Question about InFocus ScreenPlay 4805 Multimedia Projector
My unit seems to work fine, except there is a dark shadow covering the right third of the projected image. Is this a sign that the bulb is going out?
The issue is not with the lamp, it is with the dust accumilating on the inside of the projector's lense elements. I know this because I opened up my Sony VPL-ES2 and took out one lense element at a time and cleaned off the accumalated dust off of all of them. There appears to be an accumalation of dust in the inside of the front lense also. Ehich has to be cleaned out... disassembly of the top of the front lense reveals the 3 elements that get dust on them also. HOPE THIS HELP ANYONE WITH THE SHADOW APPEARING ON ANY OF THE CORNERS OF THE PICTURE.
Posted on Apr 02, 2012
  • jkdblast
    jkdblast Apr 02, 2012
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 269 Answers
This is the light tunnel needing to be adjusted or replaced because is has collasped due to the heat given off by the lamp during the life of the projector.
Posted on Aug 28, 2010
Parts illustrated breakdown
If it is the lens you have other problems that would let it get that hot. Can't be sure, but I would first check the bulb to make sure it has not smoked. If so it must be replaced. When handling the bulb let it cool down or you can get severly burned. Never let your skin touch it or the oils on your skin can damage the bulb. I usually use a t-shirt or something to wrap it in while handling it or you could just wear cotton gloves.
Aug 30, 2014 | Optoma HD20 DLP Projector
Dark Band on Samsung projection TV
most likely optical engine issue----bad light engine.
Aug 27, 2012 | Samsung BP96-01073A E-Series Replacement...
I have a Toshiba 51h83. Everything works fine except there is an issue where the colors are slightly lighter on both the left and right sides of the screen.
this is normal with rear projection tv's its from long usage when the tv isnt always in full screen mode. you can sometimes fix this by replacing the bulb/ or the color board for the projector. also you can replace the screen as it seems like it may also be do to image burn in if it wasnt always in full screen mode. (did this for my uncles Mitsubishi projection tv)
let me know if that helps!
Mar 16, 2011 | Toshiba 51H83 51" Rear Projection...
The image became distorted. It is as if two of the three bulbs (assuming there are three) are working correctly and the image project by the third bulb is warped at the corners. Right at the center of the...
You need to replace Both of the Convergence ICs they are Big Black ICs and will have Part Number on them STK392-560 and this will Fix Problem.
Mats Electronics has ICs 1-800-628-1118.
If you should need any more help with this Matter ,Just let me Know
Thank You..
Feb 04, 2011 | Sony KP-53HS30 53" Rear Projection...
I have a new bulb but am getting a dark shadow around the edges of the picture. The bulb seems fine, but the shadowing is covering about half the screen. Any ideas?
The light tunnel under the colorwheel has collasped. This is a major repair. I have known some to glue the tunnel back together, but it requires patience and skill and the right kind of glue....
Jul 10, 2010 | InFocus IN24 Multimedia Projector
On the right hand side of the screen there are a few dark blue images/blotches.....if I replace the bulb, will this go away or is it something different? The new bulb is $229 and it is probably ready to be...
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine replacing the bulb will not solve your issue. Have a blessed one!
Apr 20, 2010 | Mitsubishi WD52527 52" Projection HDTV
I have a dark shadow down one side of the screen
replace light tunnel = use service manual for procedure....T.
Dec 13, 2008 | Samsung HLP6163W 61" Rear Projection...
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
Round shadows in picture
Sounds like the Bulb is almost out of life or a dustball or something is moving around inside the light compartment. Look in the instruction or user manual on replaceing bulb or opening bulb compartment or call Mits. for a service center in your area. Good Luck
Jun 24, 2006 | Mitsubishi WD-62525 62" Rear Projection...
InFocus ScreenPlay 4805 Multimedia Projector Logo
211 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
