Question about Car Audio & Video
My amplifier fuse
I have 2 10" kicker subwoofers and a 1200watt sony xplod amplifier. the amplifier has 2 40amp fuses, and i was told i would need to rewire all my equipment to keep the fuse in my battery wire from blowing constantly like it does. is there any truth to this, or is it possible to just find a 80amp fuse from a car audio store of some sort?
  • 631 Answers
The wire must be able to handle 80 amps of current. You would need 6 gauge or larger for 80 amps. If you have a smaller wire and you use an 80 amp fuse, it will be a fire hazard.
Posted on May 06, 2008
Can I bridge my 1200watt 2channel sony xplod amplifier?
How many ohms at two channels, remenber ohms law, amp should be stable at lower ohm RMS wattage..whenn you say 1200 watts its that full wattage, now you got a RMS wattage..What is it?
Apr 04, 2016 | Sony Car Audio & Video
How do I Wire my 12" kicker cvs to a sony xplod 800-watt amp for best possible sound.
I would first need to know what the impedance level is for that sup. You may be able to hook this in mono or in stereo. But you definitely do not want to connect it up to the amplifier where as to cause damage.
Jun 01, 2014 | Rockford Fosgate Car Audio & Video
Need help installing xplod mex bt39uw
You have to invest in separate cables to the booster amplifier. Be careful that you have the proper relays and fuse for these or you might end up losing your car because of fire.
Mar 17, 2014 | Sony Xplod Mex-bt39uw In Car Audio...
I have a 1200 w sony xplod amp, with 2 caps, hooked to my sony xplod 1200 w 15s, I just need to know what size inline fuse I need to have connected to my power wire to my battery? I have a 40A that keeps...
with no signal input the fuse should not blow ,if it blows then the amp has a short on it ,if it blows when the volume is turned up really high the try 60 amps .
Jun 18, 2010 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
How to install Sony Xplod XM-1652Z Car Audio Amplifier
First you will need to post the # of voicecoils each subwoofer has, and their resistance.
Next - you can purchase an amplifier installation kit just about anywhere that will supply you with everything needed to wire up 1 amplifier.
Power wire w/fuse
Ground Wire
Remote Wire
RCA cables
Speaker Wire.
CLICK HERE for your manual.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jul 21, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Can I run 8 speakers and 1 sub through 1 1200watt 2:1 Sony Xplod?
asuming the 8s are 4ohms each; wire two in series and that gives you 8ohms then two more in series then you put those together in parallel and it gives you a 4ohm load. repeat with other four for the other side. you should then be able to bridge the sub
series; posative of one speaker to negative of other speaker and that doubles your ohms
parallel; posative to posative negative to negative and that cuts the ohms in half
Apr 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony xplod 1200 watt
i had the same ploblem with my amp then i found out i didnt have a good enough ground. Make sure you groung it to your weel well or some part of the frame. Or you mite be running with a fuse thats pushing to much power i use a 100a fuse 5 gage power cord to power my 1200w xplode and my 2 12" kicker comps. Or if your using two diff kind of subs then you amp is confused in why your asking for 500w on one side and 600w on the other this will also make your amp light come on.
Jan 19, 2009 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
Car Audio & Video Logo
112 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
