Question about Kodak EasyShare CX7530 Digital Camera
Can no longer copy from internal to memory card. Keeps saying "Memory card requires formatting." When I choose "continue" the camera tries formatting then goes back to the original screen saying "Memory card requires formatting." I bought a new memory card and it does the same thing. I formatted the new one on my computer and then tried it in the camera with the same result. Help! My mom is reeming me for some photos of her granddaughter's first day of kindergarten. Thanks, Kay lynn
  • Kodak Master
  • 3,289 Answers
In the manual, page 21 & 21 describe how to use the camera to format your choice of either the memory card OR the internal memory. If you format the internal memory, images stored there will be lost.
Once you format in the camera, you should be able to use the card if it is no larger than 2GB. It appears the camera does not support cards greater than 2GB.
Please rate this reply - good luck!
Posted on Aug 27, 2010
Why is my camera going round and round in circle when trying to format my memory card?
I'm suspecting that you are trying to use a new 4GB or larger SDHC card with your older model camera. Please note that your model camera can only use 2GB or less standard SD cards (and NOT SDHC). 2GB SD cards are inexpensive, and still available on Amazon.com if your local store no longer carries them.
Nov 10, 2011 | Kodak EasyShare DX7590 Digital Camera
Can't get to set up menu with my new memory card in camera to set it up to use the memory card instead of the internal memory. Camera keeps saying memory card needs formatted-continue or cancel-I go to...
1. with no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory.
2. insert the card and do the "format" thing again from the menu as you just did for the internal memory.
Sep 24, 2010 | Kodak EasyShare C743 Digital Camera
My kodak camera keeps saying that the internal
The internal memory is small. Your camera will continue to write to it until you erase the pics from it. Here's how...Remove the memory card. Download any pics you want to save from the internal memory. Go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Insert your card. It should work properly now. Promise yourself to never use the internal memory again.
Apr 29, 2010 | Kodak Easyshare C182 12MP Digital Camera
Camera keeps saying internal memory is full, even after putting a
Your internal memory is separate from your memory card. Think of it as two folders, the internal memory cannot be removed, and the memory card is one you can take with you. You can put new memory cards in it all day, the internal memory will still have pictures in it. You may wish to consider copying all internal memory to the memory card. To do this, make sure your camera has a memory card in it. View pictures on your internal memory, then from the menu option select 'copy all images to external memory.' In doing this, all of your photos will be moved, you can then clean out your internal memory by deleting everything/formatting it. :)
Apr 04, 2010 | Kodak EasyShare Z812 IS Digital Camera
When I install a memory sd disk, the camera says it needs to format. I format it and it then says it has to format. It just keeps saying that it has to format and wont alow me to take any pictures at all,...
Try to format the memory card on your computer first. After that, test the camera and see if it can detect the memory card.
To format the memory card on your computer, you need to have a card reader or a memory card slot on your PC. Once your mmc gets detected, go to My Computer and then right click on the Memory card and then click Reformat. Choose default settings and then check Quick Format.
Let me know how it goes.
Dec 24, 2009 | Kodak EasyShare C913 Digital Camera
My cybershot w120 keeps saying no space on internal memory when i have a new memory card in it which is empty. This happened with my last card so now i am thinkng its more a camera problem rather than the...
in your settings is it set to "shoot without card"? this could cause the camera to not use the memory card installed and rely on internal memory which is limited
Aug 26, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
LEXAR 4GB SD MEMORY CARD FORMAT??
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Nov 29, 2008 | Kodak EasyShare CX7300 Digital Camera
Memory card
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jul 03, 2008 | Konica Minolta DiMAGE Xg Digital Camera
    Memory card
    this cam will work up to 2gb sd/mmc
    what's the capacity of your card? if it's above that, it's really not gonna work with this cam
    if your card is 2gb or lower
    2 possibilities:
    defective card - please try another card
    camera memory reading problem - arrange repairs with kodak
    Jan 20, 2008 | Kodak EasyShare C663 Digital Camera
    Kodak EasyShare CX7530 Digital Camera Logo
    206 people viewed this question
    Top Kodak Cameras Experts
    Tony
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
