Acoustic Solution LCD tv Model LCD37805HD Sorry 37 inch Switched on and coulour rotates Red Green Blue white black Etc Sound is working.
  • 4 more comments
  • Chris Welsh Aug 28, 2010
    Yes I would like to replace board, I have 5 of these so spare parts should not be a problem.
    Kind Regards
    Chris Welsh
    Could boards from same make but smaller size work?
    Also If your have tech manual that would be great.
    of the 5 2 have blinking colours(above solution)
    1 has no picture but has power
    1 has red tinge but picture works albeit red tinged
    Are all fixable ?
    Hi I have just added comment.
    Yes I would like to fix.
  • Chris Welsh Sep 02, 2010
    What is approx size of this board. I can see Power supply board. Then Large board a4 size I believe is the main board. There is also a board by buttons about a5 in size(pc free board replaced this no difference) there is also very small board seems to control s video in.
    Kind Regards
    Chris Welsh
  • Chris Welsh Sep 03, 2010
    HI I replaced tcon board with no difference. Then replaced main board and now tv works.
    Do you know where I can order these main boards from Part no MB22-2 336974 I am having difficulty in finding a supplier.
    Kind Regards
    Chris Welsh
  • Chris Welsh Sep 04, 2010
    Red sticker on board =31374
    Green Sticker on board =mb22-2 336974 s/10 ha rohs 25/10-24/8-11
    Purple sticker on board = 26278508 37" 20337444 LGX4 NT123-ING-29
    Sorry printed on board itself is 17MB22-2 021106 Although I assume these are standard boards for all types of lcd tvs They just have different components added to them. Model no of tv is LCD37805HD.
    Hope this helps
    Kind Regards
    Chris Welsh
  • 4,889 Answers
You have a faulty t-con board. Have seen this problem a 100 times this week. Replacing it should resolve the issue. If you want to do it yourself then let me know and I will give you detailed instructions in replacing it. Board costs about 75-100$
Posted on Aug 27, 2010
  • 3 more comments
  • eagle338
    eagle338 Aug 28, 2010
    No you Cabot use a part from a smaller set unless the part number is exactly the same. Yes it should fix all color related problems. I do not have a service manual for this set but it's pretty straight forward. There is a small board next to the main audio/ video board. It has a pair of ribbon cables that go into the panel. Sometimes the t-con board and the main board are covered with large metal plate. If that is the case then you should first unscrew tue metal plate from the chassis. Some safety instructions for you
    1) Unplug the set from the power supply before you start working on it.
    2) Never touch the capacitors. These things hold residential voltages that are potentially lethal.
    3) Always touch a metal object for a few seconds before starting the repair. This should help you get rid of the Electro Static discharge that can damage the circuits on the PCBs.
    If you need any further info please feel free to let me know.
    Sai.
  • eagle338
    eagle338 Sep 02, 2010
    There is a board that has a pair of ribbon connectors going into the panel. That is the t-con. Its located next to the mainboard(usually). However in some cases it is attached to the panel itself. If you still can't find it then get me the part numbers of all the boards you can see so that I can tell you which one of them is the t-con.
  • eagle338
    eagle338 Sep 03, 2010
    That does not look like the part number. Can you get me other numbers off the board ?
  • eagle338
    eagle338 Sep 04, 2010
    Anything before mb coz acoustic boards start with 17mb 22
  • eagle338
Acoustic Solutions LCD37805HD. When I turn on the main power button on the TV, instead of the blue standby light only coming on, the screen turns on and flashes alternately between red, green and blue
In most cases, scree flashes will be due to a faulty main power supply regulator board. If the DC voltage comes out from it is abnormal, this could happen. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 10, 2014 | Televison & Video
Acoustic solutions tv screen flashing coulour blue red and green what is the problem and how to solve me help please i need help
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
These flashes are fault indications, called blinking codes.
May 22, 2014 | iLO 3200 32 in. LCD Television
Color problems vizio lcd hdtv
If your tv has a custom settings area, first turn all color down on set so picture looks black and white. Now in color settings look for red blue and green color bars. Use the bars until the picture looks as true to black and white as possible. Also, try changing color temp.
Dec 21, 2013 | Vizio VW37L 37 in. LCD HDTV
TV picture goese black and white
Check your cables on the back of the TV and cable box. You either have it connected wrong, or they are loose. If you are using red green and blue, make sure that you are tightly in the red green and blue connectors. If you are using yellow white and red, then make sure you don't have the yellow in the green spot.
Mar 20, 2013 | Dell W3706MC 37 in. LCD HDTV
I have a 37 inches Scotts Akai tv that has a red screen, blue screen, white screen and green screen that continually rotates through the screens. Any idea what the issue is?
I would look in owner manual to see if a demo mode exists for this set or call the maker to see if a known issue in this model.
Oct 30, 2012 | Scott LCT37SHA TV
37 inch lcd37805hd tv my screen has gone black but i can still hear the sound
The Inverter is the most likely cause replacing the inverter board should solve the issue. You can get a replacement board at www.tvcircuitboards.com if you dont see your model listed send them a email with your model number by hitting the contact us button on their website.
Aug 05, 2012 | Televison & Video
Bush lcd tv has sound but no picture when switch on tv screen is blue then goes black and you can hear the proggramme that is on
acoustic solutions lcd tv when i switch it on the screen flashes blue, green then red no picture??? it was working ok last night any ideas?
Jan 23, 2010 | Polaroid FLM-2632 Television
LCD TV Wii only displays black and white - no colour no sound
You have to option in LCD Source In-Put.All LCD Have this In-Put
Com posit-Yellow/Red/White (AV)
In LCD Select AV Mode After That Connect Yellow /Red/White as per color pin given in your LCD.
Component-Green/Blue/Red
If you have Component in put in your LCD than select from source component mode for Red/Blue/Green.
Dec 26, 2009 | LG 32LG30 32 in. LCD HDTV
Televison & Video Logo
445 people viewed this question
Top Televison & Video Experts
