Question about Electrolux Refrigerators
Now my ref. was clooing. - Electrolux Refrigerators
  • Electrolux Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 28, 2010
My hp f4280 keep saying door open but there is no error light on.
mybe dis is a problem with your sensor because it connot detect if the door is cloos or open mybe the sensor is dirty or damage
Mar 05, 2011 | HP DeskJet F4280 All In One Printer InkJet
How to disconnect
To disconnect ....remove the kickplate...after turning off the electric and water...remove the electric wire from the dishwasher by opening the e;electric box and undoing the wires...also remove the water pipe/hose from the inlet valve...then remove the drain hose from the drain and makes sure that it will not catch as you pull out the dishwasher...then remove the two screws that hold the dishwasher fast to the countertop and the pull the dishwasher straight out from under the countertop...
heatman101
Sep 15, 2010 | Kenmore Dishwashers
It just stop clooing i have cleand and vacumed every thing under the unit its starded to work for a week and now it just stoped again thanks jerry
the condenser located underneath is choked already with accumuated dirts.you could not removed all those accumulated dirts under the units sir,to do it , unplug your unit tilt it backward, in a safe angle,or remove the back cover of the unit, you can have a full view of the condensing tube,sometimes it gets clogged with your pets hair or accumulated household dirts, clean it and be a little bit carefull to avoid damaging any part.
Mar 18, 2010 | Refrigerators
Not drying and vent hose is wet in the inside gas comes on!
You have what I call a humidification problem and there is probably something clogged up in the hole in the wall to wherever it goes outside. It could also be that the dryer is TOO CLOSE to the wall.
PLEASE NOTE: If the HOT air that the dryer creates is restricted from exiting the dryer, the dryer WILL NOT HEAT PROPERLY.
If you have a CLOO in the ventilation system, the heat will try to get out and it cannot. The distance from the dryer to wherever the CLOG is could bu SUCH that this clog will creat a humidification factor that actually creates humidity and all seems wet.
Nov 20, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Hallo there i have an error code 10-389on docucolor12
The code refers to a paper jam in the fuser, although this may not be technically correct, the fuser heats the paper and melts the toner if this process is comprmised it may slow the progress of the paper through the fuser. Try the 3 links below see if they help, if necessary power down the printer and disconnect the plug for 2 minutes to reset the sensors
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=x_main_en,Company={683D76C8-B5C5-416E-9754-DD015FDB4F2E},ts=x_main_en,ques=ref(Country):str(USA),ques=ref(Prod_DC12):str(DC12CP),question=ref(ProdFamily):str(Prod_DC12),varset=Xcntry:USA,varset=Xlang:en_US,varset=prodID:DC12CP,varset=objID:8273,varset=prodName:DocuColor%2012%20Copier/Printer
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=x_main_en,Company={683D76C8-B5C5-416E-9754-DD015FDB4F2E},ts=x_main_en,ques=ref(Country):str(USA),ques=ref(Prod_DC12):str(DC12CP),question=ref(ProdFamily):str(Prod_DC12),varset=Xcntry:USA,varset=Xlang:en_US,varset=prodID:DC12CP,varset=objID:8024,varset=prodName:DocuColor%2012%20Copier/Printer
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=x_main_en,Company={683D76C8-B5C5-416E-9754-DD015FDB4F2E},ts=x_main_en,ques=ref(Country):str(USA),ques=ref(Prod_DC12):str(DC12CP),question=ref(ProdFamily):str(Prod_DC12),varset=Xcntry:USA,varset=Xlang:en_US,varset=prodID:DC12CP,varset=objID:8278,varset=prodName:DocuColor%2012%20Copier/Printer
Sep 16, 2009 | Xerox DocuColor 12 Printer
Placing a refrigerator in the garage
IF YOUR GARAGE TEMP GOES BELOW 35 THE REF MAY NOT WORK WELL BECAUSE MOST REF HAVE THE THERMOSTAT AS THE REF CONTROL. THE TEMP IN THE BOX IS SENSED AT THAT POINT AND SHUTS OFF, THE REF SEEM TO WORK BUT THE FREEZER WILL WARM UP.
IF YOU WANT TO USE A REF IN THE GARAGE, FIND ONE THAT HAS THE THERMOSTAT CONTROL AS THE FREZER CONTROL. LOOK AT THE CONTROLS, THE ONE THAT HAS AN OFF POSITION IS THE CONTROL THAT IS THE THERMOSTAT. SO, THE FREZER CONTROL SHOULD SAY "OFF" SOME NEWER REF WITH FULL ELECTROINIC CONTROLS MAY WORK AS THEY HAVE INDIVIDUAL SENSORS FOR BOTH THE REF AND FREEZER SECTIONS.
Jul 14, 2008 | Whirlpool EL7ATRR Refrigerator
Refrigerators Logo
18 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
