Question about GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
GE SIDE BY SIDE ICE AND WATER. FRIG MAKES A LOUD MOANING SOUND . EVERYTHING WORKS OK, EXCEPT FOR THE NOISE.
  • GE Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 28, 2010
At first the refrigerator side was freezing everything and the freezer was fine, except the ice & water quit working. I replaced the filter & it worked for a few days then it was back to the same...
if the fan was loud you could have a bad evap fan motor,is there ice on the inside back wall of the freezer?if there is you have a defrost problem and ice could be built up around the fan motor and the blade,when the blade hit the ice that could be the noise you were hearing and now the ice is stopping it from spinning at all.if there isn't any ice on the wall you could have a bad computer board,part number wr55x10942,i've seen g.e.'s that when the water and ice didn't work and the temp was warm it was the board but when you say the fan was loud it makes me think you could be iced up in there.also if the fan motor was reving up and slowing down the board could cause that,let me know if there's like snow or ice on the freezer wall and i can help you out
Sep 30, 2010 | GE PSS26LGR Side by Side Refrigerator
My GE Fridge PSS26SGRD has a moaning howling
The fan is hitting on ice buildup...unit is not defrosting...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The water to the ice maker continues to drip then freezes up.
the loud noise is from the water freezing and hitting the fan blade in the freezer, is the imkr level? have you replace the filter if has one? is it hooked to an R/O water drinking system? if so remove the filter in frig. last thing to do if others questions ok if the shutoff to that water line going to frig is on the bottom of the pipe shut all the way off then turn back on if you have a dispenser and water is really slow to come out this may clear up the low water pressure. If on most units if you do not have appx 35psi it will not allow the valve inside the watervalve to seat and allows water to dribble by
Sep 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Frig has water at door but no ice is made
Pour about 1/2 cup of water into the icemaker . If it dumps , replace the water valve . If not , replace the icemaker . Make sure the coils are clean of dust , etc... at bottom of fridge .
Aug 09, 2009 | GE CleanSteel GSL25JFTBS
GE Profile making knocking noises at different times
I have the GE profile Refrigerator with ice maker in the refrigerator compartment. Mine was knocking loudly for long periods of time, so I finally removed the icemaker by removing the side panel in the icemaker compartment held with 1 phillips head screw, disconnecting the electrical plug (unclip), pulling the tab of the icemaker down (on top) and sliding it toward the door, thus removing it. There was ice frozen in the motor compartment that was the problem. I let it thaw out and re-installed. All was OK after that..
Jun 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
Condensor sounds like it moans for a couple of seconds instead
Hello aeruslady1,
Do you mean the compressor? I'm sure you do. The condenser is the hot refrigerant line that comes off of the compressor.
It just sounds like you have an old compressor. I have seen them make noises for years before they take a dump. If it continues to run loud even after it starts however, then you may need to clean the condenser coil or replace the condenser fan motor. Another thing that might make it run loud is some refrigerant lines may be rubbing against something. This can be remedied by bending the lines.
Hopefully this helps.
Sincerely,
shays5415
Dec 03, 2008 | Refrigerators
Ice maker noise when filling
replace the water fill valve it is at the bottom where the water line conect to the unit
Nov 29, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge makes loud moaning sound
It is the control board. There is a recall on certain models and serial #'s that will cover the parts, but not all are covered. do a google search for hotpoint or GE howling noise. you will find out all the info you need.
Mar 14, 2008 | Refrigerators
Loud noise in freezer & ice buildup, too
Turn off, defrost over night doors open turn back on will work ok Regards Advisor
Aug 18, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
