When I turn Eee on the icons are now displayed icons are 90 degrees to the right of screen,
  • khenry7650 Aug 27, 2010
    perfect, thank you so much
  • 19,396 Answers
Hi.
Press and hold the following key combination, the three keys must be held down at the same time:
Ctrl+Alt+Arrow UP.
Ctrl+Alt+Arrow buttons turns the display orientation.
Posted on Aug 27, 2010
How to rotate asus tablet webcam display 90 degrees?
turn on the auto rotate screen and if that doesnt go in the top right hand corner there should be a button there, click on it and it says rotate just keep tapping it until it rotates to your desiered position.
Nov 30, 2013 | ASUS Eee Pad Transformer TF101A1 Tablet...
Sideway screen INSPIRON mini how do I fix it
Changing the screen orientation of your Windows display can make your screen rotate at a 90-degree, 180-degree and 270-degree angle. By default, Windows operating systems do not come with a built-in mechanism to change the screen's orientation. Certain graphics boards, such as Intel, utilize hot keys to change the screen orientation. If the hot keys do not work on your computer, a program can be installed to create shortcuts that change the screen's orientation. One such program that is Windows compatible is called "iRotate," which is available to download for free.
Turn your computer on and wait for it to load. Once your computer finishes loading, make sure any open programs are minimized or closed. Press and hold the "Ctrl" and "Alt" keys on your keyboard. Press the corresponding arrow key on your keyboard for the direction to which you want to orient your screen. Press and hold the "Ctrl," "Alt" and up directional arrow key to return the screen to its regular orientation. iRotate Application Open the iRotate download site (see Bottom of page.) in your web browser. Click on the blue download link on the left-hand side of the page. The download link contains the text "iRotate" and has an icon of a floppy disc. Save the file to your computer. Open the iRotate file and follow the on-screen prompts to install the program to your computer. You can choose whether or not to put a shortcut on your desktop, place a folder for the program in your "Start" menu or automatically run the program after it finishes installing itself. Right-click on the iRotate icon in your taskbar. The iRotate icon is a blue rectangle that will display information about your graphic properties when you hover your mouse over the icon. Select a screen orientation from the drop-down menu. You can choose a 90-degree, 180-degree or 270-degree rotation. The "Normal Landscape" option returns your screen to its default orientation. iRotate
http://www.entechtaiwan.com/util/irotate.shtm
Mar 01, 2013 | Dell Inspiron Mini 10 Notebook
My screen does not flip 180 degrees when i turn the screen around
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Jan 28, 2013 | Panasonic Toughbook 19 Rugged Notebook -...
I was wiping my keyboard when I accidentally inverted the display of the monitor. How could I revert the display back. Thanks
This actually happens a lot, and it's very tricky but simpleto fix.
Here is a full list of keys that someone on another website sent me for
screen orientation problems, in case it's ever useful.
Ctrl-Alt-Up - right side up
Ctrl-Alt-Right - 90 degrees
Ctrl-Alt-Down - 180 degrees
Ctrl-Alt-Left - 270 degrees
If these don't work you'll have to do it manually,
There is an icon at the bottom of the screen (now maybe the top) for yourgraphics properties. Right Click it
Select--->Graphics Options--->Rotation---> and make sure"normal" is checked
It will be weird with the screen inverted but give it a go.
Hope this helps
RJ
Jul 31, 2011 | Computers & Internet
Screen layout-turn 90 degree to the left
Believe it or not this is an easy fix.
Hover your mouse over the double up arrows (Windows 7) and find the TV monitor looking icon. Double click that and your intell graphics driver properties will appear. There should be a tab that says 'Screen' or "orientation".
Anyway, in that tab you'll see several choices for your screen to turn. Memory failing me, I think if you hold the 'control' key and then tap the 'up' arrow it will orientate your screen back.
Hope that helped...
Oct 11, 2010 | ASUS Eee 4G Notebook
On my ASUS eee notebook the display flipped 90 degrees. How can I get it back to normal?
To change the display from portrait to landscape
Press Ctrl-Alt plus a left or right arrow key.
Sep 04, 2010 | ASUS Eee 4G Notebook
Monitor display is turned 90 degrees, how do I turned it back
It's funny. It's caused by (someone). It's user created prob.
Well it's sure it's intel graphics card. Look next to your clock, u will find a little blue screen like icon. It's there that your problem will be solved. Right click on it & go to the menu. Configure it on normal.
Feb 10, 2010 | Computers & Internet
Screen problen
hi,
welcome to fixya
what u can try is this
(If that doesn’t work, try Ctrl-Shift-R)
pls and pls rate this solution for me pls......thanks
Feb 16, 2009 | Compaq Presario Notebook
I was cleaning the keyboard on my Gateway model mx6124 and pressed a combination that rotated my display 90 degrees. How do I turn it back?
Not a key combo--it's a display properties setting. Look for an icon for your
video card
in the lower right corner Notification Area. Right click on it to
adjust. If you don't have the icon, go to Display Properties, Settings,
Advanced, Rotation.
Or try control-alt and one of the arrow keys at the same time.
Dec 22, 2008 | Gateway 2520915 Keyboard
ASUS ee Laptop Computer
Go into your graphics card setting and rotate the screen 90 degrees.
Jul 05, 2008 | ASUS Eee 4G Notebook
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
