Question about Linksys EZXS55W EtherFast 10/100 5-Port Workgroup Switch (12503060)
I have a Linksys 5-port switch connected to a cox cable modem and I'm trying to use it to connect two computers at the same time. Only one works at a time and I have to reset the switch and modem to get the other port to connect. Any suggestions on how to get both computers connected at the same time?
    Problem Solver:
  • 13 Answers
Because the cox cable modem will only bind to one mac address (computer). You need to purchase a router, any router linksys, dlink, will do, get a wireless one so you can setup wifi as well. Plug your cox cable modem into the wan port on the router, plug your pc into one of the ethernet switch ports, you can use your web browser IE to login to the router and secure your wifi signal, power cycle your modem to make it bind to the new router. Most linksys dlink are programmed for a class c network, you could in theory put 254 devices, computers on your connection now.
Posted on Aug 29, 2010
Scientific atlanta modem is not showing that it is connected to my linksys wireless router
Seems to be that you have cable modem from Scientific atlanta.
  1. Turn off the modem and the router.
  2. Connect the modem to router with ethernet cable on internet port
  3. and computer to router's port no 1.
  4. power up your modem and wait for 2 minutes
  5. then power up your router and wait for 2 minutes and try to go online on computer.
  6. If not , then reset your linksys router by pressing your reset button at the back of the router with help of a pen for 10 sec.
  7. then follow the steps again 1 to 5
  8. try to go online.
  9. if still not , the open up a browser on computer
  10. type 192.168.1.1 in the address bar and hit enter on the key board
  11. leave the user name blank and type admin in the password box
  12. click on subtab of mac address clone under set up tab
  13. click on enable and click on clone my pc's mac tab.
  14. then click on save settings.
  15. and follow the step 1 to 5.
May 02, 2014 | Linksys Wireless-G WRT54G Router
Hi, Im using Linksys SR224 24 ports as my main switch. I got a poor internet connection, this problem occurs few weeks ago. I tried to connect my modem through a LAN cable directly to my server and...
Try a brand-new cable between the modem and the "uplink" port on the router.
Try a brand-new cable from one of the "LAN" ports to your computer, and test to see that you get a good connection.
Jan 04, 2011 | Linksys SR224 (srw224) 2x1000 Mbps...
I run 3 computers connected to the internet using the Linksys EtherFast EZXS55W 5x10/100 switch. Switch is connected to COX cable broadband. Any issues with "crashing" on this switch? Seems...
Hi, I would recommend downloading the latest firmware for this device and then se if your "crashing" goes away.
If you plug directly into the cox modem do you have problems?
If that doesn't work I would replace the Cat 5e network cable from the switch to the cox modem.
If that doesn't work replace the coax cable from the cox modem.
If you continue to have issues replace the switch.
Dec 02, 2010 | Linksys EtherFast EZXS55W 5x10/100 Mbps...
I have Time Warner Cable for internet and Vontage cable for my phone thru my internet. I'm trying to connect a Linksys router for my wireless laptop. I also have a Netgear switch connected to Time Warner...
If you purchased a Linksys wireless roter then you shoul not need the switch anymore-
Try going directly from your time warner modem into the Interner/WAN port on the router and then plug your desktop computer and the vontage phone system into 2 of the ports on the router. After everything is hooked up you will probably need to power cycle for it all to work correctly.
Please power cycle in this order:
Reboot modem - then Router- then Vontage phone system.
Hope this helps
Apr 09, 2009 | Linksys -Cisco Wireless-G VPN Broadband...
Can I use 2WIRE 2701HG-B router in COX internet connection
No. A router has 2 main interface types WAN (for the internet connection side, and LAN (for the home network side) the 'LAN' side often has up to 4 ports and wireless connectivity for the home network.
The most common routers available at electronics retail use a CAT-5 connection for the WAN ports and the LAN ports. Your DSL modem/router uses a phone line input for it's WAN port, which uses a signal type that is incompatible with the cable modem output.
If COX doesn't offer a router with the cable modem package, you can go and purchase and common brand of home networking router, and attach it to the output of the cable modem.
Feb 28, 2009 | 2wire 2700HG-B Router (2700HGB)
Well i had just bought a lynksys router from my friend with no software cd so right now i am trying to download the software online so when i switch my cox modem with the linksys modem i want the software...
You should be able to get any software that you need from LinkSys.com but I have a couple of quick questions first:
1. Is the LinkSys unit you just purchased a router or modem?
If the unit is a router, you are still going to need a Cox compatible modem. If the unit is a modem, you will still need a router to complete the network setup unless LinkSys makes a combination cable router/modem, and I haven't been able to research one.
2. If it is a modem, is it a cable modem and, if it is, is it Cox compatible?
According to the Cox Web Site, the only models of LinkSys modems that are currently compatible with the Cox High Speed Cable Internet Service are:
BEFCMU10 v3
BEFCMU10 v4
WCG200
WCG200 v2
CM100
In this particular case, you may need to contact LinkSys and/or your Internet Service Provider. In most cases, they will not only tell you exactly what type of equipment you need, they will also talk you through setting up the network once you have the equipment - usually at no charge.
Graye
Nov 25, 2008 | Computers & Internet
Hooking up rounter to cox cable
hello!
-- what is the operating system of your computer?
-- is the router working fine before or is it a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
May 27, 2008 | Linksys Wireless-G WRT54G Router
Changed from DSL to cable
Usually DSL connections require ppoe while cable uses dchp You need to log into your router and change the settings
Dec 29, 2007 | Linksys EtherFast EZXS88W (DSLSEZXS88W)...
Computers & Internet Logo
317 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
