Question about Lexmark X5470 All-In-One InkJet Printer
The paper seems to jam everytime i try to print. it tends to pull to the right, and wont go all the way through. what could be causing this problem?
  • 1 more comment
  • darklingmist May 07, 2008
    same
  • Bobbie Davis May 15, 2008
    I am having problems getting my Lexmark 5470 to print. It will start to pull the paper through but stops before it will get started. I have unhooked everything and looked down in to see if any thing is stuck I am unable to see any objects at all. Is there any ideas you may have. There is nothing stuck in it and it still will not print. Help
  • j9janine4137 Mar 02, 2009
    Paper jams and pulls to the right. I cleaned the rollers with air but the paper will not feed in.
Same problem, I read you should clea the rollers, will try now
Posted on May 15, 2008
Same here
Posted on May 08, 2008
Canon pixma mp495 rear tray rollers only pulls paper in on one side then it jams
When the paper does not feed straight, dirty or sticky rollers can cause it to jamb or crinkle, also failure to remove all traces of paper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these pieces of paper. The rollers may be dirty or sticky and causes the paper to not feed straight.
Try cleaning the rollers with methylated spirits.
Mar 30, 2013 | Canon PIXMA MP495 Wireless Photo...
Lexmark printer wont print
Leading cause of paper jams is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Jan 04, 2012 | Lexmark X4650 All-In-One InkJet Printer
Everytime I go to print something the paper get's pulled to the right and becomes jammed. Why is this? And how can I fix it?
Seems to me that there is something blocking the paper path. Perhaps a paper clip or a pen ? Is there an access door on the rear of the printer. If so, open up and check to see if the jammed paper is hitting something or has a "dent" in it where it's hitting the object. Good luck .
Dec 06, 2010 | Epson Stylus CX4200 All-In-One InkJet...
I have a lexmark x2550 printer. I was trying to print a document but the paper became jammed so I removed it. I threw away the jammed paper and tried to print the document again loads of times. Everytime i...
If its not taking the paper, it may be that the paper you are using is not the right type. Some papers are too smooth or shiny to allow the guide wheels and platten ( roller) to grip the paper. This oftemn results in no paper or only one side of the paper being caught and then it jams.
Wipe the platten with alcohol, as welol as thye guide wheels if you can see them. Ink tends to stick on them and the platten and becomes shiny ans so paper will slip. Also try a heavier grade paper to see if that rectifies the problem
Aug 10, 2009 | Office Equipment & Supplies
Canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
The paper jams up when the printer pulls it into print
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed throught the printer. The reason for this, in some cases I have been able to clear the paper track of debris that was deposited there over time. Worth a try. I have fixed a number of printers this way saving costly repairs. Bud
Jan 21, 2009 | Lexmark X4530 InkJet Printer
Paper Jam
Seems you have a dusty roller in the feed mechanism. try cleaning off the roller with some windex (or equivalent) on a towel.
Nov 18, 2008 | Brother MFC-9420CN All-In-One Laser...
Printer always jams
check your toner cartridge and also u need to service the printer fuser aseembly.also change roller.or taplon tape.
thats all
also see there is not any paper jam in parts.
Oct 09, 2008 | Lexmark X2500 All-In-One Printer
Paper Jam HP LaserJet 1020
Papper never realy "jams" the problene is usualy that the paper is late reaching the next paper sensor. What i would sugest is that you clean the paper pickup roller it is usualy in the shape of a D. Clean it with dishwassing soap dont use water just clean soap rub it on with a clean cloth until the roller is dry so use a small amount. This should solve your prbleme.
Apr 23, 2008 | HP LaserJet 1020 Printer
Lexmark X5470 All-In-One InkJet Printer Logo
47 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
