Question about Hotpoint HSS25GFP Side by Side Refrigerator
Water leaking from the bottem of double door refrigerator
  • Hotpoint Master
  • 43,501 Answers
Here is a tip that I wrote about how to fix your freezer so that the drain hole does not keep freezing up.
Water Running in Refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
Why does my double doors/GE/culligan refrigerator leak water at night
there will be a drain at the back of the fridge down the bottom there is probably something caught in it blocking it causing the water from the evaporator in the fridge to run out instead of down the drain
May 22, 2014 | GE Refrigerators
MAYTAG DOUBLE DOOR REFRIG
THE PROBLEM IS WITH THE AUTO DEFROST (IF THE FEATURE IS AVAILABLE) OR ELSE YOU HAVE TO MANUALLY DEFROST IT REGULARLY
Sep 15, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
The unit won't stay on.
If the refrigerator wont stay on the start relay may be defective. This may have been caused by the leaking door that overloaded the system. The relay is a small box mounted to the side of the compressor and provides power to the compressor start winding for a split second at start-up to help get the compressor get started. If its defective the compressor may run off and on (a lot) or not at all and the refrigerator will not get cold enough. Fairly easy to do and reasonable
May 17, 2014 | Samsung RS2534 Side by Side Refrigerator
Water leaking into bottom of refrigerator section
Make sure you dry everything in the freezer when you have the door open and remove ice. It won't be a leak it will simply be the warm air inside the freezer that has turned into condensation. Double check the seal around the door to see if it curled up as that could be letting warm in and cold out giving same results.
Mar 02, 2012 | GE Profile PFSS6PKX Bottom Freezer French...
Water leak in front bottem side under freezer side
The drain for the defrost water is frozen shut or plugged...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 24, 2011 | Maytag MSD2756G Side by Side Refrigerator
Ice maker leaking water through ice dispenser in the door.
you have double trouble it so . water leaking through door is the foutain and if its the ice maker then the inside of freezer would be flooded . so change the water valve its a dual valve and this fixes both sides . but i thnk ou have only on side leaking .. mm
Aug 17, 2010 | Whirlpool 21.7 cu. ft. Side-by-Side...
A GE Profile Model, double door refrigerator with a water leak
If the leak is on the refrig water valve where the wall water line connects to , then use a 1/2" wrench and tighten the fitting on the water valve itself . If the leak is on the plastic tubing at the bottom of the refrig water valve , pull up on the small white ring while pushing down on the plastic tube to remove it from the valve . Cut off about 1 " of the tubing and reinsert it into the valve with pretty good pressure to be sure it is inserted completely .
Mar 27, 2010 | GE Refrigerators
GE side by side leaks water from icemaker tube
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint HSS25GFP Side by Side Refrigerator Logo
87 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
