Question about Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer is flashing code f11
    Brigadier General:
  • 3,513 Answers
Hi
The F11 error code is a communication failure between the 2 control boards. This includes both boards & the wiring harness as potential defective components. However, this is usually the main machine control board that needs replaced.
Try to use a microscope or a magnifying glass to see any solder problems around the relays or anywhere else. Try to clean all the edge connectors with an ink eraser.
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Posted on Aug 27, 2010
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    What does f23 error mean?
    Display shows an error code - Front-load washer ' Whirlpool ...
    https://www.whirlpool.com/...error-code...w...
    Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
    What does error code f23 flashing mean on a Whirlpool ...
    Nov 30, 2015 | Washing Machines
    Whirlpool Duet F11
    Seems that the fault is within the main control panel board. It can be due to failure of the drive relay or semiconductor within and might need a board level service or a replacement of the board.
    Jul 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
    We have a whirlpool duet washer that flashes F11 and will not start, I made sure the door shuts tight and also tightened the plastic latch that was loose, still not responding, please advise what you think...
    The F11 error code means that the motor control unit& the central control unit aren't communicating with each other
    It could be a loose wire connection between the MCU/CCU or either one could be defective
    Gene
    Jul 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    F11 and/or dl code on a whirlpool duet front load washer
    F11 is:
    Serial Communication Error
    Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
    Check for:
    Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
    Check the Drive system for any worn or failed components
    Check MCU
    Check CCU
    Check Motor
    Check Wire Harness
    http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
    Check the above link for a detailed article about the f11 error code.
    Courtesy:JSrock
    Apr 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    NEW CCU for Whirlpool Washer
    I found this site, they actually repair the CCU for you. Mainly for the F11 Error Code. I see on the site that they have repaired 95 of them with 100% feedback.
    http://cgi.ebay.com/Whirlpool-Duet-Kenmore-HE3T-CCU-Repair-For-F11-FDL-Code_W0QQitemZ230397337074QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item35a4c05df2#ht_2034wt_1165
    Apr 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    ERROR CODE F71
    The following list of codes indicates an electronics communication problem with the washer:
    Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
    Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
    To remove the error display, press Pause/Cancel twice.
    If Pause/Cancel does not work:
    1. Unplug washer or disconnect power for one minute.
    2. Plug in washer or reconnect power.
    3. Re-select the cycle and press Start.
    NOTE: If the error remains on the display, call for service.
    Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet Error Code F11
    its your ccu board under top in back easy to change about 300.00 that is f 11 code "plz"
    Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool duet wahsher
    PLACEHOLDER FOR ART
    NOTE: If the error remains on the display, then call for service.
    please do not forget to rate and comment about your experience with fixya today.
    Aug 18, 2008 | Whirlpool Washing Machines
    Duet Washer not working after a year
    F11 means that the motherboard is not talking to the computer that contols the drive motor Fdl is a door lock failure code - i had this exact issue with several and the motherboard resolved it, unfortunately it retails at $324.99
    Sep 28, 2007 | Whirlpool GHW9300 Duet Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    Dan Webster
    Dan Webster
    Sal DeAngelo
