Pumping motor
If the heater is not working, the water temperature will not rise then controller will shutdown the machine.
If there's no water entering the machine, no water will be heated and there's no way the controller through the thermistor can detect any rise in temperature.
If the pumping motor is not working, the water cannot circulate over the heater and be heated. Again, the controller will not be satisfied.
You can bypass this fault detection feature by filling the machine either with extremely cold or extremely hot water. Water colder than 62 or hotter than 160 degrees Fahrenheit will make the controller not to check for a temperature rise but rather continue on the next cycle.
Please let me know if the problem still bother you.
Dec 03, 2009 | Refrigerators
Clean lite keeps flashing will not start whenstart
The thermistor beneath the accumulator inside the sump detects the water temperature as it begins the first 8 minutes of the main wash cycle. During this time, the controller expects the thermistor to detect the 2-4 degrees rise in the water temperature when the first 8 minutes is completed. If the expected temperature rise is not met, the controller will not be satisfied. It will shut the dishwasher down and blink the clean light 7 times. Press the heated dry then normal wash buttons in the same sequence two times. The unit will enter diagnostics mode, but can be stopped by pressing the cancel button. It will clear the fault and makes the dishwasher normal but will appear again if you have problem in either of the following:
  2. Water filling
  3. Pumping motor
You can bypass this fault detection feature by filling the machine with either extremely cold or extremely hot water. Water colder than 62 or hotter than 160 degrees Fahrenheit will make the controller not to check for a temperature rise but rather continue on the next cycle.
Dec 01, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Same problem. 2-3 inches of water left in the dishwasher at end.
Inspect for plugged drain screen. Sometimes you have to take apart the bottom area for access...
Sep 18, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Dishwasher adp 4601 when switched on the pump activates.and after 2 mins start lamp bliks and pump goes off
The number of flashes indicates the fault. Reset machine by holding down the start button for 3 secs, then start a new cycle. If fault reoccurs, the number of flashes indicates fault eg 3 flashes, stop, 3 flashes stop, indicates F3 fault.
Faults listed below- advice on repair depends on which fault your machine is indicating, but may give you an idea of what to look for
1flash=NTC (temperature sensor) break- NTC outside normal range.
2flash=water leakage-float switch in base activated.
3flash=heating fault(check element.NTC,control board).
4flash=drain error-blockage in pump or drain system,or faulty water indicator switch.
6flash=water inlet fault-check inlet valve, check inlet hose not kinked
7flash=flow meter failure (flow meter measures water intake volume-large plastic weir located on left hand side of machine-reomve side panel to access)
These a most common faults, but further advice on repair requires counting flashes when fault occurs.
Aug 09, 2009 | Whirlpool Dishwashers
Hotpoint FDW60 Flashing lights 3 and 5
Is it possible that water has gotten inside the controls that could have caused the flashing lights? Kind of like spilling water on a calculator, everything seems to go haywire.
Jan 11, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Whirlpool dishwasher ADP 4732AL
sound like you have a valty inlet valve if your model has the valve built into the hose you will have to replace the hose assy.
Mar 20, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
IDL705 dishwasher showing error code
Indesit IDL700 first two green lights flashing and cycle stops with dirty water left in the machine. CAUSE - blocked or jammed drain pump. SOLUTION - First remove all the filters inside the machine, syphon or sponge up all the water in the sump and check for any obstruction over the fine grill at the very bottom. (we had a pistachio shell covering the hole!). If this doesn't cue it you will need to gain access to the pump. First, turn off the power. Gently lift the machine onto it's side (be ready for some water to spill out!). Remove the bottom plate (6 screws) and disconnect the sump float switch. Remove the single screw retaining the pump to the bottom of the machine and rotate to remove. You should be able to see the rotor blades. With your finger check to see if the pump rotates freely. To dismantle the pump, remove the 3 screws and separate the two halves. Our pump was jammed with an apple stalk!. Reassemble and connect any cables. Apparently this is a known problem with these machines and can be prevented by assembling the filter system correctly and pre-rinsing plates etc. before placing in the dishwasher.
Sep 19, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
F4 Fault indication
F4 is a water inlet fault. It doesn't make sense if you have this fault indication with water flowing into the unit. Does the dishwasher drain properly? Usual suspects for an F4 indication would be a clogged inlet line, water supply turned off, bad fill valve, or a control board failure. Let me know if this helps, or give me a little more information on what you have done to correct so far.
Jul 09, 2007 | Asko 24 in. D3350 Dishwasher
Dishwashers Logo
52 people viewed this question
Top Dishwashers Experts
