TRIDENT LPG EXCEL GAS FIRE PILOT FLAME VERY POOR AND WILL NOT RUN CONSTATLY have blown jet out etc
  • 4 Answers
Hi, This needs new pilot assembly,when the fire uses lpg they have a harder time of it than with natural gas.They burn hotter and lpg is less forgiving .Let know if you need help further or parts. Will
Posted on Jan 30, 2011
Convert dcs oven pilot from propane to gas 36-6-1CL
changing from propane to LPG requires the services of a gas fitter
it is a jet size change with air shroud adjustment to get the correct flame color burn
Nov 06, 2016 | DCS Kitchen Ranges
8" yellow flame shooting out of ignition tube when running. No adjustments that I can see on the (Honeywell) gas cut off/pilot valve.
yellow flame is an indication of incorrect air mixture
as it is gas I would suggest that you seek the services of an accredited gas specialists to do any adjustments or repairs
Nov 06, 2015 | Heating & Cooling
My lpg fryer IFS40 burns yellow flame and on the recent inspection tech supposedly found corroded heat exchanger. The fryer is only half a year old and still under warranty but the imperial only offer
The heat exchanger might be a result of the yellow flame but not the cause of it burning yellow. I would guess it is the amount of air being mixed with the gas. Most burners have a slotted metal air mixture ring on the front of the burner near the brass orfice, you are calling a jet. There is a locking screw to release the ring so it can turn to adjust the amount of air being mixed with the gas. If this doesn't fix the yellow flame it could be a gas pressure problem that could be the external regular in the gas line. Not sure if you are talking about the pilot flame or the burner flame or both? A tech should know how to adjust the air mixture.
Oct 15, 2014 | Imperial IFS40 Deep Fryer
Attempting to light valor homeflame fire the pilot jets ignite but when i attempt to put fire on to full flame, jets go out.
Sounds like it could be your thermo-couple.
or the microswitch you will find the number for valor here
Valor Gas Fires
Jan 14, 2011 | Valor Toys
Trident system excel plus gas fire problem, fire wont light on main flame pilot light is on and is a good flame checked injecter all fine,fan runs but the green led light 4 the fan isnt on? any help would...
Hi, fault is out in the fan box when the green light does not come on ,could be pressure switch or electronics.I have spares or can repair depending on where you live.
Jan 05, 2011 | Televison & Video
Make = Trident exel natural flame gas fire - model fan powered rear flue - 549 RMN FEF +3 The fire ignites and runs normally for about 10 minutes and then the gas side completely cuts out (both the...
Hi this is a oxy pilot problem as you say, would be best to replace. There are two types that were used on Trident /FEF fires,Ican help with either but need to know which one ,get back to me for further help .Will.
Nov 11, 2010 | Heating & Cooling
We3 have recently moved house. There is a Trident Excel gas fire in the house. When we switch it on after 10 mins it turns off its self. We don't have an instruction manual. Can you please tell me a web...
Hi, there could be a number of problems for this /But i guess the pilot is failing because its blocked or shrunk.Can help with manuals etc .Get back to me for details. Will.
Nov 09, 2010 | Heating & Cooling
Pilot light goes out randomly on 6 year old Bosch Aquastar tankless water heater. When I restart it it may work for a day then goes out again.
The pilot light can be blown out just by the main gas being ignited especially if the pilot flame is a little weak. Some times a bit of grit gets into the pilot nozzle reducing the flow and hence a weak flame. Try cleaning the piolt jet nozzle with a fine piece of wire. You may have to dismantle the jet nozzle to clean it properly.
Aug 30, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
CBN30T,DESA, pilot lights, but flames out when the burner comes on.. burner stays on a few seconds and shuts off due to cold thermo-couple. pilot flame seems to jump up and disconnect from the jet, as if...
ONLY ONE OR TWO THINGS AT FAULT.YOU HAVE A BAD THERMOCOUPLE.THIS IS PROBLEM 90% OF TIME AND CHEAPEST REPAIR.IF THIS DOES NOT SOLVE PROBLEM GAS VALVE IS BAD.HOW IT WORKS:THERMOCOUPLE WHEN HEATED WITH PILOT FLAME CREATES ASMAAL ELECRTRCAL SOURCE THAT HOLDS A MGNET OPEN AFTER HOLDING THE PILOT DOWN FOR ABOUT A MIN..THEN TURN GAS VALVE TO OPEN POSITION AND MAGNET WILL HOLD GAS VALVE OPEN.IF GAS VALVE DOES NOT STAY OPEN IT USUALLY INDICATES BAD GAS VALVE
Oct 13, 2009 | Desa International GWP30T Heater
Heating & Cooling Logo
354 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
