Question about Canon Powershot SD450 / IXUS 55 Digital Camera
"Corrupted data" message
I have a 2GB SD card in my IXUS 55, and recently the camera has refused to take to its full extent, often stopping when half-full and signalling "corrupted data" on the screen. Camera or card problem?
  • Anonymous May 07, 2008
    Thanks, "Guest", I did try this after consulting the manual, changing on to the "low" setting as recommended therein if it was suspected that the card was misbehaving. It would take a few minutes, it said. 15 minutes later, the thing was still only half-way along the little bar on the screen and I had to remove the card because I wanted to go to bed! I'm beginning to suspect a faulty card - or is this whole thing a sort of intelligence test, which I keep failing?
Try formatting the card
Posted on May 06, 2008
Canon IXUS 970 IS will not recognise 2GB SD card although it used to do so
The memory card might have been damaged.If it was a problem with your camera it might not have recognized your 32k sd card.
So buy a new sd card.
Jun 10, 2012 | Canon IXUS 970 IS Digital Camera
Our schools Canon PowerShot SD450 memory card has no images or videos on it but the camera says memory full...help.
Make sure that the card is 2GB or smaller, the camera only supports SD not SDHC so it won't recognize a card larger then 2GB. If it's 2GB or smaller format it within the camera and then you should be good to go.
May 10, 2011 | Canon Powershot SD450 / IXUS 55 Digital...
I have a Eos Digital and was trying to view my photos on the computer by using my USB and was only able to access and view half of the photos b/c a message corrupted files flashed on. Please Help. I want...
If the files themselves are actually corrupted, there is not a way to fix them-- if instead there was some sort of error with the transfer of information between the camera and computer, then this is something that you can troubleshoot.
Your best bet would be to remove the SD card from the camera, (this is accessible from the door on the bottom of the camera) and use a regular SD card reader (something you can pick up at your local camera shop, or even at Walmart) to view the files on the card. This removes the camera from the equation, in the event that there is something wrong with it.
If you attempt to transfer the files when using just a regular SD card reader, and the transfer fails or your computer indicates that the files are corrupted, then you may need to resort to either a professional data recovery service (which may be offered by a local camera shop), or you may just not be able to recover the files in their entirety.
Mar 04, 2011 | Canon Powershot SD450 / IXUS 55 Digital...
Digital ixus55 compatible memory card
Hi. Your Canon IXUS 55 accepts SD Card cards.The maximum SD Card card capacity you can use in your Canon IXUS 55 is 2GB.
SD card larger than 2GB is not supported and will not work with your camera.
Hope this helps.
Feb 04, 2011 | Canon Cameras
My model is SD 10. Sofar I had 256 MB memory card in that camera. Recently I put 2 GB card. After somedays the camera take long time for processing. Finally in the photo taken day light, I can see only...
switch to a sd card of less than 2gb as your camera's internal image processor power is being used in running or reading the huge 2gb sd card ...and that is the reason the image izz getting white ...try for 1gb or less ..
Jan 31, 2011 | Canon PowerShot SD10 / IXUS I Digital...
Can I use an SDHC 4GB memory card for my Canon Digital IXUS 55? If not, what is the second best?
The IXUS 55 uses SD cards, not SDHC cards. You can use any SD card, 2GB and smaller.
Aug 25, 2010 | Canon Powershot SD450 / IXUS 55 Digital...
My Powershot 450sd camera is not reading 4GB SDHC
Apparently IXUS 55 is not compatible with a 4GB SD card. Use a 2GB and you would be fine.
Dec 29, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
SDHC memory cards are relatively new, and are sadly compatible with only the newest model cameras. For your model camera, recommend a maximum 2GB standard SD card. Fortunately, these days a 2GB card is very inexpensive.
Formatting a 4GB SD card for my canon ixus 700
The IXUS 700 works with SD cards, 2GB and smaller. It will not work with higher-capacity SDHC cards. You need to use SD cards, 2GB and smaller.
The IXUS 700 is called the SD500 in some parts of the world. You may download the SD500 manual and more from here.
Jun 24, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Memory Card Error
Check in the Manual that the camera can accept 2Gb.
If it say it can then return the card for replacement.
Feb 01, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Open Questions:
Canon Powershot SD450 / IXUS 55 Digital Camera Logo
91 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
