Question about Cobra Radio Communications
How to fix feedback in radio or squeal - Cobra Radio Communications
    Genius:
  • 1,274 Answers
Hi, my name is John. Sounds like you have a wire off the mic. plug and its touching another wire. Try another mike, or take and see if it works on PA. To take the end apart off the mike, remove the tiny screws, should be three(3), careful not to misplace them. Slide the end back, and see if any wires are off or touching another wire, if so, re solder, then put the screws back in place and your done. May have to relocate the unit, to get rid of squeal......hope this was very helpful....
Posted on Sep 02, 2010
Radio very noisy, been to 2 dealers and been told 2 different stories both with end result cannot be fixed. Does anyone else have this problem and any diy ideas
by noisy do you mean static, squeal on starting the car or what
if it is static it could be a bad aerial
squeal could be electrical interference from starter motor
dealers do not fix radios so you would be better off taking it to a radio shop ( where radios are installed ) for a qualified opinion and diagnosis
if you take it to several and you get the same opinion then get a quote to fix or replace
Oct 30, 2015 | Cars & Trucks
Its a sante fe radio with the loud squeal
a loud squeal in a radio is feedback into an amp or receiver
It can also be interference from an electronic unit such as a malfunctioning alternator or ignition module
Mar 23, 2015 | Cars & Trucks
How does the Mickey mouse fm wireless microphone work
my microphone had no "applause" button. i flipped the switch on and turned radio on. put microphone up to radio speaker. I pressed/waited auto scan button on the radio until I got the "feedback" squeal. no adjustment necessary.
Dec 30, 2011 | Toys
I have a Cobra 148 mounted on the hump in a pickup truck and it works fine. Then I plugged in a old Turner +3 desk microphone and I get bad feedback when it is keyed up and I can also hear my voice thru...
You're most likely getting lots of RF feedback from the metal cab of your truck,combined with the real sensitive nature of the amplified Turner mike.I would put an old original Cobra (coffin mike) handheld mike or a Astatic Roadking 56 (RK56) on it.They are really hard to beat,especially when you have lots of feedback & squealing. I also have a 148GTL (malaysia made) that has a Turner +3 deskmike & it squeals in my truck but not in the house. The 148GTL has given me better service than ANY other radio I've owned.It has 120 channels (freeband) & upper & lower sideband. I think mine is a 5pin Cobra-type plug-in. Try a simpler mike & good luck. Squirrly
Mar 13, 2011 | Cobra 148 GTL 120-Channels Base CB Radio
Hisses/squeals when transmitting
Check the input voltage into the radio while in transmit. The voltage maybe dropping as you go into transmit which causes it to drop into receive. That in turn allows the voltage to come back up. With your finger still on the PTT it tries to transmit again, etc. This could cause a feedback squeal and other symptoms.
May 30, 2009 | Uniden PRO538W (40 Channels) 2-Way Radio
I can hear my buddys talking to me on my cb radio but once i try and talk to them it just sqweeks
Usually a squeal is feedback from a very high SWR or a mic wiring issue. Have the SWR tested and try another mic. Make sure it has the proper wiring. Just because a 4 pin mic fits in the jack doesnt mean it has the same wiring configuration. Also if you run an amp dont wire the amp and radio to the same location. That can creat a ground loop and cause squeal, but not always.
Mar 30, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
ICOM IC-A6 Feedback type interference
The problem is caused by the microphone preamp in the headset demodulating the AM transmission. Sordin MSA headsets also have the same problem. What you require is a headset with no electronics in it and a dynamic microphone.
Mar 16, 2009 | Radio Communications
I have a Maxon handheld cb - it squeals when keyed can not talk.
sounds like you are getting a feedback squeal.. try taking a wire and attaching to you handheld and grounding it to something.. that might work.. i know i have to have my mic on my cb grounded to my radio or i get a feedback squeal...
Jan 02, 2009 | Maxon HCB-10C CB Radio
Radio Communications Logo
91 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
